20 Most Recent HEWLETT-PACKARD Compaq Presario CQ5302F 22GHz Intel Celeron Desktop AY639AAABA (AY639AAABA) Questions & Answers
Upgrade BIOS to see if it will resolve hardware issue with new stick of RAM
Hi Szusza, The new RAM module you purchased may be faulty, it is definitely possible that either due to a fault of the new RAM or on the slot you are trying to install it to cause the computer to not fully boot. Have you tried to boot the computer with the new module only? If not please try this: Replace the original RAM module with the new one (make sure you insert the new RAM in the same slot you took the old one out) If the PC boots you know the new RAM is fine. If this does not work I would suggest getting your new RAM tested. If it does work, put the original RAM back in the computer (in a new slot) if it does not boot after that then, there is possibly a problem with the RAM slot on the motherboard.
12/16/2013 9:55:31 PM • HEWLETT-PACKARD... • Answered on Dec 16, 2013
What is the best processor upgrade for Compaq CQ5302F
The processor is a Socket 775 processor and there are a lot of CPU's available and a good one is the Celeron E3400 it is a dual core running at 2.6 Ghz. it isn't too far removed from the original but will give you a noticeable improvement in performance. There are better available but I can't find any motherboard details for it.
3/20/2012 8:30:21 PM • HEWLETT-PACKARD... • Answered on Mar 20, 2012
How can I unlock my computer if someone change my password
This is about user password and there is no easy fix..but the procedure to get rid of it is not that complicated..Practically you have to reinstall the operation system or use the recovery partition to reinstall the OS ..and this will remove the password..reinstalling in either way will erase the C drive partition ..and if you have important data on this partition it is best to try to make a installation of the OS using the repair feature during and keep your data . or if you can not manage , just remove hard disk ..and add it to another computer running same OS..and browse for the folders in side and save them ..and reinstall after that ..you will need either the recovery partition or recovery disk or boot-able disk with the OS or a boot-able usb tool with the OS ..and the drivers for the motherboard and devices..
1/11/2012 5:59:46 AM • HEWLETT-PACKARD... • Answered on Jan 11, 2012
My hp will not turn on after powering it down. However, their is a green light on in the back of the tower.
the green light is from the power supply .and only indicates the presence of power...if it does not start you must check the reasons ..look first for cables being unplugged from the motherboard or so .. If nothing is being displayed on the front led it means it has no power for some reasons..and it is actually a good news..If the led is amber in color ..than it is something wrong with the board...I think in your case it may be just the front panel buttons cord being unplugged from the main board..if you have done something insiude it ..it maybe the cause..Or it may be the main power supply to blame ...even if it indicates it has power ..something may be wrong with it ..and not transforming the current like it should..I repeat... the lack of any sign of power on the main board is a good news for now ..if you eliminate all other causes related with the power supply and the front panel and other cable that powers the board...than you have to see if it is not the main board to blame ...I suggest to strip it down to the minimum ..(leave just some ram memory and the cpu on it ..and try to boot without any cards or hard disk or other..and see if you get anything on screen with the on board graphic..if you manage to start it ..and than build your way back ..one by one ..and diagnose them ..Also check the cmos jumpers..and the battery ones in special ..If for some reasons they are removed..it will play dead..for the lack of power..Just download the main manual from the hp ..and in there you have the board ..and follow the setting for the jumpers..(or better ..look for the manual for the mother board by name ..what you need is teh maps for all teh plugs ..front panel ... cards..etc..this way if you strip it you can follow the indications to build it back )
1/9/2012 6:38:38 AM • HEWLETT-PACKARD... • Answered on Jan 09, 2012
Is the processor in the HEWLETT-PACKARD Compaq
No. All processors are only locked with a clip under the heatsink/Fan. thanks
1/9/2011 12:49:45 AM • HEWLETT-PACKARD... • Answered on Jan 09, 2011
Power light comes on but
Steps:------
1.Plug in a different USB device in that USB port and check if it is working or not. If the 2nd device is working then the 1st USB device has gone bad. If none is working then try the steps mentioned below.
2.Unplug the powercable from the laptop and also unplug the battery. Press and hold the power button for 30-40 secs and then plug in the power cable and the battery and check.
