20 Most Recent
Honeywell Dolphin 6100 Wireless Barcode Scanner 6100LP11111E0H Portable Terminal Questions & Answers
My Honeywell plug-in doorbell won't stop ringing
If your Honeywell plug-in doorbell won't stop ringing, there are a few things you can try to troubleshoot the issue:
1. Check the batteries: If your doorbell has batteries, make sure they are properly installed and have enough power. Replace them with new ones if needed.
2. Check the ring options: Press the ring option button with the music sign and cycle through the different ring options until you find one that stops the ringing.
3. Reset the doorbell: To reset the doorbell, unplug it from the wall outlet and wait for a few minutes before plugging it back in. This will allow the doorbell to reset and may solve the issue.
4. Check the chime settings: If your doorbell has multiple chime options, make sure the one that's causing the issue is not selected. You can cycle through the chime options using the settings button.
5. Contact customer support: If none of the above steps work, contact Honeywell customer support for further assistance. They may be able to provide additional troubleshooting steps or offer a replacement if the doorbell is defective.
2/22/2023 10:53:48 AM •
Honeywell...
Answered
on Feb 22, 2023
