20 Most Recent Mitsubishi VS-60803 60" Rear Projection Television Questions & Answers
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.By replacing all these parts on the tv convergence board to fixed it to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Mitsubishi... • Answered on Feb 05, 2011
replace the power relay the contacts are burned and, will not latch.
Mitsubishi... • Answered on Jul 22, 2010
The VS6983 Mitsubishi model is a analog televison and not HD capable.
Mitsubishi... • Answered on Jul 15, 2010
You might check the fuse, but I think you have more of a problem than that.
Mitsubishi... • Answered on Jun 08, 2010
Hi Gloria,
Mitsubishi is the best DLP big screen on the market, ask your husband not to lose faith!
Mits had some issues with DLPs right around the time yours was manufactured, the issues did not affect all sets, I recommend contacting Mitsubishi Consumer relations @ 1-(800)-332-2119, explain to them your situation and the history of your TV and they will be happy to assist you, speak nicely,be professional and they will work with you.
Now, Mits did have some Thermocouple issues around that time, so I would ask about that, and they also had some optical block problems around that time, so I would bring that up also, I do not know if either of these are the problem with your TV, but I hope this gives you another avenue towards resolution of the TVs problem!
Good Luck !
Mitsubishi... • Answered on Feb 25, 2010
What you want to do is first remove the mesh grill on the front. Just give a tug and it'll pop off. Then remove all the screws along the bottom of the screen. Now it should just slide up a few inches and come off. Be carefull, you have to disconnect the control panel. It'll have a little disconnect connector on it and will be visible once you pull the mesh off.
Mitsubishi... • Answered on Dec 20, 2009
looks like the Green , RED and Blue are out of alignment and needs to be sent to the TV repair station for alignment
Mitsubishi... • Answered on Sep 18, 2009
Not advisable. $500.00 is way over board what we charge for that repair. 250-300 max. I don't know of any shop or with our tech web site that charges that kind of money. I would still shop around.
Mitsubishi... • Answered on Jul 20, 2009
How old is this TV and that black bow is across the screen going from left to right?
Thanks.
Mitsubishi... • Answered on May 13, 2009
menu -1-3-7-0
then inital
then enter
DO NOT DO THE E2 RESET!!!!
Let me know if you need more help
Tim nolan
Mitsubishi... • Answered on Sep 17, 2008
to reset the whole tv press menu 1 2 3 enter
Mitsubishi... • Answered on Nov 11, 2007
You have the typical convergence IC falure that every projection TV encounters at least once in its lifespan. The convergence ICs will both need to be repalce as it will only get worse. if you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Mitsubishi... • Answered on Mar 23, 2007
greetings from belize take your set to a tech and have him look at it.good luck.
If the screen is black it is broken, that is why you got it for nothing. You saved the person the disposal fee. https://www.fixya.com/support/r29790007-repairing_own_television It is a DLP projection television, a veritable antique of old technology that has projection bulbs that need changing once a year. I would suggest that your bulb has probably failed. They are $30 to $52 each! https://www.google.com/search?q=Mitsubishi+1080+medalion+hd+manual .. ..
Mitsubishi... • Answered Yesterday
Antique technology! :>) It maybe that the guard around the fan is catching the fan blade. The only thing you can do is strip it down. It maybe something vibrating because it is loose and needs tightenening. Or you could just buy an 86" Ultra HD Flat screen :>D
Mitsubishi... • Answered on Apr 20, 2021
Televison & Video Logo
Popular Tags
21 questions posted
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi vs 60803
  • Televison & Video
