20 Most Recent
Mitsubishi LT55154 55 in. LED EdgeLit LCD HDTV Questions & Answers
Flashing green LED light. Unable to turn TV on. Did troubleshooting steps. Upgraded software.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Lt55154 turn itself off
Short circuited component/s at its main board. Contact the authorized service center or any service technician. This is not a user repairable fault. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Flashing power light
Fault with serial data; serial clock signal path. Serial clock path is OK, but data path must be traced. Seek tech support. This is a very skilled work.
White specs on tv screen
Good day!!!!
Please try to play a dvd movie or a recorded tv shows on your tv.
if the problem persist,your problem is not on the cable.
try to open the cover of your tv and look at the power supply inside.
you have better chances if you have failing capacitors on the power supply.
look the actual image and look if it is bulged on the top.
replaced it with the same type,ratings and value.
i hope this solution will be helpful.please don't forget to rate my answer.
thank you and good luck
White and Blk dots on
This tv have a design problems with it Light Projection Engine Block.This Light Engine Block have a design flaw with the IC chip the tvs corporations they're putting it in the tvs.This problems happen to many to other tvs compannies too like Samsung,Toshiba,Sony Big Screen DLP tvs too.The whole Light Projection Engine block have to be replaced or change the IC chip.This is a very expensive fix,because the tv Light Projection Engine Block is the brain for the tv.Call them up and talk to them make a deal with them to help u with repair cost.This problems with dots apearing on the DLP tv big screen is not a new problems,have been NEW on the Youtube video site for a few years now.
Mitsubishi VCR HS-U580 guide rollers not moving forward all the way. Cassette would not load. Also noticed drum not spinning when powered on
Your Mitsubishi VCR HS-U580 looks to have a problem with the information rollers and drum. Here are some things to check:
Look for something blocking the VCR or cassette compartment that would possibly be stopping the guide rollers.
Check the belt that drives the VCR mechanism. If it is loose or broken, you may also need to substitute it.
Clean the video heads using a head-cleaning cassette to make certain they're not dirty.
See if the drum motor is working. If it is not spinning, there may be an issue with the motor.
If the trouble persists, it's an exact idea to get assistance from a professional technician or contact Mitsubishi's purchaser support for advice.
Be cautious when dealing with electronic devices, and if you are not certain what to do, it's great to get assistance from an expert.
Where could I download a copy of a service manual for mitsubishi hs-u580 vcr?
i think finding a downloadable service manual for your Mitsubishi HS-U580 VCR might take some searching, but here are a few options:
Check the official Mitsubishi website's support section. They might offer downloadable manuals for older models.Many online appliance parts stores like RepairClinic or AppliancePartsPros stock service manuals for various brands and models. Search for your specific VCR model to see if they have it available.Websites like ManualsLib or iFixit sometimes host user-uploaded service manuals. While the availability and quality can vary, it's worth checking. If online options fail, consider purchasing a physical copy of the service manual from online marketplaces like eBay or Amazon.
Remember, some websites might charge a fee for downloading manuals. Always be cautious of suspicious websites and download from reputable sources.
I own a Mitsubishi 1080 1EEE 1394 television. Yesterday, we had a planned power outage in our area. When the power was restored, the only picture I can get is flipping horizontal lines?
Hoping you did not have electric overload that damaged the power supply, try unplugging the set and push the button On until no lights indicate anything. Then wait about an hour so the capacitors would empty themselves further. Next plug it back in and see if this worked. It is never wrong to push the edges a little in finding if the cables that go around the screen have a problem at that point. When one opens the TV (off power and unplugged) these flat cables should be checked for corrosion and right position in connectors. Corrosion is caused by little moist only, combined with the electricity. Then see if capacitors from the power supply, or any at all, have expanded tops. Those are the larger and smaller towers with metal on top that is divided in three parts. New ones alike can then be ordered but replacing requires basic skills. Further examples can be found on YouTube. Capacitors are common to fail early. Those larger ones have dangerous high voltage and can hold their charge for long span of time. it is not uncommon for devices like this to fail after being off.
