20 Most Recent Mitsubishi VS-60801 60" Rear Projection Television Questions & Answers
I need an HV Flyback transformer and Convergence
Navigate to this page ..an search for your product ! http://www.acme-sales.net/portal.php?country=USA
12/18/2010 11:30:05 PM • Mitsubishi... • Answered on Dec 18, 2010
I have a Mitsubishi vs6080
7/6/2010 3:45:55 AM • Mitsubishi... • Answered on Jul 06, 2010
2answers
Vertical hold does not work
check for bad cap,s in virt ic
9/9/2009 1:16:20 AM • Mitsubishi... • Answered on Sep 09, 2009
The picture rolls vertically sometimes.
I would check the capacitors in the verticle deflection circuit. Also try resoldering the verticle output as well as the verticle yoke pins where they connect to the chassis. Mitsubishi has had some trouble with their capacitors, you may have one that is leaking. Let me know if I can help you further.
1/13/2008 11:32:48 PM • Mitsubishi... • Answered on Jan 13, 2008
I have a mitsubishi wd 77731 tv and the screen turned completely white with white vertical lines. what happen?
If your Mitsubishi WD-77731 TV screen has turned completely white with white vertical lines, it is possible that there may be a fault in the display panel or the video processing circuitry of the TV. This could be caused by a variety of issues, including a faulty LCD driver board, a loose or damaged video cable, or a problem with the TV's power supply. Here are some troubleshooting steps you can try to determine the cause of the problem:
  1. Check the video input: Ensure that the video input to the TV is working properly by connecting a different video source, such as a DVD player or game console, to the TV.
  2. Check the video cables: Inspect the video cables that connect your video source to the TV for any damage or loose connections. If you find any damage, replace the cable.
  3. Power cycle the TV: Turn off the TV and unplug it from the power outlet for 1-2 minutes. Then, plug the TV back in and turn it on to see if the issue persists.
  4. Check for firmware updates: Check the Mitsubishi website to see if there are any available firmware updates for your TV. Updating the firmware may help to resolve any software-related issues.
If none of these steps resolve the issue, it is recommended that you contact a professional TV repair service to diagnose and fix the problem.
3/8/2023 11:50:05 AM • Mitsubishi... • Answered on Mar 08, 2023
I have a Mitsubishi TV model 73838, only getting black screen when turned on. Also replaced DLP ... getting red/ orange flashing light Changed lamb ad
If you have replaced the DLP lamp and are still experiencing a black screen, along with a flashing red/orange light, there are a few possible causes. One possible issue is with the color wheel. The color wheel is responsible for producing the colors on the screen, and if it malfunctions, it can cause the TV to display a black screen. Another possible issue could be with the ballast, which powers the lamp. If the ballast is malfunctioning, it can cause the TV to fail to turn on. It is also possible that there could be an issue with the power supply or the main board. In order to determine the cause of the issue, you may need to contact a professional technician who can diagnose and repair the TV. It is important to ensure that any repairs or replacements are done by a qualified technician to avoid any further damage to the TV.
2/23/2023 2:23:49 PM • Mitsubishi... • Answered on Feb 23, 2023
Loose wire coming from projector
It sounds like the wire you're describing is likely a connection wire for the audio component of your Mitsubishi 73838 projector. It's important to reconnect this wire properly in order to restore audio functionality to the projector. Here are some steps you can take to reconnect the wire:
  1. Identify the connector on the circuit board where the wire originally came from. This should be easy to spot as it will likely be the only empty connector in the area.
  2. Carefully reconnect the wire to the connector, making sure that the wire is securely connected and properly aligned.
  3. Check to make sure that the wire is not in contact with any other components on the circuit board, as this could cause a short circuit.
  4. Power on the projector and test the audio to see if the wire has been reconnected properly.
Please be cautious when handling the projector. It's best to be sure that the projector is unplugged and you have a static free environment. Also, be sure to check the manual of the projector or consult the manufacturer to ensure that you are handling the projector in the correct way. Regenerate response
1/26/2023 1:29:37 PM • Mitsubishi... • Answered on Jan 26, 2023
Mitsubishi WD - 65833 BLINKING GREEN LIGHT
A blinking green light on a Mitsubishi WD-65833 television can indicate that the television is in standby mode, and is trying to establish a connection with a signal source (such as a cable or satellite box).
  • First, make sure that the TV and the signal source (cable or satellite box) are turned on and properly connected.
