20 Most Recent Mitsubishi CS-35505 35" TV Questions & Answers
It might depend on the type of input. VCR often use A/V or component cables. if you are using AV (red, white, yellow) make sure they are plugged into the right input. if plugging in to a component (white, red, green, blue, red) make sure the yellow plug goes into the green input. If plugging in component make sure your red wires are not backwards. There should be a white and red together (these are the audio) and a green blue red together (these are video)
Mitsubishi... • Answered on Sep 08, 2017
What are the dimensions.
Mitsubishi... • Answered on Oct 12, 2016
You should have a remote control for this purpose. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mitsubishi... • Answered on Feb 21, 2015
That means you blew your vertical output transistor. This likely happened because some electrolytic capacitors dried up and nneded replacing.
Mitsubishi... • Answered on Nov 26, 2013
Click here to know more.
Mitsubishi... • Answered on Apr 19, 2013
after 4 or 5 yrs ( depending on usage ) in some TVs on mainboard & crt tube's circuit board at few soldering joints cracks develops ...... then due to loose connection TV behaves as you said ..... so solution is most of the soldering joints on mainboard & crt tube's circuit board should be resoldered carefully ....that'all your TV will again works normally ......100% GUARANTEE
Mitsubishi... • Answered on Sep 01, 2011
first, do you know how to successfully hook up a DVD to a TV? It might be that you did not connect the DVD to TV correctly or the Video cable might be defective or failing.
Please crosscheck the below procedure on how to hook up a DVD player to a TV:
  • Check all the input ports located in back of the TV. It needs to have at least composite ports, which are the three round sockets colored yellow, white and red. It could also have an HDMI port (it looks like a small, stretched trapezoid) or component ports (similar to composite, but colored blue, green and red).
  • Disconnect the cable/satellite receiver from the TV only if it is using the TV input port you want to use for the DVD. If this box is connected through an RF coaxial cable (the thick black cable that is twisted into place), you don't need to disconnect it.
  • Connect the DVD player to the TV, using the best cable connection available. An HDMI cable will transmit the bast video/audio combination. If you can't use this, the composite cables (yellow, white, red) will also carry both video and audio. Component cables (blue, green, red) may give you the best video quality but won't transmit audio.
  • Connect a cable to the DVD and TV for audio if you connected the video with component cables. The simplest connection will be through composite audio cables. This means you only need a cable that has red and white plugs.
  • Attach your cable or satellite receiver to the DVD's input, if it has one. You should only need to do this if you are using a DVD recorder instead of just a player. If the DVD recorder has an RF coaxial port, use that. Otherwise, link the cable/satellite's output to the DVD's input through composite cables.
  • Reconnect your cable/satellite receiver to the TV if you had to disconnect it (Step 2) and did not connect it to the DVD's input (Step 5). Using the RF coaxial connection is your best option.
If reverse is the case, please let me know.
Good luck.
Mitsubishi... • Answered on Oct 20, 2010
Congratulations on your purchase! That's a nice TV, what specifically do you need help with. What kind of dish receiver are you using?
Mitsubishi... • Answered on Feb 06, 2010
Hi guzzman2,
I have the same exact TV as you and it has the same problem. I took the whole tv apart and checked the obvious things i.e. fuse, loose board, etc. etc. Bottom line - it looks like the flyback transformer needs replacment This is what provides the picture tube with power/voltage, etc. The part itself is ~200.00 and the labor will be about $150.00 - $200.00. Thats what you would pay if its only the transformer. Usually when the transformer goes, it takes other components along with it. I am bringing my set to the recycling center since It's not worth fixing. Went to Costco and bought a 42" LCD tv for less than 900.00. Instead of spending upwards of $300.00-400.00 to fix a 13 yr old standard tv, go for the gusto and upgrade to High Defination TV with the appropriate Cable company box and you'll never regret it!!!!
What a wake up call to watch TV now!!!!!!!!! Good luck to you...
Mitsubishi... • Answered on Jan 05, 2009
When pressing power switch the green LED blinks once,
Mitsubishi... • Answered on Oct 25, 2008
A LOT!!!! Takes two big people to move this dog around.
Mitsubishi... • Answered on Aug 01, 2008
What code are you talking about ( remote?) (service access?)(child lock?)
Mitsubishi... • Answered on Apr 04, 2008
i want to add my signature as action text and action picture of cartoon and also flowers and many more pictures.
Bharat Maheshwari
Mitsubishi... • Answered on Mar 13, 2008
It looks like the vertical amplifier IC401 is defective. If you have soldering/desoldering skills you can change this part yourself. Also you may have to change C471 (.01UF 50V).
Good Luck.
Mitsubishi... • Answered on Feb 11, 2008
You might be able to take care of it yourself,you are corret when you said no vertical sweep,if you can identify the vertical IC it will be easy,you are looking for loose conections but by now it might have a bad vertical Ic and it needs to be replaced along with the safety resistor that power the IC,the ic should be mounted on a heat sink and the resistor should have low resistance,very straight forward repair and while you are there make sure and check for overheated areas and loose conections specially in the power supply , horizontal drive circuit and convergence IC's.Be careful you still have high voltage witch can be dangerous.
Mitsubishi... • Answered on Jan 21, 2008
Televison & Video Logo
Popular Tags
30 questions posted
Top Mitsubishi Televison & Video Experts
Paul Bade
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
no picture or sound just three low beeps
  • Televison & Video
