20 Most Recent Mitsubishi CS-31205 TV Questions & Answers
2answers
Where is a manual for a mitsubishi CS-31205 tv?
The manual for Mitsubishi TV model CS-31205 can be found by clicking the link below (Although the link says "CS 31305" , other models such as CS-31205, CS- 31309, and CS-31304, will use this guide as well) Download Mitsubishi CS 31305 Owner Manual Available for download (and offline viewing) in PDF format with a very short registration, or bookmark in your browser, and utilize online. Or click below to visit the very useful website (the library is large, yet easy to use). ManualsLib Makes it easy to find manuals online (*just read this 2 year old question today- hope the OP found resolution)
10/15/2016 2:52:22 AM • Mitsubishi... • Answered on Oct 15, 2016
I need the code for unlock my tv, please help me
I think you mean the parental control lock. You can bypass this added feature, or disable it completely by following the instructions in the appendix (page 84) of the owners manual. You can find the manual by clicking the link below Download Mitsubishi CS 31305 Owner Manual (the guide is correct for your model number- its a catchall for other similar models) Hope that helps
9/30/2014 11:12:02 AM • Mitsubishi... • Answered on Sep 30, 2014
I got a Mitsubishi 1996 TV\r\nModel No. CS-31205
trun down your flyback that is lum.
6/24/2010 8:05:23 PM • Mitsubishi... • Answered on Jun 24, 2010
A black square takes up 90% of the screen
You need to turn off the TEXT Captioning. I had the same problem and that fixed it.
1/9/2010 6:30:48 PM • Mitsubishi... • Answered on Jan 09, 2010
The sound to the speakers
THERE IS A SWITCH IN THE BACK NEAR THE VIDEO INPUTS
12/28/2009 3:29:07 PM • Mitsubishi... • Answered on Dec 28, 2009
Where may I buyt a Mitsubishi CS-32105 TV Remote?
Online. Just type in Mitsubishi CS-32105 TV Remote on your browser and bingo, many sales locations will appear.
8/8/2009 5:01:45 PM • Mitsubishi... • Answered on Aug 08, 2009
2answers
Black box in the middle of the screen
The closed caption is turned on. I don't have the schematic in front of me, so, I will wing it. There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the service menu and you may have to search a bit. Either way it's an easy fix and you can do it yourself. If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
3/22/2009 7:25:27 PM • Mitsubishi... • Answered on Mar 22, 2009
I was just given a
your tv tuner is bad just take it out and resolder the tuner
1/11/2009 7:22:42 PM • Mitsubishi... • Answered on Jan 11, 2009
Keeps turning off
high volt or b volt going to high. reg circuit not working  normal to shut down need tech to repair.
12/1/2008 6:48:53 PM • Mitsubishi... • Answered on Dec 01, 2008
I have a mitsubishi wd 77731 tv and the screen turned completely white with white vertical lines. what happen?
If your Mitsubishi WD-77731 TV screen has turned completely white with white vertical lines, it is possible that there may be a fault in the display panel or the video processing circuitry of the TV. This could be caused by a variety of issues, including a faulty LCD driver board, a loose or damaged video cable, or a problem with the TV's power supply. Here are some troubleshooting steps you can try to determine the cause of the problem:
  1. Check the video input: Ensure that the video input to the TV is working properly by connecting a different video source, such as a DVD player or game console, to the TV.
  2. Check the video cables: Inspect the video cables that connect your video source to the TV for any damage or loose connections. If you find any damage, replace the cable.
  3. Power cycle the TV: Turn off the TV and unplug it from the power outlet for 1-2 minutes. Then, plug the TV back in and turn it on to see if the issue persists.
  4. Check for firmware updates: Check the Mitsubishi website to see if there are any available firmware updates for your TV. Updating the firmware may help to resolve any software-related issues.
If none of these steps resolve the issue, it is recommended that you contact a professional TV repair service to diagnose and fix the problem.
3/8/2023 11:50:05 AM • Mitsubishi... • Answered on Mar 08, 2023
I have a Mitsubishi TV model 73838, only getting black screen when turned on. Also replaced DLP ... getting red/ orange flashing light Changed lamb ad
If you have replaced the DLP lamp and are still experiencing a black screen, along with a flashing red/orange light, there are a few possible causes. One possible issue is with the color wheel. The color wheel is responsible for producing the colors on the screen, and if it malfunctions, it can cause the TV to display a black screen. Another possible issue could be with the ballast, which powers the lamp. If the ballast is malfunctioning, it can cause the TV to fail to turn on. It is also possible that there could be an issue with the power supply or the main board. In order to determine the cause of the issue, you may need to contact a professional technician who can diagnose and repair the TV. It is important to ensure that any repairs or replacements are done by a qualified technician to avoid any further damage to the TV.
