20 Most Recent
LG 32LD450 32 In. LCD HDTV Questions & Answers
first check color level setting on the tv when on av source input. double check input you are using, yellow video input (not green)
then try another device in that same input, then try the DVD player on another tv. The problem will be either DVD player or incompatibility or bad main board in TV, but usually a DVD or compatibility problem(cheap DVD player)
LG 32LD450 32...
Answered
on Feb 14, 2020
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations
. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (
Exclude the model number), in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts
LG 32LD450 32...
Answered
on Jul 22, 2017
In some models there would me no headphone jack. May it only have RCA audio out and optical out.
If you wish to get some details about television repair then check the following link
http://electro-medical.blogspot.com/
LG 32LD450 32...
Answered
on Aug 22, 2016
Where are the pictures coming from?
Off-air, cable, DVD, VTR, computer, etc?
LG 32LD450 32...
Answered
on Feb 13, 2015
Plug stick in and go to multi media mode and select from there.
LG 32LD450 32...
Answered
on Feb 04, 2015
Your symptoms point to the main board [the board with all the input connections], no simple fix, you must replace the board. Less likely the keypad is bad, just unplug the keypad and see if channel display stops popping up.
LG 32LD450 32...
Answered
on Oct 21, 2014
tv lg hidup suara y ada tpi gak jelas
LG 32LD450 32...
Answered
on Feb 05, 2014
Having only sound that means the inverter is bad (darfo) but switching off means also power unit.
LG 32LD450 32...
Answered
on Nov 08, 2013
How many times this power light flashes at one time switch on? Count it. These flashes are fault indications, and are called blinking codes. From the number of flashes occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.Blinking codes to many brand TVs are given in detail.
LG 32LD450 32...
Answered
on Oct 26, 2013
Check its back light inverter board.
LG 32LD450 32...
Answered
on Jul 13, 2013
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at
www.tvrepairworld.com
LG 32LD450 32...
Answered
on Mar 14, 2013
Unless you have electronics repair experience, you will need to replace the power supply. If you do have some repair experience, I would check for any shorted diodes, bridge rectifier, switching mosfet, or a cap on the primary side. Replacing the fuse will not solve your problem.
LG 32LD450 32...
Answered
on Feb 14, 2013
