20 Most Recent Sharp LC60LE810UN 60 in. LCD TV Questions & Answers
Open internal fuse or power supply failure
Sharp... | Answered on Jan 11, 2018
The LCD controller or T-con board does not control the back light. Some back light ballasts are incorporated into the power supply or the main board. Others are on their own board
Sharp... | Answered on Sep 12, 2016
No. the power button on the TV will turn it on, change the channels and the volume.
Return to the initial set up procedure and disable it.
Sharp... | Answered on Feb 11, 2016
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Sharp... | Answered on Mar 09, 2014
Have to make sure all ribbons are seated, and tabs locked. If any.
Sharp... | Answered on Feb 15, 2014
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH.
What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD!
SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN HOLD ALL three buttons until LED stops flashing and then release.
┬ĚThis will reset the TV in order to fix the problem.
┬ĚTHE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to [email protected] Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
Where can you buy the LED's - try searching
Sharp LCD/LED parts web site -
Copy this link:
http://www.encompassparts.com/item/8459814/SHARP/RUNTK4459TPZZ/LEDPWBUNIT(LC-60LE810UN),_X4
Yahoo.com or Google.com for resellers.
SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION
LONG STRIP (49 LED's)
FRONT SIDE BACK SIDE RL 94v-0
E329419
1029
LFa
Sn-Ag-Cu
Ps-1
K4458TP
4458ZZ
0921FM
104863
ee03A
SHORT STRIP (30 LED's)
RL 94v-0
E329419
1025 LFa
Sn-Ag-Cu
Ps-1
K4459TP
4459ZZ
0714FM
302213
Mm05A
Sharp... | Answered on Dec 11, 2013
Sharp LC60LE810UN 60 in. LCD TV Logo
64 questions posted
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
60 sharp aquos power indicator flashing
  • Televison & Video
