20 Most Recent AT&T SB67108 Phone Questions & Answers
I am unable to register
Here are the steps: Press menu, then press *883247# and then press the up arrow. Select deregister and then unplug and take the battery out for 10 seconds. Plug the phone back in and it's ready to be registered to another device.
1/31/2016 11:29:28 PM • AT&T SB67108 ... • Answered on Jan 31, 2016
We replaced the base unit
To un-register the SB67108 handset from a base unit, SB67118 or SB67138, you will need to do these steps in order: 1. Press menu 2. Key in this sequence *883247# 3. Select deregister 4. Unplug the battery for minimum 10 seconds 5. Plug battery back in and it will want to be registered. 6. Follow the directions in your base unit manual to reregister it. That's it in a nut shell.
4/28/2015 7:16:52 PM • AT&T SB67108 ... • Answered on Apr 28, 2015
0answers
My cordless phone displays message,
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone (or your power is out). Please contact your telephone company for instructions on accessing their voicemail system.
10/3/2012 5:48:41 PM • AT&T SB67108 ... • Answered on Oct 03, 2012
2answers
How to clear ALL memory from 4-set of (now disconnected) AT&T Model CL82401??
There is a way to delete all calls in the Caller ID log. With the phone system in standby mode, press Menu/Select (key to the upper right of the arrow keys). Scroll (up/down arrows) to Caller ID log. Press Menu/Select again. Scroll to Del all calls and press Menu/Select. You should see a Delete all calls? Press Menu/Select to confirm. There is no corresponding way to delete all old speed dial or directory listings. The manual for the CL82401 is available here: https://att.vtp-media.com/media/p/document2/products/%7B60627918-4BDE-494D-8537-E265D7649708%7D/CL82201_CIB_2_611.pdf . See page 42 for the information on deleting the caller ID log. See pages 36 and 38 for the directory and speed dial items. I hope this helps. Cindy Wells
12/15/2023 3:52:36 PM • AT&T Lands... • Answered on Dec 15, 2023
2answers
AT&T 1830 phone/answering machine. How do I get a manual please?
Question edited for clarity.
AT&T 1830 User Manual - ManualMachine.com
ManualMachine.com https://manualmachine.com > att > 6453-user-manual ANSWERING SYSTEM TELEPHONE 1830. •Installation. •Telephone Operation. •Memory Dialing. •Answering System Operation. •Remote Operation ...
AT&T Product Manuals ' Product Support Center
AT&T https://telephones.att.com > product-support > manuals Find official user manuals and quick start guides for cordless and corded telephones from AT&T.
AT&T Answering Machine 1830 need manual for at&t 1830
Manuals Online http://phone.manualsonline.com > support > att > need... Aug 9, 2012 - Phone manuals and free pdf instructions. Find the user manual you need for your phone and more at ManualsOnline.
12/13/2023 11:07:52 PM • AT&T Lands... • Answered on Dec 13, 2023
How to register AT&T Synj SB67108 to new base unit SB67138?
Register SynJ SB67108 Handset How to register AT&T Synj SB67108 to new base unit SB67138? To register an AT&T SynJ SB67108 handset to a new SB67138 base unit, you will need to follow these steps:
  1. Make sure the new base unit is plugged in and turned on.
  2. Press and hold the "Menu" button on the handset until the display shows "Menu."
  3. Use the navigation buttons to select "Registration" and press "Select."
  4. Select "Base" and press "Select."
  5. The handset will begin searching for the new base unit.
  6. Once the base unit is found, it will be displayed on the handset's screen.
  7. Select the new base unit and press "Select" to complete the registration process.
  8. The handset should now be registered with the new base unit.
Note: if you have multiple handset you need to register, repeat step 2-7 with each handset.
1/22/2023 6:32:18 AM • AT&T Lands... • Answered on Jan 22, 2023
How do I deregister my AT&T CL82313 handset please?
Question edited got clarity. Video should help, similar model. https://www.google.com/search?q=deregister+my+at%26t+cl82313+handset ..
6/28/2022 4:54:29 PM • AT&T Lands... • Answered on Jun 28, 2022
Where can I get a replacement power cord for a handset dock for an AT&T phone model : TL96217
Try AT&T direct https://telephones.att.com/shop The second link might work, but it is a $28 gamble. The first link says specifically that it isn't for the handsets, but doesn't show the end connector! https://www.google.com/search?q=AT%26T+TL96217%2C+replacement+power+cord+for+a+handset+dock ..
1/14/2022 11:55:24 PM • AT&T Lands... • Answered on Jan 14, 2022
Standby mode At&t CL8`301
Do you mean the AT&T CL81301 Cordless telephone? This model doesn't have an answering system. You'd need to adjust the number of rings for your voicemail system through the telephone company's system. See the manual here: https://att.vtp-media.com/media/p/document2/products/%7B40A22BFC-681D-46DC-B836-7CB7C7A691FE%7D/CL81101_CIB_5_610.pdf . If you mean the AT&T CL82301 or the CL83301, first make sure that the system is set to Answer On. Do this with the base Answer On/Off button or through the Menu system (see below for accessing the Answering System menu). You'll need the Answer On/Off line in the handset menu. With the phone system idle (no calls in or out, no one using another handset), press Menu/Select. Use the Up(DIR)/Down(CID) arrows to navigate to Answering Sys. Press Menu/Select. Navigate to Ans Sys Setup and press Menu/Select. Navigate to # of Rings and press Menu/Select. Use the up/down arrows to choose the number of rings and press Menu/Select to Save. Press Off/Cancel to exit the menu system. The manual for this cordless telephone system is available at ManualsLib, https://www.manualslib.com/products/AtAndt-Cl82301-165464.html . See page 47 of the manual, https://www.manualslib.com/manual/643600/AtAndt-Cl82101.html?page=53#manual . Note: if you choose Toll Saver, the answering system will pick up after two rings if you have new messages. It will pick up after 4 rings if there are no new messages. I hope this helps. If you have a different AT&T CL8 * 301, please add a comment with the correct second digit in the model number. Cindy Wells
8/22/2021 9:58:57 PM • AT&T Lands... • Answered on Aug 22, 2021
I need phone manual for AT&T 847. How to assign extension to this model?
http://www.radiomanual.info/schemi/YAESU_HF/FT-847_user.pdf
5/6/2020 7:42:43 PM • AT&T Lands... • Answered on May 06, 2020
I need to purchase a replacement manual for the AT&T TTY 8840 Telephone
actually you can get the manual for free at manuals lib.com
1/27/2020 6:47:56 PM • AT&T Lands... • Answered on Jan 27, 2020
My AT&T landline has no dial tone
Is this just for your home or do your neighbours have the same problem? I hope I can help you further, a few more details would help me be able to help you.
Regards Jem
9/22/2019 11:01:20 PM • AT&T Lands... • Answered on Sep 22, 2019
Whenever I place a call and am asked to dial an extension , I keep getting the message to enter the number and am unable to complete the call.
Do you hear tones when you press the buttons to dial?Many phones have the option to dial by pulses instead of tones. Make sure your phone is set to tones.
5/13/2019 1:40:49 PM • AT&T Lands... • Answered on May 13, 2019
AT&T SB67108  Phone Logo
13 questions posted
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
AT&T Lands Phones
  • AT&T Lands Phones
Most Popular Question
am unable register
  • Lands Phones
