20 Most Recent
LG GB220 Cell Phone Questions & Answers
How do I delete all text messages from my phone
Hi ...go to the box that you want to delete i.e inbox, sent etc.... choose a message select options and then select mark all ...and then select.. delete this will remove all the messages in that box. Hope this helps.
Free Unlock Code
Free unlock codes is provided only to Old LG mobiles like B1200, B1300 etc.. If you are in need to get the code for your LG GB220 mobile, visit
Unlock-zone.com . Here you need to check the service for your Network and Country it is locked now. If the service is available, they will send you the code through mail with instructions to unlock it easily.
MY LG GB220 NO NETWORK
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
Unlock code for lg gb220
What kind of lock code are you asking for? Is it a phone lock or Network lock? Anyway let me assume it as network lock.You can get the unlock code for LG GB-220 from any trusted online vendor. For example you can get the unlock code from
www.Simpleunlocking.com This is one of the trustworthy online site providing accurate unlock codes at affordable cost. Unlocking process here is very simple and easier. You will get step by step instructions on unlocking process. All the best mate.
HOW TO INSTALL .JAR AND
You really don't have to go through any stress installing files on your phone if the phone supports them.simply download the .jar files and try to open them.if your phone supports those java applications, they will install without stress but if they don't, try other file formats like .sis, .rar.
Forget my security code number
You
can
get the unlock code by contacting your current service provider
customer care department. If your phone is locked you can use any of
your friends phone to make this call. The
service
provider will then provide you the unlocking codes. Everything is done for free of cost and you are not going to be charged
for this process.
Another alternative is, you can take the
phone to any authorize phone service center to help unlock the phone,
because to unlock your phone, you will need some kind of software, USB
cable
etc to unlock the phone, so you can also go a nearby phone service
center to unlock the phone,
but calling your network service provider is the best because they have
the records of your phone and can easily help to unlock it. This are the
two reliable means you can unlock your phone..
WHERE CAN I GET LG
have you tryed driverwiz ?
they have alot of newer drivers for the lg's
