20 Most Recent Samsung PS50C451B2D 50 in. Plasma TV Questions & Answers
You should be able to do so with an HDMI cable
Samsung... | Answered on Sep 01, 2015
Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. It will be best to replace the inverter board as card basis.
Samsung... | Answered on Jun 28, 2014
0083,0081,0089. Try these codes. For more information http://electrohelponline.blogspot.com/
Samsung... | Answered on Nov 19, 2013
Nothing can be done, if TV do not have supported resolution.
Samsung... | Answered on Oct 29, 2013
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_31_2012_9_08_59_pm.jpg5_31_2012_9_09_17_pm.jpg
Samsung... | Answered on May 31, 2012
before you consider it needing repair check a few things:
In menu of SET are SPEAKERS SWITCHED ON OR OFF?
Is volume on SET or a Box if used down or muted.
Does the set have an internal or external speaker switch?
last but not least does the set have sound when a DVD etc is connected via the rear audio and video jacks?
Samsung... | Answered on Apr 28, 2012
Forget it---The cost of a PDP (plasma display panel) easily will exceed the cost of the set when new---not to mention major labor to replace it.
Samsung... | Answered on Mar 23, 2012
This may help to explain your problem.
http://news.softpedia.com/newsImage/How-Does-Plasma-TV-Work-2.jpg/
Underneath the glass there is a thin film of metal that is half of the "connection" that gives you a picture. When you cracked the glass that connection may have been severed and in doing so killed the tv. Sorry about the news :(
Samsung... | Answered on Sep 12, 2011
if timer is not activated, your unit needs servicing.
have the power supply check first for output voltages it may not have enough to power up some of the circuits board.
Samsung... | Answered on Feb 08, 2011
Component video input is a high quality analog video signal separated by the three prime colors, red green and blue. You will need component video cables to make this connection.
Turn the television off.
Plug the connectors of each coaxial cable into their corresponding terminals on the TV.
Plug the other end of the cable into your other device that is also using component video, such as a cable box, video game console or DVD player, etc.
Power on the TV.
Press "component" on the remote.
Power on the device.
Samsung... | Answered on Nov 07, 2010
Normally a sign of overheating. Vacuum all the grille holes around the case. Also from Samsung
www.samsung.com > troubleshooting > TSG01108742
When your TV is turning off and on continuously, unplug it and plug it back in. Additionally, try updating the software if the TV stays on long enough between ...
Samsung... | Answered 8 hours ago
According to the analysis of fault performance, it is likely to be caused by the action of protection circuit
If you need tv parts ,you can link to https://www.abctay.com
Samsung... | Answered on Oct 16, 2020
You need to use the Amazon start page on your TV. It will probably give you a new code. Go to your computer Amazon.com/activate
you should be able to enter the six letter code to start your subscription. You should have Amazon Prime to use this feature on your TV.
Samsung... | Answered on Oct 15, 2020
try checking audio cables if ok audio settings if ok try external speaker if able
Samsung... | Answered on Oct 10, 2020
bad capacitors on power board
Samsung PS50C451B2D 50 in. Plasma TV Logo
19 questions posted
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
View Most Popular
  • Samsung Televison & Video
Most Popular Question
live streaming
  • Televison & Video
