20 Most Recent LG M2362D 23 in. LCD TV Questions & Answers
TV and remote jammed
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. https://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
2/2/2018 4:15:35 AM • LG M2362D 23 in.... • Answered on Feb 02, 2018
Sound but no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
2/14/2017 10:34:49 PM • LG M2362D 23 in.... • Answered on Feb 14, 2017
Hello guys, I have a LG flatron Tv LG m2362dp and an ASDA remote Urc220-D4f, & need help setting up the remote for this device, could please help and advise on how to do this.. many Thanks..
The remote instructions show codes to use to set-up the remote. There is an extensive number of these codes and usually indexed according to TV's identity. It is easily done with that list provided by the remote manufacturer. Check their website, perhaps there is a PDF of the user guide with the codes.
6/22/2016 12:35:00 AM • LG M2362D 23 in.... • Answered on Jun 22, 2016
Problem V3.17.0 appears on my LG TV model No.M2362D. What is this?
Sounds like it is displaying the firmware version because it is being started from applying power rather than pressing the On/Off button.
9/7/2014 6:10:09 PM • LG M2362D 23 in.... • Answered on Sep 07, 2014
Picture works for about 15 seconds then goes off leaving sound only. Appreciate any help
two possibilities 1.Power supply unit problem 2. lcd -lamp problem either ways for this model advanced help is needed
8/15/2014 5:24:28 PM • LG M2362D 23 in.... • Answered on Aug 15, 2014
Lg M2360d mode hotel
Refer its user manual for details. Gopakumar Gopalan Google
2/15/2014 5:37:34 AM • LG M2362D 23 in.... • Answered on Feb 15, 2014
0answers
Indication Light On, Black Screen, Unresponsive
I happened the same problem and the solution must change the power pack
1/25/2014 9:44:05 AM • LG M2362D 23 in.... • Answered on Jan 25, 2014
LG Flatron Monitor flashes on and off intermittently when used with PC
get someone that knows what they are doing and see if someone lives near you and see if they can come over to your house that is technology person and fix it.
12/21/2013 4:18:52 PM • LG M2362D 23 in.... • Answered on Dec 21, 2013
Turns blue led light on ...quick screen flash then
Almost certain to be the screen inverter pcb locking up and going into protect mode Flea bay has lots of them relatively cheap and it's a straight plug in swap for the old one.
3/15/2013 4:09:16 AM • LG M2362D 23 in.... • Answered on Mar 15, 2013
TV wont turn on
If I understand you correctly u can occasionally get the tv out of standby using the remote but seldomly if ever using the tv mounted controls . This being the case I would suggest the capacitors on the output stage of your TVs power supply and starting to fail giving you low voltage and keeping the set in standby its a very comin fault on SMPS's
3/15/2013 4:05:57 AM • LG M2362D 23 in.... • Answered on Mar 15, 2013
Flickering screen on lg m2362d
If you can hear sound, then screen is gone.I'll bet you don't.If you see an image, hear sound, just won't hold.I'd bet on the T-Con board.Not knowing what is really happening here..If willing to dive into electronic's.Open her up and start testing power side, starting with capacitors.
2/3/2013 10:54:40 PM • LG M2362D 23 in.... • Answered on Feb 03, 2013
Hi..i have LG FLATRON TV.model
I got the same problem and i raged a lot ! But now it's better, so you should take your telecomand ant try all buttons and it will turn on again ( sorry for my bad english i'm french and i'm 14 ) yours faithfuly ;)
2/2/2013 9:31:00 PM • LG M2362D 23 in.... • Answered on Feb 02, 2013
M2362D
try to replace sound board or sound IC
6/14/2012 11:31:47 AM • LG M2362D 23 in.... • Answered on Jun 14, 2012
Hi I just bought a
The tv have a long board that called the tv LCD inverter board,this tv LCD inverter board only job are to control and help the all the amount of the tv LCD screen panel backlight brightness for the tv LCD screen panel for light.This long LCD inverter is the causes and the problems.New tv exchange it for another one,not so new take ur tv warrenty repair qickly the tv long LCD inverter board it is the causes an the problems must have to be change.
9/14/2011 11:11:08 AM • LG M2362D 23 in.... • Answered on Sep 14, 2011
My LG M2362D keeps turning
Check the monitor cord to the PC, tighten them as also check the mother board for any loose connections. If possible try with an another monitor to confirm that the fault is with the monitor or not. If so open the monitor after disconnection of mains and solder all the suspected joints , seen to look dry. Check for loose components, capacitors, IC or resistor that detach the soldering connection when it is hot.
1/21/2011 12:00:43 PM • LG M2362D 23 in.... • Answered on Jan 21, 2011
0answers
0answers
LG M2362D 23 in. LCD TV Logo
24 questions posted
Ekse
View Most Popular
M LG
  • M LG
Most Popular Question
lg flatron tv model
  • Televison & Video
