20 Most Recent
Polaroid CZA10011B PoGo Instant Thermal Printer Questions & Answers
Why does it print with streaks through the
I've had that problem and running the special blue sheet that comes with the paper pack through the printer seems to work. I've had to run the blue sheet through before each printout for a while, but the problem seems to have gone away - I guess it finally got cleaned out. It also seemed like running the blue sheet through after not using the printer for several weeks was a good idea before printing. When I get a new pack of paper, I run the blue sheet through as instructed. Instead of throwing the sheet away, I store it on top of the blank sheets inside the printer. That way I can use it again if needed.
1/16/2013 6:43:39 PM •
Polaroid...
Answered
on Jan 16, 2013
I keep trying to connect to tha bluetooth but its
Check your camera manual and it should have a code listed for a bluetooth password (or check the printer which might have it's own password). If that does not work then the bluetooth version might be incompatible with your camera/printer.
3/14/2011 3:41:30 AM •
Polaroid...
Answered
on Mar 14, 2011
Trying to print coupons that
There is a post about using the free Pogo app in the Android store that solves some problems.
http://www.fixya.com/support/t7303474-successfully_paired_pogo_samsung
The image should be in a .jpg format.
1/10/2011 6:36:00 PM •
Polaroid...
Answered
on Jan 10, 2011
How can a Polaroid Pogo printer works without battery, directly connected to current?
If you a reasonably handy you could disassemble the battery pack and replace the cells with new NiCad or NiMH units. They are not complicated and you should find lots of sites on the net that will supply the cells. Alternatively if the unit has a DC socket you should find the voltage and current printed beside it. Try fitting a suitable power pack.
Cant sign in
Sign in to what/where? You obviously managed to sign in to FixYa.
My ea games load but the will not play
make sure you have the software that you need to play them such as direct x is a software you will need to play tons of games on your computer that you installed from a cd.
Pogo ican get on pogo but most of the games will
Remove all Java and Flash from your computer. Once removed, do a Shut down, wait a couple of minutes, power the computer back on, go to Adobe and download and install Flash, after that's done, go to
www.java.com and download and install the latest version of Java. Restart the computer, then try Pogo again. Don't skip any of the steps or it probably won't work.
Pogo printer error -21860
Don't name files with characters like - . & or something like that.Hope that the tip will be useful.
