20 Most Recent LG 26LE5300 26 in. LCD HDTV Questions & Answers
2answers
How can I operate my
1) You need to look at the output current rating (AMP) of this AC to 24dc adapter, this 24vdc adapter is a regulated switching power supply that will maintain 24vdc output up the maximum current rating and also has shutdown circuits if the over current draw is detect and also if the output voltage goes up beyond 24vdc to protect the load (TV).
2) To use 12vdc to 24vdc DC-DC booster, it should have the following spec:
A) The output current rating should be at least 20% higher than the load requires to give its head room.
B) It must have regulated output that will maintain the 24vdc when the input (12vdc) will vary from 10vdc ~16vdc or higher since your batteries will not maintain exact 12vdc all the time.
C) It must have good protection circuits that will protect it self from reverse polarity connections, shorted output protection, over voltage output protection.
D) It should provide AC ripple spec on the 24vdc output, it should be in the milli-volt range (you will always get AC ripple riding on top of DC when you rectify the AC into DC).
These are the minimum requirement for your DC to DC booster, which you need to protect your TV and your motor home from burning down.
I hope I explain it OK to you.
Please leave rating if it helps.
Basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/ Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
5/5/2022 7:41:34 PM • LG 26LE5300 26... • Answered on May 05, 2022
I m having a problem with lg led le5300 26'' it is not catching any signal it has stopped playing any channel i have tried auto tuning so many times but no channel found.
Make sure your cable/antennae connection is OK and you're getting signal from over there by connecting another (working) tv set to it.
3/30/2015 12:34:54 PM • LG 26LE5300 26... • Answered on Mar 30, 2015
MY LED TV LG 26LE5300 is not working. It's power module failed. changed the supply but still display is not coming up. The POwer Indication turns from red to white while switching on from the remote.
The Control Board on these TV's cause of 90% of the problems. You can actually find a NEW ONE on-line fairly inexpensive. When ONE Component goes out, it does have a habit of taking another one with it.
3/3/2014 12:12:41 PM • LG 26LE5300 26... • Answered on Mar 03, 2014
2answers
When I turn on my LG TV model 26LE5300 the LG logo screen flashes with the small clock and dashes at the bottom. The remote or buttons on tv won't work to change channel/menu or do anything. We ca
Your Main board is defective. Your board from Shop Jimmy is $69.00 but they are out of stock.EBR65469804 is the part number.
3/9/2013 5:19:04 AM • LG 26LE5300 26... • Answered on Mar 09, 2013
2answers
Issues with LG 26LE5300 26 in HDTV LCD TV Both
Reduce the resolution of the PC to 1024 x 768. This can be done by right clicking on the desktop ( not any icon ) click properties / click settings / slide the screen resolution pointer to 1024 by 768 / slick apply / Computer will ask if you want to save this setting /Click yes and then try connecting the TV to the HDMI port. Should work
1/19/2013 7:06:08 PM • LG 26LE5300 26... • Answered on Jan 19, 2013
How to connect my pc to LG 26LE5300 LCD HDTV wireless
Go buy a cord for like the same as yore computer screen you can get them from most elictonic stores it should have male pins on both ends and hook one end to the computer and the ather to the lcd hdtv then get an rca plug with pin plug on the ather put the pin plug in to the computer output and you should have the rca end in th hdtv input for sound (Make shore it is a sound input) . Push the input av butten on yore remote and go to pc ing there you have it.
6/6/2012 11:01:35 AM • LG 26LE5300 26... • Answered on Jun 06, 2012
Dear Sir, I and my family are great fan of LG products that is why I bought LG 26LE2600 to replace my LG TV two month before. during these two months it work very well but unfortunately from the last
Not to worry just because there was a fault on this model, sometimes even the supposed best brands also do not go well with a customer and hence we have many brands around selling well. To address the issue it is important that the set is under warranty or not. If so you MUST register a complaint with the LG support center.click on this link: http://www.lg.com/us/support/index.jsp If you can post your comment on the support /contact link , I amsure LG will take a serious view and rectify the fault.This seems to be a fault in the motherboard and it is important that you must seek a free replacement.