3.click on START->right click on COMPUTER->click on MANAGE->click on DEVICE MANAGER->click on the symbol beside Universal Serial Bus Controller and uninstall all the USB ROOT HUB's and then restart the computer.
4.Run System Recovery from the Recovery Partion or Using the Recovery Disk.
Still if it remains then it is surely a hardware issue
10/19/2010 11:42:14 PM • HEWLETT-PACKARD... • Answered on Oct 19, 2010
2answers
When I try to download into quicken the documents page comes up. How do I correct this situation?
If your bank statement is not in the Quicken format, you cannot do that. Best see if it will download into MS Excel. If not, get in touch with the Bank
10/19/2022 4:47:44 AM • HEWLETT-PACKARD... • Answered on Oct 19, 2022
3answers
Back Slash on HP keyboard ProBook
Try now~ Then you can reset your keyboard if you like
5/4/2022 2:32:08 PM • HEWLETT-PACKARD... • Answered on May 04, 2022
HP G72-253NR Laptop - Using an External Keyboard
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
1/31/2019 6:37:16 PM • HEWLETT-PACKARD... • Answered on Jan 31, 2019
Pano pag ang laptop sa HP ay hindi na mag on pero meron syang power?
please use English, ok?
10/30/2018 1:04:04 PM • HEWLETT-PACKARD... • Answered on Oct 30, 2018
3answers
User manual Hewlett-Packard G2 tablet or the instruction booklet
https://support.hp.com/us-en/product/hp-10-g2/8223709/model/9078231/manuals
this is the manual pdf just download it
10/1/2018 11:15:14 AM • HEWLETT-PACKARD... • Answered on Oct 01, 2018
2answers
My Hewlett-Packard w2207 monitor is showing no input signal when I power it on what does that mean and how can I fix it
1) Reset your computer. 2) Unplug the cable from the computer to the monitor and check to see if its damaged, if OK plug it back in. 3) On windows computer, click windows key / windows system / control panel / device manager / display adapters (click on icon) / Update driver
5/1/2018 3:23:11 PM • HEWLETT-PACKARD... • Answered on May 01, 2018
HP A6519FH Black Screen Issue: I
what computers.?? 1000's of models over 30 years. made F10 is BIOS screens, so if that works, BIOS. and any screen then the PC is not booting. try booting to CD? *(a free linux live cd?) as a test. if that works run HDD tests. next ill stop here, if you can get this far, we go to next step F11 HDD reload the OS, if PC is 2006 or newer from HP.
2/1/2018 12:20:26 PM • HEWLETT-PACKARD... • Answered on Feb 01, 2018
Ce 3700, no model HP stated
Try again with the model number
1/30/2018 12:32:03 PM • HEWLETT-PACKARD... • Answered on Jan 30, 2018
My laptop hp compaq 6715s, the battery is charging
what is a device? did you mean PC, a collections of devices and chips:? a PC Is not a DEVICE it is a system.(or machine) why in the world not buy a new battery first? if charging fails. mine sometimes go bad even 1 year old, when I abuse it. and I fully expect that, if you read the battery makers pages, youd learn how that happens' (cycling the snarf out of it) if i remove the word DEVICE and add LAPTOP OR PC THE ANSWER IS THIS. IF the Pc does not run with the battery (main big) out ! the power pack is bad. the PC will run forever on AC power, a fact, !!! I do so all the time, or even the wrong AC pack used, (mixed up with other pc:) get a new pack, get one matching your systems, needs (watts) the laptops can come with 5 processor options and 4 graphic chip options, the worse mix is 100watts, HP will tell you that match. but only if YOU tell your full service tag data.... that magic, nnnnnnnABA# number tells the HP pro what is inside this laptop and what power park is right or just buy the 19v, 100watt pack. here is real HP, fixya is NOT. they can match you up as can the hp PARTS SURFER, https://h30434.www3.hp.com/
1/24/2018 1:56:50 PM • HEWLETT-PACKARD... • Answered on Jan 24, 2018
2answers
How to fix the sound of HP pavilion dv6345us
