20 Most Recent Yard Machines MTD Gold 20 HP Lawn Tractor 13AL795T004 Questions & Answers
you need to jack up the mower get someone to help you and see if there is something lodged in the mower .
Yard Machines... | Answered on Dec 05, 2017
If it is Briggs & Stratton powered, your valve clearances are in dire need of adjustment. Sounds like a silly answer, but will almost certainly solve your problem.
Yard Machines... | Answered on Oct 25, 2017
you should take a picture of how the belt is on there now so you will know how to put it back on. check to see if the blades will spin freely with it not running of course. put your hand under it and spin the blade. if they don't spin you may have something wrapped around the spindles causing the blades not to spin causing the belt to smoke. if the belt is cracked or missing any chunks you may want to replace it. take a picture so you will remember how it goes back on.
Yard Machines... | Answered on Sep 20, 2017
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Yard Machines... | Answered on Jun 07, 2014
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
Yard Machines... | Answered on May 17, 2014
Are you asking how to reset governor linkage to factory spec? If so, move governor arm in direction that opens throttle valve on carb wide open. Hold in this position. Loosen small nut on bottom of governor arm. With a needle nose pliers turn center arm that goes into engine in the same direction you turned governor arm to open throttle valve. Holding in position, now tighten nut on governor arm tight again. This is referred to as a static setting and is factory spec. Good luck!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Yard Machines... | Answered on Oct 05, 2013
sounds like rust build up on the magnet flywheel remove the cover from the top of the engine and clean it
Yard Machines... | Answered on Aug 11, 2012
sound like its stuck to the axle when that happens to me i just change the tire on the mower and leave the wheel on the axle
Yard Machines... | Answered on May 01, 2012
Hi Richard,
I see I am late responding to this but I now live overseas and it is 6 am here. I note you have already taken the unit in for repair.
I ws just trying to sort out which spring and clip had departed from your mower knowing the original problem was that the baldes would not engage.
I think but am not positive that your talking about the spring that is item 26 this link:
http://www.partstree.com/parts/?lc=mtd&mn=13AL795T004+%282010%29&dn=769054030013
The clip maybe item 60????
You can look at other diagrams for your mower on this page:
http://www.partstree.com/parts/?lc=mtd&mn=13AL795T004+%282010%29 I looked at the PTO drive but did not see the spring or clip.
When you get it back from the shop could you respond post the location that they installed the spring and clip? Just has the curiousity factor way up here. Per your model number this mower is a 2010 unit and hopefully the problem you had is not one that will keep repeating for other owners.
Thanks and take care,
Kelly
Yard Machines... | Answered on Aug 12, 2011
Could be failing ignition module or needs valve lash adjustment... periodic requirement for BS OHV engines.
Yard Machines... | Answered on Oct 27, 2019
First check the safety switch under seat is working by bridging the gap.
Try the same with the safety switch on hand brake.
Check fuse hasn't blown.
Check spark plug is intact and cable is correctly fitted.
Check in line fuel filter.
Ensure battery is fully charged, a drop in output will result in not starting.
Hope this resolves the problem.
Gareth
Yard Machines... | Answered on Sep 01, 2019
there should be a place right below the spool to either put a screwdriver or a wrench in and you will turn the spool like a nut to get it off
Yard Machines... | Answered on May 27, 2019
There may be a manual showing the wires at this web site.
I FOUND THIS WEB SITE that I think will help you with this question and a lot more. Since this web site will have access to many different vehicles I hope you do not feel like I am lazy by just passing along the web site instead of giving you the exact information you asked for.
Go to this site to find a manual to help you.
https://www.browsemanuals.co/lander_zrk65_test14.html?t1=1535071160&t2=65192170713&t3=kwd-28425796&gclid=EAIaIQobChMI-oybpN624AIVwdVkCh2GtguWEAEYASAAEgJ9yvD_BwE
Yard Machines... | Answered on Feb 22, 2019
Parts Tree Repair Clinic may have a video
Yard Machines... | Answered on Feb 09, 2018
Yard Machines MTD Gold 20 HP Lawn Tractor  13AL795T004 Logo
Popular Tags
19 questions posted
Top Yard Machines Garden Experts
dannydoesita
john h
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Yard Machines Garden
Most Popular Question
mtd yard machine blade stopped engaging
  • Garden
