20 Most Recent
LG DLE2301 Electric Dryer Questions & Answers
Lg dryer doesn't turn on
Having changed the main control board, the only other things to check are as follows:
Thermal Fuse, Door switch, Drive motor, Drive belt and Belt switch.
These can cause a non-start situation.
Dryer continues to run past the preset time.
If you are not running the load on "Time Dry", the machine will automatically use the sensor dry settings. Meaning that it automatically adjusts dry time with the dampness of the load. If you look near the time window you will notice that it says "est. time remaining". If you would like to have the unit run for just 20 minutes use the time dry button you will notice the dryness level light will turn off. The means your unit does not care how wet or dry the clothes are it will just run for 20 minutes. Hope this helped explain things.
LG DLE2301R no power up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The
Dryer is not TurningDryer Repair - The
dryer will not startheatman101
Making a roaring noise when
Hi damaestrogk....
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers are in need of lubrication.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
My LG2301E dryer was making
maybe the drum roller/glide, belt, idler arm assemblage, I would not suspect the motor as it is working. Here is a website that may help:
http://www.ehow.com/how_6373955_install-belt-samsung-lg-dryer.html
