20 Most Recent Mitsubishi VS-55601 55" Rear Projection Television Questions & Answers
Cerved lines in the top and bottom of the red screen.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts///
10/30/2017 3:28:48 PM • Mitsubishi... • Answered on Oct 30, 2017
Mitsubishi vs-55601 55 inch tv
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
3/11/2017 2:50:04 AM • Mitsubishi... • Answered on Mar 11, 2017
Need a replacement bulb for my mitsubishi vs-55601
Hi,a spares supplier should be able to help you , just do a wed search from either google or bing, for a Mitsubish spares supplier in your area
6/8/2015 3:17:06 AM • Mitsubishi... • Answered on Jun 08, 2015
Light white lines on some channels
Possible convergence problem. Find honest TV tech.
11/14/2013 7:42:59 AM • Mitsubishi... • Answered on Nov 14, 2013
Picture is coming up as 3D
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
5/9/2011 1:54:14 AM • Mitsubishi... • Answered on May 09, 2011
Picture looks concave and 3D. The convergence is
  • Screen looks 3D
69189a5.pngSOLUTION
69189a5.pngSOLUTION
5/9/2011 1:51:22 AM • Mitsubishi... • Answered on May 09, 2011
My DM board is
Mitsubishi does not make it a available nor do they offer a rebuild on this. My only thought would be is to try PTS. It is a company thet referbishes boards for various manufactures. You also could try ebay. I wish you luck,
Skyassoc
12/8/2010 5:42:36 AM • Mitsubishi... • Answered on Dec 08, 2010
How to fix a mitsubishi vs 55601 convergence
hello, the reason for this is down to the convergance ic 2 large chips connected to metal frame called heatsink they usually located behind the tuner board, also there are some resistors in front chips and capacitor at either end these will need to be tested as well. hope it helps.
regards
shaun
10/19/2010 1:08:27 PM • Mitsubishi... • Answered on Oct 19, 2010
My Mitsubishi projection TV model#
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs tobe replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime.
There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
8/21/2010 8:49:02 PM • Mitsubishi... • Answered on Aug 21, 2010
When i turn it on it only stays on for about 3
Disconnect CRT Board that plugs on that tube and turn TV on, if it stays on then tube is defective
7/3/2010 9:09:10 AM • Mitsubishi... • Answered on Jul 03, 2010
Bowed screen left side top to bottom probably 1
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
6/6/2010 5:00:34 AM • Mitsubishi... • Answered on Jun 06, 2010
Wavy lines on Mitsubishi ws-a55
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
5/7/2010 6:26:49 AM • Mitsubishi... • Answered on May 07, 2010
Picture has color separation and halos. Picture distorted.
Your convergence is bad and you need to replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
4/27/2010 1:26:53 AM • Mitsubishi... • Answered on Apr 27, 2010
When you turn on tv the green power light comes on
bad power board
4/24/2010 5:10:28 AM • Mitsubishi... • Answered on Apr 24, 2010
I can't converge the colors on my 55
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. Your symptom sounds like a damaged convergence IC.
If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, heat sink compound, and some basic soldering skills, you can repair the television yourself.
*** VERY IMPORTANT NOTE***
If your set is not producing a clear picture and the colors are not lining up, do not continue to watch the set as this can lead to further failure and possibly damage the individual CRT’s in the set.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
How do I tell if the IC’s are damaged?
Since you cannot look inside of an IC, you will have to locate some of the components in the area around the convergence IC’s. You may be able to see some resistors that have changed colors or you test a resistor and it no longer reads the value marked by the color bands or the printed value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulator for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
4/3/2010 4:12:30 AM • Mitsubishi... • Answered on Apr 03, 2010
POWER BUT NO TV
needs software upgrade.
1/5/2010 6:25:31 AM • Mitsubishi... • Answered on Jan 05, 2010
Mitsubishi big screen with dlp technology 2001
Must replaced the coolant,ur tv coolant it running out.
12/25/2009 5:11:26 AM • Mitsubishi... • Answered on Dec 25, 2009
Mitsubishi vs 55601 picture has gone out. It was
I have found several of the vertical deflection caps to be off value as well as the vertical chip to be defective.First after pulling the chassis (mark plugs and sockets that have no id numbers with a mark a lot) look with magnifier around vertical and hi section for circuit board cracks that need resoldered.Hope this helps.
Technition
11/24/2009 6:46:01 PM • Mitsubishi... • Answered on Nov 24, 2009
I have a convergence problem on my Mitsubishi VS-55601
ICS with some resisters,tries these websites Tv rpair Word.com or Tv repair kits.
11/17/2009 8:41:17 AM • Mitsubishi... • Answered on Nov 17, 2009
Mitsubishi TV VS-55601S Convergence Problem
Convergence it dead.Must replaced convergence,know how to solders?Tries these websites for convergence kit.Tv repair World.com,or Tv Repair Kits.
11/17/2009 8:35:51 AM • Mitsubishi... • Answered on Nov 17, 2009
Televison & Video Logo
43 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi projection tv model
  • Televison & Video
