20 Most Recent
Panasonic TCP46C2 46 in Plasma TV Questions & Answers
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Panasonic...
Answered
on May 13, 2014
The TV might have overheated. Contact the authorized service centre.
Gopakumar Gopalan Google
Protection mode is now ON. If you know how to set it OFF, can do.
Panasonic...
Answered
on Mar 28, 2014
Its fan SOS board is likely to be faulty. If you wish to get more details, check the site linked here. It has details about blinking codes to Panasonic Plasma TVs.
http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type
in the model name to your set in its search box, or view it in
Timeslide
option.
Panasonic...
Answered
on Jul 11, 2013
Hello!First: disconnect any signal source from your TV, including cable. Unplug TV off the wall or power strip. Let it sit for a minute or two. Plug power back in. TV might turn on itself, might not. Depends on configuration. Turn it on manually, using set's "power" button. Observe the behavior. Lines? TV need repair! Not an armature job. Lines gone? start to connect signal sources back, starting with cable. Observe the picture. No lines? Proceed to the next source: DVD player, and so on. At some point lines might return. Make note, what source causes the problem. Then, you may know what to do next.good luck,Alex.
Panasonic...
Answered
on Jan 10, 2012
For Optimum Perfomance purchase an S video cable, And a 1/4 to AV cord from Radio shack. Make sure you get them long enough to reach. They come in various sizes.
Plug the S video end into the computer then plug the other end of the S video into the tv.Plug the AV into the Audio-in on the TV, and Plug the 1/4 in to the Audio out/ Head phone jack on the computer. Go to Start button on computer and click, click on control panel, If you have nvidea it will automatically go to both screens. Once your in the invidea consol you can make fine adjustments by following the prompts and instructions. Let us know if we helped you, we love feed back here at FIXYA. Thank you for using us.
Panasonic...
Answered
on Mar 25, 2011
Cooling fans are normal and will kick on as temperatures require.
Panasonic...
Answered
on Mar 01, 2011
checkpower suply allcapacitors are ok if any one opens on top replace it
Panasonic...
Answered
on Feb 24, 2011
there should be a "format" button on your remote,just click it until you reach your desired ratio
Panasonic...
Answered
on Feb 01, 2011
Speaker magnets can distort TV pictures.
Panasonic...
Answered
on Jan 29, 2011
The cable box will most likely have multiple options for display - the most common will be a standard coax cable(exactly the same as what comes out of your wall).
This is where I would start since you have no HD option on your cable box.
There will probably also be RCA's on the back of the cable box (red, white and yellow). You should be able to use these three, the yellow being for your video and the red/white for left/right stereo sound, to connect to your TV as well. You would need to select the appropriate input for the cable you use.
CABLE/SAT will be your coax input, and depending on the input you plug into for the RCAs it would most likely be Video1 or Video2.
You can plug in the coax as well as the RCA's without a problem, they won't conflict or anything.
Make sure the cable box is on and then use your remote to select the different inputs - there should be a specific button dedicated to switching through these.
-Ryan
Panasonic...
Answered
on Jan 25, 2011
your unit has the format of 1080i and you have an ATSC color wih 600HZ movement. HD has to be transmittet or HDMI inputs or RGB input or comp input. what are you using as a source?
Panasonic...
Answered
on Nov 04, 2010
