20 Most Recent Pentax Optio 50 Digital Camera Questions & Answers
0answers
Pentax 50L
Be the first to answer 9/27/2017 7:09:02 PM • Pentax Optio 50... • Posted on Sep 27, 2017Be the first to answer
0answers
manual
Remove function 13 from keyboard
reaad your owner manual, and see the troubleshooting section, and fix it.you will valious information!God bless you
9/23/2012 11:32:40 AM • Pentax Optio 50... • Answered on Sep 23, 2012
W what size SD memory card can i use?can i use
You may use any SD card up to 2GB in size. Make sure you don't try larger SDHC cards, as they won't work.
8/24/2012 9:39:39 PM • Pentax Optio 50... • Answered on Aug 24, 2012
When turning on camera (optio M50) the lens does
Try the procedures in this tip.
8/24/2012 9:23:18 PM • Pentax Optio 50... • Answered on Aug 24, 2012
Lens error
8/24/2012 9:21:57 PM • Pentax Optio 50... • Answered on Aug 24, 2012
Software is outdated for windows vista
You don't need any software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
8/24/2012 9:21:15 PM • Pentax Optio 50... • Answered on Aug 24, 2012
PROBLEMS LOADING PICS TO COMP
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
8/24/2012 9:19:37 PM • Pentax Optio 50... • Answered on Aug 24, 2012
Pentax Optio E40
8/24/2012 9:18:41 PM • Pentax Optio 50... • Answered on Aug 24, 2012
The lens won't go out!
8/24/2012 9:17:17 PM • Pentax Optio 50... • Answered on Aug 24, 2012
Computer connecting to camera
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
8/24/2012 9:16:02 PM • Pentax Optio 50... • Answered on Aug 24, 2012
COMPUTER WONT ACknowledge camera
8/24/2012 9:15:10 PM • Pentax Optio 50... • Answered on Aug 24, 2012
Memory card error
Make sure you're using an SD card, 2GB or smaller. Larger SDHC cards will fit into the slot but are electronically incompatible.
8/16/2012 4:12:22 PM • Pentax Optio 50... • Answered on Aug 16, 2012
Is SDHC memory card compatible?
No. The Optio 50 works only with SD cards.
9/8/2011 9:04:40 PM • Pentax Optio 50... • Answered on Sep 08, 2011
Cannot take photos..... Screen shows
The display being white can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the phone aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
7/29/2011 7:15:06 AM • Pentax Optio 50... • Answered on Jul 29, 2011
Camera comes on. screen shows
If you can get into the menu system, find "reset" in the set-up menu. If not, remove the card and battery...press every button....leave it alone for 20 minutes...insert the card and then the battery...turn it on.....this is called a "hard reset" and sometimes works.
7/17/2011 8:36:51 PM • Pentax Optio 50... • Answered on Jul 17, 2011
Pentax Optio 50 Digital Camera Logo
93 questions posted
Top Pentax Cameras Experts
David Shaub
Marvin
Marvin
Steven Wander
Steven Wander
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
w size sd memory card use use
  • Cameras
