20 Most Recent Samsung LN46C750 46 in 3D LCD TV Questions & Answers
about the only easy possible thing would require taking the set apart and looking where the display panel connects inside the set==a loose or open plug is about the only simple thing.
Samsung LN46C750... | Answered on Sep 02, 2012
May be a bad display panel but not a do it yourself repair, a buzz etc from the display panel is not a good sign.
The tv have LCD inverter boards backlight problems,tv is new take it back where u bought it for a new tv replacement.
Samsung LN46C750... | Answered on Mar 16, 2011
1. We are not samsung
2. Did you receive some type of coupon for the free glasses?
3. Did you ever consider that samsung sales millions of products and maybe a lot of people bought this tv with the same jibe you where going to get FREE glasses?
Listen, We are Fixya.com a do it yourself fix site for many products we are not the manufacture.
you might want to lodge a complaint with www.comsumerist.com, www.bbb.org www.ftc.gov about these sales practices.
1. if you have to received a coupon or some redemption code from the retailer then the likely hood that your going to get FREE glasses is a LIE.
You got a couple options:
1. Deal with it
2. take the tv back
3. or complaint until you have to check yourself into a hospital.
The fact is here you should have never took there word for it, FREE does not come with bows and ribbons nor in paper or plastic, you got to fight for FREE stuff do not believe me check out youtube and see what people would do for something FREE.
1. Stay calm (you think if i was samsung that i am going to give you free stuff yelling?)
2. Be polite (do not use all caps in your emails, or correspondence it gets you no where.
3. Relax talk to the people Nice even tho its a inconvenience using threatening behavior will get you no where but the door trust me I got kicked out of places for not being civil learned from my mistakes.
4. people have hearts,lungs,feet,ears, mouths, just like you do BE NICE, KIND, respectful, professional.
Put yourself in there shoes would you want to hear a angry client?
Thanks for using Fixya.com and not samsung.com you got the wrong people!! Please be considerate, NICE, take my advice
LIVE LIFE!!
God Bless!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Samsung LN46C750... | Answered on Aug 24, 2010
The problem is the LCD panel went bad, it can't be repaired, you have to replace it.
Samsung LN... | Answered on Jan 16, 2018
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung LN... | Answered on Nov 18, 2016
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
Samsung LN... | Answered on Mar 17, 2016
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Samsung LN... | Answered on Jan 18, 2016
Could be power supply failure. It tries to start but can't.
Samsung LN... | Answered on May 16, 2015
flicking or shutting down,i have the same tv,mine shuts down,it needs power supply,yours needs the control board,get one on ebay
Samsung LN... | Answered on May 11, 2015
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Samsung LN... | Answered on Mar 15, 2015
Page 64 of the user manual explains this procedure.
Go to Global Download Center and under Manuals, click See More + and then click on Download PDF.
Samsung LN... | Answered on Mar 03, 2015
Hi, not sure if you have the same fault as i had, but our tv only had half the screen go off, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps
jim
Samsung LN... | Answered on Mar 01, 2015
You can also replace the bad capacitors on the power supply board.
Samsung LN... | Answered on Jan 27, 2015
Samsung LN46C750 46 in 3D LCD TV Logo
14 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
tv emits strange sound from screen
  • Televison & Video
