20 Most Recent 2000 Chevy Astro - Cargo van, with factory roof rails - Base Rack System Questions & Answers
Just tighten the bolts down firm and equal don,t over tighten.
2000 Chevy Astro... | Answered on Nov 17, 2015
Hi,try doing a compression test to see if there is eny problem there
2000 Chevy Astro... | Answered on Nov 14, 2015
do you have to add coolant and is there a rear heater core in rear ??
Thule Vehicle... | Answered on Feb 09, 2015
Are the bolts seized or is there a release pin?
Thule Vehicle... | Answered on Sep 02, 2014
Are these factory acessories or another name brand?
Ronald, sometimes thing just don't happen like the book says so in times such as this I have been known to bring out the mig welder and fabricate a mount that will work and the modifications shouldn't be noticed from the topside of the vehicle. Be sure to use suitable materials 3/16th inch wall mild steel and that proper prep work and proper welding procedures are observed and you will have the box serve you well for years to come.
Thule Vehicle... | Answered on Jan 01, 2014
Demi,
The Loadcarrier 1061 is an older model and onl;ine data is hard to find, if there at all. To know more about the feet and fit kit, I recommend you call Thule Customer Support line at 800-238-2388 (Monday - Friday 8:30AM - 5:30PM EST).
Hope this helps. - RedRanger
Thule Vehicle... | Answered on Nov 16, 2013
Repost under RV for an answer
Thule Vehicle... | Answered on Jul 25, 2013
It is best to find an experienced veteran to replace the Mercedes alternator
Vehicle Parts &... | Answered on Oct 16, 2020
I don't have the same jump box but I have ran into the same problem is either gets charged in the garage or in the house that's best result for me anyway
Vehicle Parts &... | Answered on Oct 11, 2020
Jump starters with a lead acid battery are very similar to each other and many are generic label engineered imported items. The manual mostly covers the safe useage and operating procedures that are mostly intuitive - few people that know nothing about inflating tyres or jump starting a dead vehicle would own a jump starter...
Jump starters are mostly so similar the instruction booklet for one will serve for many others. There is really only a few things to remember - a battery can explode so if sparks have to be made make sure they are nowhere near the (vehicle) battery, observe the correct polarity (failure to do so can be very expensive) and top up charge your jump starter after each use and monthly regardless (leaving it in a discharged or semi-discharged state will quickly render it useless).
Vehicle Parts &... | Answered on Oct 10, 2020
Will any metal detector manual serve, or do you have a specific make and model in mind?
Vehicle Parts &... | Answered on Sep 15, 2020
I had a problem similar to that which you described the car would start fine then few seconds later it would cut out completely.
i changed the fuel pump, Fuel pump relay and still the problem was there and a a code of P0230 i cleaned the ECU connections which still didnt change anything so i put a jumper wire to bypass the fuel pump relay it got it to work fine.
With abit more digging and head scratching i opened up the ECU and found one wire broken.
I soldered it back in place and behold the car worked a dream no problem ever since.
I also removed the bypass which i put on the fuel pump relay and put the relay back.
Dont know if this would fix your problem but hopefully it would be of help.
Vehicle Parts &... | Answered on Jul 10, 2020
Yes, you should go for car wrap, it has many advantages like a high quality film will help you to prevent color fading, flying glass splinters during accidents and heat protection etc.
A nice Auto folie will enhance the appearance of your vehicle.
Vehicle Parts &... | Answered on Jun 09, 2020
you can purchase from:
https://www.amazon.com/Adapter-Charger
Vehicle Parts &... | Answered on May 29, 2020
https://help.compustar.com/s/article/How-Do-I-Exit-and-or-Enter-Valet-Mode
You can see this link.
Vehicle Parts &... | Answered on May 07, 2020
Suggest to do a patent search and review some diagrams. That will get you started.
Vehicle Parts &... | Answered on Feb 13, 2020
2000 Chevy Astro - Cargo van, with factory roof rails - Base Rack System Logo
2 questions posted
Top Thule Vehicle Parts & Accessories Experts
Nicola Conroy
Don Walper
Level 1 Expert
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Thule Vehicle Parts & Accessories
Most Popular Question
4 3 valve cover torque specs
  • Vehicle Parts & Accessories