2/23/2023 2:23:49 PM • Mitsubishi... • Answered on Feb 23, 2023
Loose wire coming from projector
It sounds like the wire you're describing is likely a connection wire for the audio component of your Mitsubishi 73838 projector. It's important to reconnect this wire properly in order to restore audio functionality to the projector. Here are some steps you can take to reconnect the wire:
  1. Identify the connector on the circuit board where the wire originally came from. This should be easy to spot as it will likely be the only empty connector in the area.
  2. Carefully reconnect the wire to the connector, making sure that the wire is securely connected and properly aligned.
  3. Check to make sure that the wire is not in contact with any other components on the circuit board, as this could cause a short circuit.
  4. Power on the projector and test the audio to see if the wire has been reconnected properly.
Please be cautious when handling the projector. It's best to be sure that the projector is unplugged and you have a static free environment. Also, be sure to check the manual of the projector or consult the manufacturer to ensure that you are handling the projector in the correct way. Regenerate response
1/26/2023 1:29:37 PM • Mitsubishi... • Answered on Jan 26, 2023
Mitsubishi WD - 65833 BLINKING GREEN LIGHT
A blinking green light on a Mitsubishi WD-65833 television can indicate that the television is in standby mode, and is trying to establish a connection with a signal source (such as a cable or satellite box).
  • First, make sure that the TV and the signal source (cable or satellite box) are turned on and properly connected.
  • Check that the cables are securely plugged in to the TV and the signal source.
  • Make sure that the TV is set to the correct input (e.g. HDMI1, HDMI2) to receive the signal from the cable or satellite box.
  • Try unplugging the TV and cable/satellite box for a few minutes, then plugging them back in to reset the connection.
If the green light continues to blink, and you have tried the above steps, it is possible that the problem is with the TV's internal hardware or software. In this case, you may need to have the TV serviced or repaired by a professional. It is also important to check the TV's manual or the manufacturer's website for troubleshooting information specific to your model. Please note that the reason of the blinking light can vary depending on the TV model and the specific issue.
1/23/2023 9:22:06 AM • Mitsubishi... • Answered on Jan 23, 2023
Fan noise running when tv is on
Mitsubishi rear projection DLP keeps turning off and shutting down. The red light then turns on for a while and then turns off. TV can be turned on again and works fine until a random shutdown occurs again. No fault codes are stored. No blink codes. No airflow warning messages. The original thermal sensor was replaced 8-1/2 years ago. Fans are completely clean and running smoothly. I fixed this problem by replacing the 8.5-year-old thermal sensor. The problem is gone. Mitsubishi thermal sensor part number 299P313010A. Manufacturer part number YS11A95B-C6. Do not use the connector plug. Strip the wires, and hard wire and solder the 2 connections. This might also apply to these models: WD-52631, WD-57731, WD-57732, WD-65732, WD-57831, WD-65831, WD-Y57, WD-Y65
1/11/2023 8:53:49 AM • Mitsubishi... • Answered on Jan 11, 2023
My Mitsubishi 55" model LT-55164. Turn on and after 20mins or so the picture shuts down but still have sound. Changed the inverter but didn't help. Any idea what might be the problem.
Take the board out and use your heat gun to heat the board. Look for any loose connections and resolder if needed. I see why you when with inverter replacement. It sounds like a board issue.
1/7/2023 1:03:15 AM • Mitsubishi... • Answered on Jan 07, 2023
Mitsubishi WD65638 staus light blinking orange constantly
Not sure what it is. Mine is blinking like that as well
12/1/2022 4:40:50 PM • Mitsubishi... • Answered on Dec 01, 2022
MITSUBISHI WD 65735 replaced lamp, turns on for a few minutes then shuts off and lamp light indicator is now solid red
Hello, one of the fans are bad or just clogged up, but only vacuum them off, NEVER blow them out, you'll wind up with dust bunnies in your optics causing blurry spots on your screen. Thanks Techman 57
10/21/2022 5:33:44 AM • Mitsubishi... • Answered on Oct 21, 2022
Televison & Video Logo
11 questions posted
Top Mitsubishi Televison & Video Experts
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
sound speakers
  • Televison & Video
