20 Most Recent
Mitsubishi WT-46807 46" Rear Projection Television Questions & Answers
DT? I am becoming famous with these instructions--having done the repair hundreds of times and getting asked the same question here by many people I composed the step by step instructions.
Once you get the instructions all I would ask is you rate them with a vote on this question.
SD TECH
Mitsubishi...
Answered
on Nov 01, 2012
on the model indicated the front screen and frame are removed--mirror rarely needs cleaning but the lens below (3) usually do and those can be cleaned from rear or set with back cover removed.
Mitsubishi...
Answered
on May 14, 2012
what are you trying to tune?
Mitsubishi...
Answered
on May 14, 2012
Did you try the OPTION menu---think I offered that to you a few days ago......
Mitsubishi...
Answered
on Mar 28, 2012
is the screen green tinted or askew and 3 d looking?
Mitsubishi...
Answered
on Mar 19, 2012
yes!
When you turn set on and power light goes out do the self check this set has.
On front of set when light goes out press and hold both the Menu and Input (device) buttons at the same time and hold both for at least five seconds and then release both.
Power light will blink a two digit error code like 2 blinks,2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means. Make a comment here and I will assist you.
SD TECH
Mitsubishi...
Answered
on Jan 29, 2012
one blink pause and then 2 blinks is a "12" on error code list which means there's no error detected by the processor.
To double check the error code lets access the "Error code operational check". Follow the steps below.
Turn on the unit and then wait after the blinking led light stopped from flashing and then push the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds, activates the Error Code Mode. The LED flashes denoting a two digit Error Code. Example if the error code is "22", the led will blink 2 times pause and then blinks 2 times and repeat the cycle 5 times.
Please let me know the error code.
Jdvillanueva
Mitsubishi...
Answered
on Sep 08, 2011
Do
the self check this model has, when green power light comes on and then
goes out on the front of the set press and hold both the Menu and Input
(device) buttons at the same time for at least 5 seconds, then release
both buttons and watch the power light, It will blink a two digit code, a
error code.
Most common is 2 blinks, 2 blinks, a pause and then it will repeat the code several times.
Let me know what code you find and I will tell you what it means.
This is a self check meant to narrow down what kind of problem the set has.
Make a comment here so I can help.
SD TECH
Mitsubishi...
Answered
on Aug 13, 2011
There are no fuses going to the convergence board, the converegnce IC needs replaced.
Mitsubishi...
Answered
on Aug 08, 2011
2 blinks pause then 2 blinks is an error code for "Shorts Protect". Most of the shorted parts came from the power supply section (voltage regulator IC/transistor, Diode) and in the convergence circuitry (STK chips/IC). You must know how to test these parts for shorts to isolate it from the board. Pico fuses must be check for continuity even connected from the board using the multimeter.
If you found open fuse, trace this line, a shorted parts is connected across this line from the ground.
Another parts to be check is the fusible resistors(low resistance resistors) they act like a fuse also, cuts when shorts is in the circuitry to avoid further damaged.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified tv technician to troubleshoot the unit.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mitsubishi...
Answered
on Jun 15, 2011
have you done the reset on the fron on push buttons there is a small recessed buton marked reset try taking a tip of a pencil or pen and push it in gently to stop and release it and see if that wont reset it
Mitsubishi...
Answered
on Jun 05, 2011
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
- Screen looks 3D
- Colors don't line up
- One or more colors can't be adjusted when using the convergence menu.
- Screen is bowed or warped.
- TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
SOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mitsubishi...
Answered
on May 18, 2011
Either screw a coaxial cable from wall plate to tv, or install a cable box and use A/V cables from box to tv.
Mitsubishi...
Answered
on Feb 25, 2011
Please do the self check this set has:
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Mitsubishi...
Answered
on Jan 22, 2011
