20 Most Recent Magnavox 19MF330BF7 19 in LCD TV Questions & Answers
Could be a defective switch or defective power supply.
Magnavox... | Answered on Jun 21, 2016
Codes are stored in the remote. Since yours is universal, you can use its "code search" (or equivalent) feature to find one for your Magnavox TV. If you sear through all codes stored in the remote without success, you may have to try a different universal remote. All universal remotes do not have all possible codes.
Magnavox... | Answered on Oct 28, 2015
Check its backlight inverter board. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Magnavox... | Answered on Apr 16, 2013
Most likely your power supply is damaged and will need to be replaced. Sometimes, power supply manufacturers add additional "fusible resistors" to provide additional protection.
Magnavox... | Answered on Jan 06, 2013
The new power supply board may be defective.
Magnavox... | Answered on Dec 02, 2019
Open internal fuse or power supply failure
Magnavox... | Answered on Nov 30, 2019
An applicable code would be found in the URC, not the other way around. Use code search to find it.
Magnavox... | Answered on Nov 29, 2019
Setup :
1. Power on your desired device (Ex: TV) as usual.
2. Find the four (4) digit device code for it in the attached Code List.
3. Press and hold the Code Search Button approximately 2 seconds until the LED indicator is illuminated then release the button.
4. Press and release the corresponding device selection button on the Universal Remote (such as TV Button).
5. Enter the four (4) digit code for your device by pressing the numeric buttons. The LED Indicator will turn off.
(If the code is invalid, the Indicator will blink 5 times then auto exit. Repeat the setting procedures from 2-5 again to reset a valid code.)
6. Aim the Universal Remote to the remote sensor for you device then operating the device. If the device responds correctly, it means you have entered the right code.
https://www.magnavox.com/en/index.php?controller=attachment&id_attachment=781
Magnavox... | Answered on Oct 26, 2019
replace the batteries in the remote, then push a button next to an FM radio, you may hear a buzz, that tells you the remote is working,this test doesn't always work,by the way. Next, turn the TV off & unplug for 10 min
Magnavox... | Answered on Oct 12, 2019
https://www.magnavox.com/en/index.php?controller=attachment&id_attachment=307
Hi
Try to download the user manual to your set by the above link. It has all details you want to know.
. If you wish to get some details; check the site linked here. Pull up older posts.
Magnavox... | Answered on Oct 06, 2019
Magnavox 19MF330BF7 19 in LCD TV Logo
Popular Tags
6 questions posted
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Magnavox Televison & Video
Most Popular Question
what can it be
  • Televison & Video