  • Check that the cables are securely plugged in to the TV and the signal source.
  • Make sure that the TV is set to the correct input (e.g. HDMI1, HDMI2) to receive the signal from the cable or satellite box.
  • Try unplugging the TV and cable/satellite box for a few minutes, then plugging them back in to reset the connection.
If the green light continues to blink, and you have tried the above steps, it is possible that the problem is with the TV's internal hardware or software. In this case, you may need to have the TV serviced or repaired by a professional. It is also important to check the TV's manual or the manufacturer's website for troubleshooting information specific to your model. Please note that the reason of the blinking light can vary depending on the TV model and the specific issue.
1/23/2023 9:22:06 AM • Mitsubishi... • Answered on Jan 23, 2023
Fan noise running when tv is on
Mitsubishi rear projection DLP keeps turning off and shutting down. The red light then turns on for a while and then turns off. TV can be turned on again and works fine until a random shutdown occurs again. No fault codes are stored. No blink codes. No airflow warning messages. The original thermal sensor was replaced 8-1/2 years ago. Fans are completely clean and running smoothly. I fixed this problem by replacing the 8.5-year-old thermal sensor. The problem is gone. Mitsubishi thermal sensor part number 299P313010A. Manufacturer part number YS11A95B-C6. Do not use the connector plug. Strip the wires, and hard wire and solder the 2 connections. This might also apply to these models: WD-52631, WD-57731, WD-57732, WD-65732, WD-57831, WD-65831, WD-Y57, WD-Y65
1/11/2023 8:53:49 AM • Mitsubishi... • Answered on Jan 11, 2023
My Mitsubishi 55" model LT-55164. Turn on and after 20mins or so the picture shuts down but still have sound. Changed the inverter but didn't help. Any idea what might be the problem.
Take the board out and use your heat gun to heat the board. Look for any loose connections and resolder if needed. I see why you when with inverter replacement. It sounds like a board issue.
1/7/2023 1:03:15 AM • Mitsubishi... • Answered on Jan 07, 2023
Mitsubishi WD65638 staus light blinking orange constantly
Not sure what it is. Mine is blinking like that as well
12/1/2022 4:40:50 PM • Mitsubishi... • Answered on Dec 01, 2022
MITSUBISHI WD 65735 replaced lamp, turns on for a few minutes then shuts off and lamp light indicator is now solid red
Hello, one of the fans are bad or just clogged up, but only vacuum them off, NEVER blow them out, you'll wind up with dust bunnies in your optics causing blurry spots on your screen. Thanks Techman 57
10/21/2022 5:33:44 AM • Mitsubishi... • Answered on Oct 21, 2022
Mitsubishi WD-73838 fan makes grinding noise Mitsubishi WD-73838 Projection TV
all PC and TV and projectors all those have fans. for sure thing that run faster, than say notepad and yours does fan all fans suck in piles of lint learn to clean it or have shop do it. if ignored the fan jams up with lint, and stalls or makes noise (bad) and stalls. all things with a fan does that. and causes overheating damage that wrecks all elecronics with fans. it needs service do get serviced or rear the service manual or learn to clean it your self. that was 3 answer, YOU CALL
9/19/2022 4:58:54 AM • Mitsubishi... • Answered on Sep 19, 2022
2answers
Mitsubishi WD-73835 Projection TV. How to get rid of a dark shadow across the entire top of the screen.
Question edited for clarity. Question moved from Cars and Trucks category. See the fixes in the link https://www.google.com/search?q=Mitsubishi+73835%2C+dark+shadow+across+the+entire+top+of+the+screen ..
9/19/2022 4:58:08 AM • Mitsubishi... • Answered on Sep 19, 2022
I need a universal remote for my Mitsubishi tv
No you don't, you need a remote that is made for the television you have, not a universal. Nobody buys those any more. This tip I wrote explains and tells you where to buy. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote https://www.google.com/search?q=mitsubishi+tv+remote+control ..
7/28/2022 9:18:48 PM • Mitsubishi... • Answered on Jul 28, 2022
60 inch mitsubishi tv model number LT55265 power light keeps flashing and tv doesn,t come on
This link might help. https://techlore.com/article/mitsubishi-blinking-green-light-repair-procedure
7/14/2022 1:09:28 AM • Mitsubishi... • Answered on Jul 14, 2022
Televison & Video Logo
8 questions posted
Top Mitsubishi Televison & Video Experts
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
need hv flyback transformer convergence
  • Televison & Video
