20 Most Recent
Samsung SF-515 Plain Paper Laser Fax Questions & Answers
Not receiving any incoming faxes
Is the phone line working? Do you have any devices connected to the phone line that pick up before the fax machine? Make sure the machine has paper and is set to FAX or AUTO. Is there a Memory Full error? Clear the memory (Setup > Memory Clear then press Start/Enter. Use the left and right arrows to select the items to remove. Press Start/Enter twice (second time to confirm the choice). Repeat until all memory is cleared that you wish to clear. Then press Stop to exit.)
If you are using the ANS/FAX mode and have an answering machine connected to the extension port, disconnect the anwering machine and switch to FAX or AUTO. Check if the machine receives faxes. Sometimes the extra device causes interference. Call the fax machine from a different phone number and see if you hear the fax tones.
Check that the Junk Fax barrier is off, if the incoming call is from a machine that is not listed in your speed dial database. If you have a distinctive ring, make sure that the Fax machine has learned the ring by pressing Setup go to DRPD. Choose Set and call the fax machine from another phone. The LCD will say Waiting Ring until it gets that call and then once the ring is learned will say END DRPD Setup
I hope these ideas help.
(If you have a phone company voice mail service, the faxes may end up stuck in that box. It depends on how many rings the fax is set to wait before picking up versus when the voice mail opens to take the call.)
The machine doesnt work at all.the LCD screen
This is a well known fault with fax machines and unfortunately the main board and or the power supply has gone faulty. there is no fix other than to replace them. Its probably not cost effective. look for a replacement machine.
Sorry!
Fuser error
you need to replace the fuser bulb which is used to heat the paper or thermostate which controls the temperature..
I have a samsuns SF515 fax machine after changing
if you have changed the drum/toner unit then the machine should have a fuse on top of the drum unit.I have come across some cartridges that don't have them on the unit.The fuse resets the fax so that it knows there is a new unit installed.If that does work then clear the machines memory using the control panel
Fuser unit error
This means the heater in the fixing unit is not functioning properly. Either the element is blown, and not heating up, or there is a temperature regulation problem.
It will need a service technician to repair this
Message error
sir,
You can only receive a fax by pressing *9* from the extension phone which is connected to the fax machine.*9* is an universal code. for more u can read up your user guide.
No incoming Faxes
sir,
first you have to set the fax machine in auto answer mode.so that you can automatically recive the incoming faxes.
SF-515 does not dial anymore
Hi there try this press menu then using the arrow keys go into machine settings I think if not you are looking for line type. Once in the make sure it is set to tone.
Once you have done this come out and try if this doesn't work then the control panel maybe faulty and you could take it apart and clean the number pad keys and make sure that the buttons move freely.
If they do cleanup and put back together and check machine if it still doesn't work then the panel will more than likely need replacing.
Thanks J
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