sure, get the Correct HP driver for this exact pc but, but but...The windows sounds are dead. (do that yet>, CP + sound test)CP = control paneltry to know , most HP made, dv6345us, can have 3 sound chips as an option day 1 new!what you have is clearly stated in the service tag that you did NOTpost, the number ending in ABA# is THAT number.the chip and PC and the unstated OS all must matchwindows what? you never said so i cant match that either.VISTA????????? vista 32 bit or 64????????but the other way is what, sure, guess.read the drivers at HP and try all there.for sound chips (aka audio)This HP computer is 11 years old. now. (2007)HP dropped most support on it this old, (SOP) one sound chip is Conexant AC -Link Audiolets say you said (service tag) RV214UA#ABAand you said VISTA> what works there.the secret is deep, lacking full spec, from HP.finding Conexant drivers is not easy, lots of hits all virus sites now.lets first look .does device manager show it as bad.CP+DM see sound there. is it red, yellow or Unknown marked.go to CP again control panelclick sound is the Conexant still there.the window for sound has a speaker is it selected?select speaker then properties lower right.then pick enhancementshit checkmark, disable all sound effectsclick tab levels, turn up volume.can you do all that, i bet not, its got bad drivers for this chipVISTA btw is dead so asking MS to update driver is dream of dreams, hopeless, now and for sure forward.you dont have the HP install disks so that source too is missing.,leaving you , VISTA and MS and HP and conexant in the lurch.if microsoft was not dead and your internet was alive (is it)the remove the driver, and reload, it under device manager.it then magically PnP reloads from MS but not if the MS driver servers are off line as they sure are. (1/2 or all) (ms secret this is)Hard this is,::::, 1ST OFF, is HP ended support,ON YOUR PC NOW.2nd VISTA support has ended at MS. (double dead)3rd factor (bad) IS Conexant maker of chip and their Driver. IS DEAD. TRIPLE DEAD.SHORT WHY>?synaptics Bought out Conexant in 2017, and shows no support NOW. FOR THAT. the Snaptics web site lists nothing on the words driver or conexant. zero support, but do call them,,,? SO that ends that foray. leaving all those malwares sites offering this driver, only. ? many we can find it this magical way. the FAMOUS DRIVER PACKS site. (all safe ask) the one place on earth with no malware is here.this is the vista set 32bit only 64 is on other pagethere are 15 drivers for Conexant. there. get them try them.end storyhttp://driverpacks.net/driverpacks/windows/7/x86/audio/11.11
1/5/2018 4:29:57 PM • HEWLETT-PACKARD... • Answered on Jan 05, 2018
3answers
How do i take a screen shot
There should be a button on your keyboard labeled "PrtScn". It stand for "Print Screen". This will copy an image of your screen. Simply open Microsoft Paint or a similar software and select paste. Your screen shot should appear in your chosen software.
1/2/2018 8:44:11 AM • HEWLETT-PACKARD... • Answered on Jan 02, 2018
I installed validity driver version.
NO PC stated (model name and full number) NO OS stated, is this XP? must we beg you to get hard key facts like this>? what are you attempting, ? the Finger print reader has many features, which one are you attempting? yes, it can work but only works on matching PC and matching OS. the HP pages there warn you,.it only works on the OS sold with PC. (eg vista or w7) HP web site on your PC is clear, ever look there? my HP 8540w , works perfectly with W7 but not w10 ! i can not use the reader nor the security package, ever. But w10 is happy there , FP reader stuff removed. HP will not revise these drivers and apps for W10 ever. see my point? In my example case. there are 2 parts, the FP reader, driver. and the security package ( vastly huge and complex !) i say why use it at all? do you have secrets on your PC? (you 007 agent?) 008? or your soon to be published book ? (huge value) or engineering work/ cad/cam, etc. or valuable art, (or music composer) or you are CEO or FCO with sensitive data? (accountant?) if no, then avoid that. The reader is safe but not the security HP applications: look in the registry at all that complexity, and risk for that. you can use the reader to block BIOS boots. dead. block the windows, login page. or block specific apps, or all 3. is say don't do it, at all. But all that works on mine 100% on w7 only. it does work but is still risky. other apps do not like it , etc.
12/19/2017 2:41:37 PM • HEWLETT-PACKARD... • Answered on Dec 19, 2017
HEWLETT-PACKARD Compaq Presario CQ5302F 22GHz Intel Celeron Desktop  AY639AAABA (AY639AAABA) Logo
7 questions posted
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HEWLETT-PACKARD Computers & Internet
Most Popular Question
upgrade bios see will resolve hardware
  • Computers & Internet
