20 Most Recent Mitsubishi WS-65712 65" Rear Projection Television Questions & Answers
Your tv is probably going into a "protection mode" this means something inside the set had failed. This is the tv's way of shutting down before more damage can occur. This could mean many different things that could have gone wrong with this unit. Your best bet is to call your local dealer and have them come out and look at it for you. Tearing apart tv's is very dangerous! Some sets have up to 30,000 volts on the anode! GOOD LUCK!
Mitsubishi... | Answered on Oct 20, 2011
I have worked on a few of these and all have had problems with the convergence IC's solder joints. Over time, the heat generated by the IC chips weakens the solder joints. All that needs to be done is resolder the joints.
Mitsubishi... | Answered on Sep 17, 2011
Don't get stressed out, not worth the hassle.
If recently aquired. Proof of purchase receipt and return to seller.
Mitsubishi... | Answered on May 12, 2011
Unplug set for a few minutes. Try to turn it on and if power light comes on and goes off, repeat self check.
If you unplugged set before doing this, error code will always be 1,2 which is no error detected--unplugging clears error code and you have to try again.
If you have questions comment here and I will assist you.
SD TECH
Mitsubishi... | Answered on Jan 01, 2011
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingnment,have colors shadows pictures or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,require replacing to fix the tv picture convergence problems.The shop,will cost $300-350 for parts and labors.
Mitsubishi... | Answered on Oct 19, 2010
the convergence ic wnet out , it need to be replace , i would recoment to take to a repair shop because after they replace this ic they may need todo aligment , call around repair cost about $250 - 350
Mitsubishi... | Answered on Aug 25, 2010
by what your are stating sir yest the problem wiull be nthe lamp but it could also be the ballast board witch powers up teh lamp , it could be that the ballast is not strong enough to turn the lamp on.
Mitsubishi... | Answered on Jul 23, 2010
Tip
Mitsubishi WS-65712 Manual Download
Download Mitsubishi WS-65712 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-65712 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65712 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Bypass Mitsubishi WS-65712 Front Lock
Reset Mitsubishi WS-65712 VChip Password
on May 05, 2010 | Mitsubishi WS-65712 65" Rear...
Tip
Bypass Mitsubishi WS-65712 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65712 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65712 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Tip
Bypass or Reset Mitsubishi WS-65712 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65712 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
go to this website and buy the kit for your t.v., I did and it fixed my t.v. mitsubishi ws65712. had the green blinking light, and could not power up. hopes this helps.
www.tvrepairkits.com
Mitsubishi... | Answered on Mar 13, 2010
Replace the DM capacitors. That will often happen after a power failure, as the capacitors will be bad and the set will continue to operate fine untill the power is lost, then they can no longer charge due to their being weak so the timer led will blink repeatedly because the DM cannot complete the boot sequence untill the capacitors charge.
Mitsubishi... | Answered on Jan 22, 2010
Do the self check this set has:
when the power light goes off---on the front of the set press and hold both the MENU and INPUT (or Device) buttons for 5 seconds and then release both.
Power light will blink a two digit error code--most common is 2 blinks a pause and 2 blinks--it will repeat the code several times.
Let me know what the error code is and I will tell you what it means.
2,2 is most common and the most easy to fix.
If this information helped you rate this solution as I do this here for free.
Mitsubishi... | Answered on Jan 11, 2010
this is power section problem
Mitsubishi... | Answered on Jan 09, 2010
Mitsubishi WS-65712 65" Rear Projection Television Logo
Popular Tags
29 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
red field
  • Televison & Video
