20 Most Recent Mitsubishi WS-73411 73" Rear Projection Television Questions & Answers
bad stk 392-120 or 110
Mitsubishi... • Answered on Nov 21, 2013
The next time it shuts down (I presume the green power light goes off) do the self check this model has, on front of set press and hold both the menu and input buttons for at least five seconds and release both.
Power light will blink a 2 digit error code like : 1 blink, 2 blink and repeat it several times.
1,2 is no error detected but there are other codes.
Let me know what you find.
SD TECH
Mitsubishi... • Answered on Jan 13, 2013
Hi, this is a very common problem with this set, what is happening is that there is a "Fault" so severe that if the unit was left powered on, there may be an fire, and explosion or both, as some component(s) are faulty and the PSU, is "Sensing" this and it shuts down the set, for safety reasons. The reason it was intermittent before is usually the component is failing sue to heat stress, and once it cooled down, the set would work again, however NOW this component(s) has faulted completely, and thus the fault is what we call "Hard ON" subsequently the PSU will NOT allow operation for the reasons discussed before.
If you wish to DIY, please find your service and repair manual below. Inside the manual you will find all the necessary troubleshooting steps to try to isolate and effect a repair,however i must warn you that this set is particularly hard to service, and it is my professional advice that you have the matter attended to by a professional.
I advise contacting a local or head office of Mitsubishi and ask for a referral to an authorised service center, here you should ask for a "Quote" before allowing any repairs to be undertaken.
http://www.service-manual.eu/model.php?id=2752
Below is a training manual this is what I use to train the engineers to troubleshoot and repair and understand how it all works .. this will help you understand whats going on.
www.scribd.com/doc/17849622/V23-Training-Manual
Mitsubishi... • Answered on Aug 25, 2010
Hello, asnowman here.
I had to reply to this post, as the other would not let me.
Your question:
Comment posted on Oct 26, 2009 Thank you for your help, do you know what board this is on? signal, main, or power? Your televsion is the 73411, and I think that your convergence IC's are on the center board, (called the power board, even though it doesn't have the flyback on it), if they are not they are on the signal board. You can't miss them they are attached to a very large aluminum heat sink and the IC's are very large as well. I hope that this answers your questions. If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Mitsubishi... • Answered on Oct 26, 2009
press 9 and qv buttons on remote at the same time.
Mitsubishi... • Answered on Oct 13, 2009
If you try ctechnicians.com this will give technical answers
Mitsubishi... • Answered on Dec 28, 2007
have you got the slider switch at high definition and not TV at the connecting end at the xbox that leads to the tv input
Mitsubishi... • Answered on May 21, 2007
If the screen is black it is broken, that is why you got it for nothing. You saved the person the disposal fee. https://www.fixya.com/support/r29790007-repairing_own_television It is a DLP projection television, a veritable antique of old technology that has projection bulbs that need changing once a year. I would suggest that your bulb has probably failed. They are $30 to $52 each! https://www.google.com/search?q=Mitsubishi+1080+medalion+hd+manual .. ..
Mitsubishi... • Answered on May 12, 2021
Antique technology! :>) It maybe that the guard around the fan is catching the fan blade. The only thing you can do is strip it down. It maybe something vibrating because it is loose and needs tightenening. Or you could just buy an 86" Ultra HD Flat screen :>D
Mitsubishi... • Answered on Apr 20, 2021
Request or order the manual from Mitsubishi.
Mitsubishi... • Answered on Apr 16, 2021
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/
Mitsubishi... • Answered on Feb 26, 2021
You have to enter its service menu to reset the lamp time. 1. Enter the Option Menu <MENU><2-4-7-0> 2. V43C & V43 Chassis select "2. Reset All Settings" and <ENTER>. Then confirm "YES" <ENTER>.. V43+ & V43++ Chassis select "Initialize" and <ENTER>. If you wish to get some details; check the site linked here. Pull up older posts or search the site by type in the brand name of your set, at its search box at the right column.. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/
Mitsubishi... • Answered on Feb 19, 2021
Mitsubishi WS-73411 73" Rear Projection Television Logo
15 questions posted
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
owners manual
  • Televison & Video
