20 Most Recent Toro Z Master Zero Turn Riding Lawn Mower 19 Hp 34" Cut Questions & Answers
What is the part called that goes on top of the pulley were the belt goes through
Is it a drive belt or on the deck? I helped a friend of mine replace the drive belt tension spring on his. It was located just above the drive pully. Was a very stout spring. Used a brake spring tool and it popped right on. Is this the same thing you are talking about? the L shaped piece with a belt tensioner on it? If not, I will get back on here later and try to help. Thanks.
6/12/2015 1:36:42 AM • Toro Z Master... • Answered on Jun 12, 2015
What is the valve settings on a 19 HP KAWASAKI engine
which model kawasaki engine?
5/12/2015 7:17:28 PM • Toro Z Master... • Answered on May 12, 2015
I have a oil leak under the oil filter
try tightenig the oil filter a little that will stop small filter leaks
7/19/2014 10:19:10 AM • Toro Z Master... • Answered on Jul 19, 2014
2answers
My toro 74411 seems like is notpumping enough gas cause when i engage the pto looses all power
Hione thing to try sstart up ngine le it warm up and get a screw diver and turn the mix screw on the carb 1/4 turn out and try that engage PTO if nothing turn another 1/4 if nothing turn engine of and turn mixure sew all the way in very easy dont force it just when it stops turn 1 and 1/4 turn to 1and 1/2 out now start it and try pto if its still slowing down turn another 1/4 turn out now if that didnt work just make sure you have a clean air filter and fuel filter and spark plug before you do any of the above then u will need carb rebuilt please use fresh gas otherwise you will very low powerJoeJoe
7/19/2014 10:16:51 AM • Toro Z Master... • Answered on Jul 19, 2014
0answers
What is the valve ajustment on a 19 hp, toro motor
Here is a table with the small Kawasaki engines listed. I hope this helps.
http://outdoorpowerinfo.com/engine_specs/kawasaki_valve_gaps.asp
6/12/2011 11:30:56 PM • Toro Z Master... • Answered on Jun 12, 2011
0answers
Year of my machine ser# 993007
Does it have a B&S motor? If it does, look on the back side of the cover (above the spark plug) or the opposite side of the carb. and you should see " Model, Type, and Code" and some numbers underneath them. Look under "Code", the first two digits is the year of the motor. For example, "01" means it was made in 2001. Thats if its the original motor that was made for that machine, thats the year of your machine. If its not an B&S, call your local Toro dealer and they can tell you.
7/10/2010 3:40:55 PM • Toro Z Master... • Answered on Jul 10, 2010
2answers
Toro CCR 2450 Snowblower has new plug & gas but will only start with added starter fluid then will run until trying to start again.
Question edited for clarity. When you put it away at the end of last snow season, I expect you just rolled it to the corner of the garage and left it until now? The two stroke gas in the carburetor, went bad and gummy. It starts on starter fluid because no gas is coming from the carb. https://www.google.com/search?q=toro+ccr+2450+carburetor+cleaning ..
1/20/2024 9:51:29 AM • Toro Garden • Answered on Jan 20, 2024
We have a Toro Powervac that will not start. Vac has a new carburetor, new engine coil, new fuel lines, new spark plug and still will not start. Any suggestions?
did you make sure it has spark. i have learned over the years because an electronic is new doesn't mean its good? If it has spark remove the plug and put a bit of gas in the hole and re install plug see if it will fire on that gas. if it does its the carb something is probably blocking fuel. check the compression if its low compression it will not run. if u dont have a compression checker just remove the plug stick your finger tight over the plug hole and pull it over it should blow your finger off the hole.
9/17/2023 6:54:34 AM • Toro Garden • Answered on Sep 17, 2023
Hi, I would like to know what is the typical compression value of a Kohler 16HP singel cylinder engine?
Yes, decompression lowers cylinder pressure during low rpm while cranking. If you're concerned with compression, you need to do a leakdown test. Inexpensive (~$30) units are available through numerous eVendors. The leakdown test provides a metered volume of air that is translated and displayed on a pressure gauge simply labeled high (excessive leakage), moderate, or low (nominal leakage).
It's an L-head engine and once they get a few hundred hours run time, the valves wear into the hard seat, lash goes to zero, and they become hard to start. You can check valve lash by removing the crankcase breather (two screws). If lash is near zero, time for a valve job. Plenty of how to videos on the web. If it's easy start, just low power then less likely a valve lash issue.
There are many things that cause low power. Bad fuel, water in fuel (fuel bowl), fouled carburetor, poor spark, fouled plug, improper plug gap, wrong plug, weak ignition module.
9/12/2023 10:24:23 AM • Toro Garden • Answered on Sep 12, 2023
Toro riding mower stopped moving
If you have no forward, no reverse but the motor is still running normally the most likely reason for this is the main drive belt. This connects the motor to the transmission. If it stretches, breaks or drops off the drive pulleys you will lose all movement.
8/21/2023 3:49:43 PM • Toro Garden • Answered on Aug 21, 2023
Why does my Toro Titan HD 2000 series 74467 blow a fuse every time I engage The blade?
My thought is the seat safety switch is faulty, because normally these mowers won't work unless someone is sitting in the seat when if goes into the blade drive. There are other ideas in the videos. Frayed wires in the harness somewhere?
4/29/2023 6:19:25 PM • Toro Garden • Answered on Apr 29, 2023
Toro Z Master Zero Turn Riding Lawn Mower 19 Hp 34" Cut Logo
18 questions posted
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
part called goes top pulley belt goes
  • Garden
