20 Most Recent
RTX DUALphone 3088 for Skype Questions & Answers
Registering Handset to Base Station
Registering the handset to the base station has nothing to do with your wireless router. The handset and the base act like walkie talkies. The signal from the handset must match the signal in the base station. The handset may have a reset button of its own, or a sequence you must go through to register the handset to the base. Try removing the battery from the handset and see if that will work. If not you need the manual to tell you what to do to register the hand set to the base.
Hi, I buy two phones 3088, and in both, time to
There are a few things that cause what you describe:1. The landline is having problems and your phone is trying to alert you so that you know not to use it2. The internet connection is having problems,3. You have voice mail or other notifications that wait your attention.To avoid any issues you should update the firmware on both devices.Have a nice day!Vlad
I can't hear the phone when I receive a call. Have
I had the same problem with the latest firmware (Version 250). It was working perfectly earlier but this problem arose suddendly. I fixed it after many days by installing an older firmware (Version 245 in my case) and then installing the latest firmware again (Version 250).
You can install the firmware by going to:
Menu > Settings > Advanced > Firmware Update > All Firmware vers. > (select firmware version) > Install
Please make sure that you don't loose power and internet to your base station during the update. Also, your handset should be fully charged.
Hope this will help everyone who has the problem.
Model RTX 3088. Sound of
Do you mean the ringing tone? our the Earpiece of your RTX 3088. but since you say landline too, probably you mean ringer. so when you call out, you are able to hear them and they hear you right? I will assume that the landline is inserted in the RTX 3088 base and you are using it as a 2in1. you could have muted your set. Adjust the volume via Settings ==>Tones ==> Ring tones.
What is direct marketing?
Hello
Direct marketing is a sometimes controversial sales method by which advertisers approach potential customers directly with products or services. The most common forms of direct marketing are telephone sales, solicited or unsolicited emails, catalogs, leaflets, brochures and coupons. Successful direct marketing also involves compiling and maintaining a large database of personal information about potential customers and clients. These databases are often sold or shared with other direct marketing companies.
for more information visit
http://www.wisegeek.com/what-is-direct-marketing.htm
Hope this helps if so do rate the solution
3/21/2024 10:02:08 AM •
Lands Phones
Answered
on Mar 21, 2024
SONIM XP 3800 VOICEMAIL INDICATOR STAYS ON BUT,NO MESSAGES=?
TRIED POWERING OFF-PROBLEM STARTED 2/WEEKS AGO.
1. First, try resetting your phone by powering it off completely and then turning it back on after a few seconds. This can sometimes resolve minor software glitches.
2. If the problem persists, you can try contacting your mobile service provider and ask them to reset your voicemail on their end. They might be able to resolve the issue from their system.
3. Another option is to manually check your voicemail and listen to any existing messages. Sometimes, even if you've listened to a message, the indicator might stay on. By checking your voicemail and ensuring there are no unread messages, it might help clear the indicator.
If none of these steps work, it could be a more complex issue that might require technical support from Sonim or your mobile service provider. They should be able to provide further assistance. Let me know if there's anything else I can help with!
2/5/2024 4:27:32 AM •
Lands Phones
Answered
on Feb 05, 2024
