20 Most Recent CIPHERLAB 8000 Series Handheld Mobile Computer Questions & Answers
I have a Cipherlab 8000 barcode scanner and cannot remember the password. How can I reset the password?
I have the same problem did you ever find a fix
5/14/2022 12:48:08 PM • CIPHERLAB 8000... • Answered on May 14, 2022
Cipherlab cl8200 timeout error? when exporting to
9f76079d-6fa0-4db9-9587-a2e27f8ce81a.jpg in the lookup section . select the following that should solve the timeout problem
3/17/2017 10:02:18 AM • CIPHERLAB 8000... • Answered on Mar 17, 2017
My CipherLab 8000 not scan the barcode.laser are open but can't scan.Could you please find out the solution.Thank you.
May be some one doing by mistake disable for all types of bar code ( not enabled ) or all sympologies.
10/25/2016 1:05:30 PM • CIPHERLAB 8000... • Answered on Oct 25, 2016
How do I get the craddle to turn on
It depend of model of your cradle: If cradle is without charge capability (suits CPT-8000), it get power from USB for internal logic and irda. Cradles with charging capability ( two charging pin in cradle socket) need a powersupply to power both the charging of CTP-8001 and the internal logic/irda. The driver need to be installed before connect the cradle to computers USB-port.
7/2/2015 1:11:44 PM • CIPHERLAB 8000... • Answered on Jul 02, 2015
How do I insert comma into the scanned data of a cipherlab 8000?
If you using Forge, you could chose between comma or dot for decimal inputs in the latest versions of Forge. Earlier just a dot were available.
7/2/2015 12:55:31 PM • CIPHERLAB 8000... • Answered on Jul 02, 2015
3answers
My cipherlab 8000 has the
Hi, there are two possibilities, One the main battery has gone bad, this is common, the only way to tell is to replace it. Two, on the main board, there is sometimes a small battery, this battery can sometimes leak, etc, or have gone bad. Replacement, if there is one, usually fixes it.
7/2/2015 12:40:32 PM • CIPHERLAB 8000... • Answered on Jul 02, 2015
0answers
0answers
Cipherlab model 8001. When programming
fc0ae530-6af6-4e10-8135-4244176001ce.jpgplease follows the following process in your form make sure that your field datat relates to the the field in your lookup file
12/24/2013 7:40:27 PM • CIPHERLAB 8000... • Answered on Dec 24, 2013
0answers
0answers
I have a Cipherlab scanner 8001, when i connect it
OK,you indicated COM1 serial port is working on the a Cipher scanner 711.
Please check the communication setting on the Cipher scanner 711.
The most popular setting are
AUTO BAUD RATE
or
9600 bps 8 bits N for no parity check and 1 for check bit.
Short for as
9600 8 N 1
Check the setting on the Cipher scanner 711 communication speed and make set the Cipherlab scanner 8001 to the same rate.
MAKE SURE YOU RE-BOOT the Cipherlab scanner 8001 before re-try.
Please keep me up to date on the fix via email.
1/30/2011 7:48:59 AM • CIPHERLAB 8000... • Answered on Jan 30, 2011
Faut-il installer un driver avant
FIXYA ADMIN CHECK. Q APPROVED.
1/15/2011 12:45:10 PM • CIPHERLAB 8000... • Answered on Jan 15, 2011
Hello! I have a problem when programing the
Cipherlab has technical support available - I'd recommend getting in touch with them. The Cipherlab global site is: http://www.cipherlab.com/default.asp - you can choose your region, then support or the contact link.
10/21/2010 1:24:38 PM • CIPHERLAB 8000... • Answered on Oct 21, 2010
CIPHERLAB 8000 Series Handheld Mobile Computer Logo
29 questions posted
Top CIPHERLAB Computers & Internet Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Larry Ng
Larry Ng
Are you a CIPHERLAB Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • CIPHERLAB Computers & Internet
Most Popular Question
cipherlab scanner 8001 when connect
  • Computers & Internet
