20 Most Recent Mitsubishi VS-60111 60" Rear Projection Television Questions & Answers
Hello, my Mitsubishi TV (WS
More than likely the power relay is sticking.
5/3/2017 7:20:53 PM • Mitsubishi... • Answered on May 03, 2017
How to change from 480i to 1080i
Which input on the tv did you use?
4/18/2014 4:56:08 AM • Mitsubishi... • Answered on Apr 18, 2014
Tv mitsubishi vs-60111
Was there a power failure? unplug unit for a min and plug it back in. hold power button til unit turns on. If it still flashes you may have a power supply problem inside the unit.
4/8/2014 1:03:49 AM • Mitsubishi... • Answered on Apr 08, 2014
0answers
0answers
Have to hit the on button several times before it
tried to check the power on button with a analog tester weather the resistance doesn't have good contact. otherwise you must replace it.
9/24/2013 1:29:59 AM • Mitsubishi... • Answered on Sep 24, 2013
0answers
Error code 21
Be the first to answer 5/22/2013 1:30:44 AM • Mitsubishi... • Posted on May 22, 2013Be the first to answer
Some of my channels are only in spanish, some have no sound
Look first in the menu for the set and then in the menu for a box if used:In either place if set is set to SAP (secondary audio program) some channels will be in Spanish or have no sound.It can be the setting in the TV or a cable or sat box if used.
10/24/2012 4:04:03 PM • Mitsubishi... • Answered on Oct 24, 2012
Vs 60111 Fuzzy picture
Its a very old set and if happens on all inputs and cables have been ruled out something serious--the rear inputs bypass the tuner in the set and based on its age I would not suggest spending major money (if you can find someone willing to work on a set of this age) on this set.Many parts for this are no longer available.
8/31/2012 1:44:21 PM • Mitsubishi... • Answered on Aug 31, 2012
How do i get rid of purple horizontal distortion lines?
This is a older model and likely the first generation of HD set made by Mitsubishi---where the HD input is on rear (DTV?) ARE THERE TWO JACKS MARKED H sync and V sync?If they are there set needed an external box made only by Mitsubishi for for later HD use.
4/12/2012 4:41:13 PM • Mitsubishi... • Answered on Apr 12, 2012
How much does the fuse cost
A fuse can cost a few dollars; The question is what is your set doing or not doing, I have fixed and lot of the Mitsubishi sets,.
3/15/2012 12:57:29 PM • Mitsubishi... • Answered on Mar 15, 2012
2answers
Flashing Tv screen
Turned out to be a problem with my dish receiver. Found out by attaching a separate DVD unit to the TV, and it didn't flash. I then realized everything ran through the dish receiver. Called them, reset ( by unplugging for 90 seconds) and all was well.
11/14/2011 4:35:06 PM • Mitsubishi... • Answered on Nov 14, 2011
Mitsubishi VS-60111 60" Rear Projection Television Logo
69 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi big screen full sized hd 1080
  • Televison & Video