10/28/2011 3:49:43 AM • LG 26LE5300 26... • Answered on Oct 28, 2011
0answers
2answers
LG 75UK6190PUB has sound, but no picture.
Just change everything, or take this advice. https://www.fixya.com/support/r29790007-repairing_own_television ..
1/27/2023 12:22:58 AM • LG Televison &... • Answered 2 days ago
2answers
LG TS913ES AV Receiver has stopped working/blinking light
if not in timer mode then bad power board
1/24/2023 8:47:06 PM • LG Televison &... • Answered on Jan 24, 2023
75" LG tv has sound but no picture
Do you have a multimeter and able to pull the back off and get some voltage readings?
1/24/2023 1:44:31 AM • LG Televison &... • Answered on Jan 24, 2023
LG 75um6970pub tv turns on with a faint light.
The Tcon board is not working or there might be an issue with the back lights and the LCD and the screen for your TV.
1/21/2023 7:44:48 AM • LG Televison &... • Answered on Jan 21, 2023
How do I fix LG55UM7300pua screen issue?
If you can see the image as you say its dark that should be backlights are faulty
1/16/2023 4:57:51 PM • LG Televison &... • Answered on Jan 16, 2023
Kortek MagicSing YK5000 not connecting to LG Smart TV with HDMI.
It sounds like you are experiencing an issue with your Kortek MagicSing YK5000 not connecting to your LG Smart TV via HDMI. Here are a few suggestions for troubleshooting the issue:
  1. Check the HDMI cable: Make sure that the HDMI cable is securely plugged into both the Kortek MagicSing YK5000 and the LG Smart TV. Also, check the cable for any damage, such as frayed wires or a broken plug.
  2. Check the HDMI input: Make sure that the HDMI input on your LG Smart TV is selected and that the TV is set to the correct input source.
  3. Check the TV settings: Make sure that the TV's settings are configured to accept an HDMI input from the Kortek MagicSing YK5000.
  4. Check the YPbPr adaptor input: Make sure that the adaptor is securely plugged into both the Kortek MagicSing YK5000 and the LG Smart TV. Also, check that the adaptor is not malfunctioning.
  5. Check the TV firmware: Check if there's any firmware updates available for your TV and make sure that it's up to date.
  6. Contact the manufacturer: If none of the above solutions work, it may be necessary to contact the manufacturer of the Kortek
1/13/2023 12:27:43 PM • LG Televison &... • Answered on Jan 13, 2023
2answers
Have 70 inch LG tv that has black screen and no sound.
It sounds like you've done some initial troubleshooting steps to try and determine the cause of the problem with your TV. Based on the symptoms you've described, it's likely that the issue is with either the power supply board or the main control board. The power supply board is responsible for providing power to the various components of the TV, and if it's not functioning properly, it can prevent the backlight from turning on, resulting in a black screen. Similarly, if the main control board is not functioning properly, it can prevent the TV from displaying a picture and produce no sound. To determine which of these components is causing the problem, you can try the following: -Disconnect all cables from the back of the TV, including the power cord, then press and hold the power button on the TV for a minute. Connect the power cord back and turn the TV on. -Check the voltage of the power supply board to ensure it is providing the correct voltage to the main control board. -Check the continuity of the backlight LED strips to ensure they are not open. -Check the continuity of the ribbon cables from main board to the panel. -By checking all of this you could eliminate the possibility of a simple problem, If all of the above steps don't work, it's likely that one of the boards is faulty and needs to be replaced. It would be best to get a professional to diagnose and repair the TV, as working with the inner components of the TV can be dangerous and may cause further damage if not handled properly.
1/11/2023 1:11:45 AM • LG Televison &... • Answered on Jan 11, 2023
LED TV has a a blue tint, would could be the issue?
Either the source or the input devices have not been set up correctly with your TV.
1/9/2023 9:38:03 AM • LG Televison &... • Answered on Jan 09, 2023
LG 26LE5300 26 in. LCD HDTV Logo
18 questions posted
Marvin
Marvin
View Most Popular
  • LG Televison & Video
Most Popular Question
operate
  • Televison & Video
