20 Most Recent Mitsubishi VS-5077/78 TV Questions & Answers
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
5/12/2017 10:03:27 PM • Mitsubishi... • Answered on May 12, 2017
Mitswubishi VS-5077 TV - Display would work and flicker to black screen. We would wait awhile try again.....picture would work and then flicker and go to black screen. Now black screen w/ only volu
The most common issue here in the old sets is bad solder connections--the problem is you have to get the entire chassis free and up so bottom of boards face rear of set---look to power supply---a lot of 2 and 3 lead parts there from heat come loose from the boards and also to the middle of the set on the middle board.If you are not able to attempt this the set is too old for a shop repair in my view as many parts for it are no longer available.
11/5/2012 4:32:31 PM • Mitsubishi... • Answered on Nov 05, 2012
No color
Confirm to me the brand and model number AND if you have not tried it=unplug the set for a while and then power up and see if that helps.
3/23/2012 8:01:14 PM • Mitsubishi... • Answered on Mar 23, 2012
I have a Mitsubishi VS-5077 the screen has gone
You definitely have bad solder grounds. I have repaired a few of these. You will need a TV tech pull the boards out and resolder them. The worst board would be the one on the left [signal board, has rca jacks. rf connector]. And they may as well solder the second board. You will have a restored TV when completed. Thanks for asking and show a few hands of support!
10/10/2010 2:33:48 PM • Mitsubishi... • Answered on Oct 10, 2010
2answers
TV turns on and then picture goes away after a
Your horizontal: (white vertical line shows on black screen) or, vertical:
(white horizontal line shows on black screen) power transistor is getting too hot. turn on TV untill the line shows then: remove power (unplug) from the tv, remove the TV back cover, find the too hot transistor; using coolant spray then, apply white coolant cream to the back of the too hot transistor or, chip. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix it.
4/6/2010 5:01:10 PM • Mitsubishi... • Answered on Apr 06, 2010
9answers
Mitsubishi vs-5077 picture turns off
here there  is a resistor by the high voltage transformer,it has low value and it opens for no reason,he is likely open and does not let the set stay on,if you are familiar with tv service you can replace it and while you are down there check for any over heated areas and resolder them specially the convergence IC.This resistor is located in the back edge of the chassis in the board in the right side and it might be hidden by a plastic casing that covers the high voltage transformer.If you are not too familiar with tv service you should seek the help of a servicer.
12/12/2008 12:38:51 PM • Mitsubishi... • Answered on Dec 12, 2008
Front freznel lens cracked
vancebaldwin.com
3/26/2008 6:57:23 PM • Mitsubishi... • Answered on Mar 26, 2008
Mitsubishi WD65638 staus light blinking orange constantly
Not sure what it is. Mine is blinking like that as well
12/1/2022 4:40:50 PM • Mitsubishi... • Answered on Dec 01, 2022
MITSUBISHI WD 65735 replaced lamp, turns on for a few minutes then shuts off and lamp light indicator is now solid red
Hello, one of the fans are bad or just clogged up, but only vacuum them off, NEVER blow them out, you'll wind up with dust bunnies in your optics causing blurry spots on your screen. Thanks Techman 57
10/21/2022 5:33:44 AM • Mitsubishi... • Answered on Oct 21, 2022
Mitsubishi WD-73838 fan makes grinding noise Mitsubishi WD-73838 Projection TV
all PC and TV and projectors all those have fans. for sure thing that run faster, than say notepad and yours does fan all fans suck in piles of lint learn to clean it or have shop do it. if ignored the fan jams up with lint, and stalls or makes noise (bad) and stalls. all things with a fan does that. and causes overheating damage that wrecks all elecronics with fans. it needs service do get serviced or rear the service manual or learn to clean it your self. that was 3 answer, YOU CALL
9/19/2022 4:58:54 AM • Mitsubishi... • Answered on Sep 19, 2022
2answers
Mitsubishi WD-73835 Projection TV. How to get rid of a dark shadow across the entire top of the screen.
Question edited for clarity. Question moved from Cars and Trucks category. See the fixes in the link https://www.google.com/search?q=Mitsubishi+73835%2C+dark+shadow+across+the+entire+top+of+the+screen ..
9/19/2022 4:58:08 AM • Mitsubishi... • Answered on Sep 19, 2022
I need a universal remote for my Mitsubishi tv
No you don't, you need a remote that is made for the television you have, not a universal. Nobody buys those any more. This tip I wrote explains and tells you where to buy. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote https://www.google.com/search?q=mitsubishi+tv+remote+control ..
7/28/2022 9:18:48 PM • Mitsubishi... • Answered on Jul 28, 2022
60 inch mitsubishi tv model number LT55265 power light keeps flashing and tv doesn,t come on
This link might help. https://techlore.com/article/mitsubishi-blinking-green-light-repair-procedure
7/14/2022 1:09:28 AM • Mitsubishi... • Answered on Jul 14, 2022
Mitsubishi TV not working.
Your TV is stopped working and it would be more cheaper to purchase a new TV than to try and repair the TV that is not working anymore.It could be the power supply inside of the TV is not working.
5/3/2022 7:08:37 AM • Mitsubishi... • Answered on May 03, 2022
Mitsubishi 83832 tv light constant green and wont come on
Maybe need new batt for remote ..try controls on set. Tv cud b worn out ...try unpluggnset for aspell n see if it reboots after a rest . Fixn it cudcost the same as new..n older tvs can hav manythings worn
5/3/2022 4:30:07 AM • Mitsubishi... • Answered on May 03, 2022
I don't have a remote control for my TV or DVD player. My TV is a sharp digital and my DVD player is a Mitsubishi player my screen is showing two images
try using buttons go to picture settings and turn off double screen
3/27/2022 6:04:24 AM • Mitsubishi... • Answered on Mar 27, 2022
How do I adjust picture with no remote?
you can google Mitsubishi wd60638 remote they are available for $10.00 on line
3/9/2022 8:23:03 PM • Mitsubishi... • Answered on Mar 09, 2022
Televison & Video Logo
11 questions posted
Top Mitsubishi Televison & Video Experts
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
tv works fine while picture disappears
  • Televison & Video
