20 Most Recent Mitsubishi VS-6041 60" Rear Projection Television Questions & Answers
This is an older projection TV & I am unable to locate the parts for it, best bet may be to search craig's list for someone locally trying to get rid of one that may have a good screen
Mitsubishi... | Answered on Jun 05, 2014
based on the model number its a older set, bad solder connections are most likely here.
Mitsubishi... | Answered on Dec 23, 2012
Model listed here is rather old so first suspect would be bad solder connections on power board or elsewhere. Some of these are also prone to Glycol issues, coolant from the picture tubes leaks and gets onto a board and causes failures of almost any kind depending where it leaks.
Mitsubishi... | Answered on Dec 17, 2012
A very common problem in older Mitsubishi sets is bad solder connections develop.
If bumping or jarring brings back picture you are going to have to get the entire chassis loose----it involves getting the chassis unbolted from cabinet, releasing some bundled wires and lifting chassis up so bottom is facing rear of set.
Then you take a good look in power supply and other areas for any "ringed" connections: connections that are cracked loose and not soldered solidly.
The hard part is getting the chassis loose; usually in this case I find four or more loose, or poor connections.
What happens is from age the board expands and contracts and some parts that produce more heat crack/break loose solder connections.
Let me know if you have questions.
Steve
Mitsubishi... | Answered on Mar 01, 2012
You dont have a bulb, since that model is a CRT projection you have three CRTs ( Picture tubes) instead of a single lamp like the DLP projections have.
Mitsubishi... | Answered on Dec 03, 2011
You may attempt a B+ replacement. This controls the high frequency voltage that powers all the RGB tubes needed for picture. The B+ flyback looks like this:
Best of luck! Thank you
Mitsubishi... | Answered on May 27, 2011
Try going to mcmelectronics.com they are a mitsi parts dealer
Mitsubishi... | Answered on Jan 08, 2011
Hello.
I would not recommend you to touch the mirror. It is hanged sort of reflection surface facing down so it is not real dust collector. You can clean lenses of your CRT tubes (red, green and blue) to improve your picture. Just remove rear cover taking out black and golden screws and you will see dusty lenses right away in the middle of the TV. Use DRY "Bounty" paper towels to remove dust from lenses, don't wet it with any solutions or it will leave film on optics. Just in circular motion move dust to the black plastic edges of lenses. Don't worry about some specs of dust that inevitable will be left behind - they will not affect image at all like thick layer of dust do.
Regards.
Russ.
Mitsubishi... | Answered on Dec 01, 2010
input controls in front or side of TV
Mitsubishi... | Answered on Jun 04, 2010
Try adjusting the sharpness in your TV's menu. If it's not just that, then perhaps the tube/LCD display is simply degrading.
Mitsubishi... | Answered on Jun 03, 2010
These are NO Longer available with Mitsubishi or any other Vendor. The only way my client was able to get this, he buy a Dump TV from Craiglist and used the Fresnel, Lenticular Screen from there.
Unfortunately, there is no Substitutes as well.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mitsubishi... | Answered on May 12, 2010
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
Ed
NC Electronic
Mills, Wyoming
Mitsubishi... | Answered on Dec 17, 2009
the convergance amps have gone bad you need to have somone replace them alot with the 2 bad resistors that will be burnt
Mitsubishi... | Answered on Nov 19, 2009
If you have a Mitsubishi remote or the one that came with the TV, you can try the following.
Try using the video up and down button on the remote until you get to close caption, then turn it off. I know it is a strange place to put the CC portion of the menu, but that is what Mits did.
I hope that this helps you with this issue.
Thanks for usning Fixya.
asnowman
Mitsubishi... | Answered on Oct 19, 2009
It depends on the make and model. Usually the bulb is located on the bottom half of the TV. It is most likely located in the back or side of the TV but different models sometimes have it hidden in the front behind a covering. Look for a small door usually about 6 inch by 8 inch with a couple of screws holding it closed. You usually will need to unscrew 1-2 screws to open the lamp door for bulb. This information is ALWAYS available in the owner's manual with step by step directions for your particular model. If you no longer have the manual, they are usually available for download on the manufacture's website for free.
Mitsubishi... | Answered on Oct 05, 2009
it sounds like your speakers might be fried or just the wire loose or fried.
Mitsubishi... | Answered on Sep 27, 2009
Televison & Video Logo
59 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
get in safely clean mirror
  • Televison & Video
