20 Most Recent Mitsubishi CS-27309 27" TV Questions & Answers
there is no way you should have a remote.
Mitsubishi... • Answered on Aug 22, 2013
hello with out a circuit refrence it will be hard to find thanks
shaun
Mitsubishi... • Answered on Mar 20, 2009
The set you have has a bad tuner assembly. At this point most likely you would be better off getting a new TV set. Good Luck
Mitsubishi... • Answered on Apr 02, 2007
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/
Mitsubishi... • Answered on Feb 26, 2021
You have to enter its service menu to reset the lamp time. 1. Enter the Option Menu <MENU><2-4-7-0> 2. V43C & V43 Chassis select "2. Reset All Settings" and <ENTER>. Then confirm "YES" <ENTER>.. V43+ & V43++ Chassis select "Initialize" and <ENTER>. If you wish to get some details; check the site linked here. Pull up older posts or search the site by type in the brand name of your set, at its search box at the right column.. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/
Mitsubishi... • Answered on Feb 19, 2021
and we should care about this why?
Mitsubishi... • Answered on Jan 17, 2021
You have to do a channel search to find what's active in your area.
Mitsubishi... • Answered on Jan 13, 2021
The remote control "manual" usually is part of a related device manual.
Mitsubishi... • Answered on Dec 12, 2020
What color lights blinking after words does light stay on? Also what model number or year is your TV?
Mitsubishi... • Answered on Dec 10, 2020
check the screen first if backlight on or off .the simple method is checking backlight on or off first switch off the all lights of the room if backlight light of the tv is ok shows light blue shade whole screen
Mitsubishi... • Answered on Dec 04, 2020
Televison & Video Logo
5 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
want know yellow capacitor 107 10v r3331
  • Televison & Video
