20 Most Recent Mitsubishi VS-50805 50" Rear Projection Television Questions & Answers
In general two possible reasons--sets of this age often develop bad solder connections on the boards--normal with age, heat and expansion and contraction of the the boards.You can also have a issue where some Glycol has leaked from one of the tubes onto the circuit boards under them--I can tell you where to look and what to look for if you do not know.
Mitsubishi... • Answered on Jun 16, 2012
Hi Daniel,Please check if you can access the "error code operational check" to narrow down where the fault came from.How to enter to error code operational check.Note : The TV must be in shutdown and not have been switched off. When the TV is switched off, the error code automatically resets to 12 (no error).Press the buttons on the front panel "Input/Device" and "Menu" at the same time and hold it for 5 sec, activate the error code mode. The LED light will flashes denoting a two digit error code.Example : if the error code is 22, the led will flash two times pause and then flash two times and will repeat the error code for five times. If you can't access the error code operational check , please let me know the exact pattern of the flashes of the led light and its color. Check if it will continually flashes green to give you the caused of the symptoms and best solution.Good luck and take care.
Mitsubishi... • Answered on Dec 11, 2011
Hi astump,
Welcome to FixYa.
My name is John.
I will be assisting you with you issue.
It,s time to replace your CONVERGENCE IC,s.
If you can solder, and have a good steady hand, and can be guided,
you can land this job. Post back if you want to do this and I
will let you know what tools and step are needed.
Thanks for choosing FixYa.
John
Mitsubishi... • Answered on Jan 06, 2011
You may have a bad ground on your vertical IC to begin with! Other repairs would include a bad ground on a coil or the horizontal transformer. The biggest problem is, Yes you have some bad grounds. Repair will be, to find the cracked rings underneath the boards and resolder. Take this note to your local TV Tech, this is your best defense in keeping the the repair cost down! Knowledge, in this case, is on your side now. Good Luck in your search!
Mitsubishi... • Answered on Jul 03, 2010
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
Mitsubishi... • Answered on May 19, 2010
Look under Audio on your menu ,find SAP and turn OFF
Mitsubishi... • Answered on May 05, 2010
Hi
Thanks for using FixYa. You’ll need to reset the Projection TV and to reset it follow these steps:
  1. Turn off the television and wait for 5 minutes.
2. After 5 minutes unplug the television power cord from the electrical outlet.
3. Let the television remain without power for more then 1 minute.
4. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the television.
If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board of your TV. You should try and turn off the TV for 8-10 hours to reset it. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mitsubishi... • Answered on Feb 12, 2010
just replace converg.IC(2pc).
Mitsubishi... • Answered on Jan 31, 2010
the problem with this unit is in the convergence ic's need to replace and check for bad resistors and pico fuses in the circuit
Mitsubishi... • Answered on Jan 25, 2010
Flyback is necessary part of CRT based rear projection TVs that generates high voltage for picture tubes and low voltages for other circuits in TV.
Click HERE to see an image of flyback transformer, just for reference.
Since TV is an old model so spare parts would not be available.
Thanks.
Mitsubishi... • Answered on Dec 01, 2009
VS 50801 and VS 60801 mitsubishi2.gif models (I have one each) have both had this problem develop after about 10 years of service. The picture simply started "Blinking" off after collapsing to a horizontal line - audio was still present. A simple fix to this problem is to space the yoke connector (7-pin white "Molex-type") away from the neck of the CRT (~1/8 ") . I used a plastic insulator. My 60" set had a problem with the center CRT (green) connector and thye 50" set had the same problem on the connector on the Left (red) yoke connector. The TV senses an open yoke circuit and shuts down all deflection drive. I only want a few more years of service from these sets, otherwise I would resolder the connector on the PCB for a correct and permanent solution.
Mitsubishi... • Answered on Oct 23, 2009
Leaky electrolytics around the vertical drive circuitry and/or on the powersupply B+
Mitsubishi... • Answered on Mar 27, 2009
Might try MCM Electronics. 1-800-543-4330. www.mcmelectronics.com
Mitsubishi... • Answered on Mar 26, 2009
Replace both STKs covergence chips 392-56or 570s use same STK numbers.
Mitsubishi... • Answered on Dec 12, 2008
try to clean all reflection glass at the back of the projector
where is the tube located?
Mitsubishi... • Answered on Oct 24, 2008
Mitsubishi VS-50805 50" Rear Projection Television Logo
Popular Tags
31 questions posted
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
vs 50805 turns off when wants as long as
  • Televison & Video
