20 Most Recent eMachines EL133105 Desktop Computer with Windows 7 Home Premium (64bit) | Athlon 2680E (18GHz) | (PTNB902002) Questions & Answers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html
if these arent right you will find free sound drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
be precise you might have to try a few times to get it right
hope this helps
eMachines... | Answered on Mar 30, 2016
This is not a PC problem. You should consult Tally 9 customer support or search their Forums for assistance.
eMachines... | Answered on Apr 21, 2014
Please download this site http://www.3dpchip.com/3dpchip/3dp/chip_down_en.php after download, install and click for video card or the missing driver and wait for pop up page and select the appropriate windows. And also try this link http://drivers.downloadatoz.com/vendor_emachines/emachines-el1331/
eMachines... | Answered on Jan 08, 2014
First check is your volume mixer if you notice that your audio device is properly working. Simply right click your audio shown beside your time and date and select Open Volume Mixer make it sure that no one is mute. If it is working properly, second is go to control panel and select RECOVERY and open system restore, choose exact date that your audio device working properly. If not simply uninstall and install the driver. All of them it doesn't work just buy usb audio device like this https://www.google.com.ph/search?q=usb+audio+device&client=firefox-a&hs=U7k&rls=org.mozilla:en-US:official&source=lnms&tbm=isch&sa=X&ei=_MDMUqTZCc7PiAfyt4GYDQ&ved=0CAkQ_AUoAQ&biw=1024&bih=718#facrc=_&imgdii=_&imgrc=wfRzEF_R6kAGdM%3A%3B1vCA49U-0gpQJM%3Bhttp%253A%252F%252Fwww.techfuels.com%252Fattachment.php%253Fattachmentid%253D18198%2526d%253D1271760841%3Bhttp%253A%252F%252Fwww.techfuels.com%252Fthreads%252F35253-USB-2-0-3D-7-1-Channel-Audio-Sound-Card-Adapter%3B479%3B369.
if no any power indicator at the front and also the fan at the power supply as will as in the mother board, it was a power supply failure.
eMachines... | Answered on May 14, 2013
try ccleaner it's free and easy to use.
eMachines... | Answered on Feb 19, 2013
if you want a good free media player download VLC PLAYER
eMachines... | Answered on Dec 06, 2012
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
eMachines... | Answered on Nov 11, 2012
Click the Start button at the bottom left of your screen, click the arrow next to the Shut Down button, and then click Restart. If you are unable to do this, hold your power button until your screen goes blank, wait 30 seconds, then power your computer back on.
eMachines... | Answered on Oct 09, 2012
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark ? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled.
hope this helps
eMachines... | Answered on Sep 13, 2012
http://download.cnet.com/realtek-high-definition-audio/3000-2120_4-10788600.html
IE: windows 7 sound drivers
hope this helps
eMachines... | Answered on Jun 21, 2012
It depends!!! On some modems/routers it will be listed on the somewhere on the device. AT&T places theirs on the their device for you.
If not, you can always plug an ethernet cable from the router into the ethernet port of a computer and type in the router's ip address in the browser. For example the ip address will be something like 192.168.1.1
Once you have the correct ip address ( you can google your router's manufacturer for the ip address if you don't know it), then the routers gui interface will open up for you to configure the router. It will ask for the user id and password. Most times this is the default password set by the manufacturer unless whoever installed your router changed it. You can also google your router's manufacturer for the default user id and password. In fact you could go to the router's manufacturer's website and look at the manual for your router which will have the ip address, userid and password.
Once you are in the router you can go to the Wireless Settings and Wireless Security to see the key.
eMachines... | Answered on Apr 07, 2012
I have encountered this problem.my solution is this,
STEPS: 1.)Remove you HDD and place it to another Computer or PC.Then make it a slave drive or secondary drive. 2.)If your computer detect your HDDr,try to right on it and press Properties>Tools>Error Checking and press CHECK NOW. 3.)After that check the two check box and then press START. (if it says that you need to restart your computer,just restart it) 4.)Then when the scanning and repairing is done.put back you HDD on your desktop and it will work and boot properly.
eMachines... | Answered on Sep 13, 2011
Try uninstalling it and download the latest version and reinstall it all.......hope it works
eMachines... | Answered on Sep 02, 2011
This appears to be an issue with the play speed. in the play option on windows media player "play speed" appears to be set too fast.
eMachines... | Answered on Jul 07, 2011
Hawaiian Electric Industries, Inc.
eMachines... | Answered on Dec 07, 2010
hi rja8410m
You need a video card that is capable of outputting rca signals.
Also check your video card slot if its agp or pci-express
Hopefully it helps
Thx
Banaple
eMachines... | Answered on Sep 03, 2010
Every computer comes built with a processor cooling fan system.
The fan's main function is to keep the processor from overheating.
After long periods of use, processor fans can start to malfunction.
If your eMachines computer's fan is excessively noisy, it will need some maintenance.
If you don't deal with a noisy fan promptly, your computer's processor could overheat and cause significant damage to your motherboard as a result.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Power down the computer.
Disconnect all cables and peripheral devices from the computer's back panel.
Rotate the computer so the back panel is facing you. Lay the computer on its left side.
Remove the Phillips thumb screws that fasten the right side access panel to the computer's frame.
Remove the side access panel from the computer to reveal the motherboard and all internal components.
Locate the cooling fan assembly near the center of the motherboard.
Remove all Phillips screws fastening the fan to the motherboard.
Disconnect the fan's power cable from the motherboard.
Then lift the fan out of the computer.
This will reveal the processor chip.
Place the fan on a flat work surface with the label sticker facing upward.
Use a thin, flat-head screwdriver to peel away the label sticker from the fan.
This will reveal the access hole to the fan motor's bearings.
Apply one to two drops of lightweight mechanical oil into the fan motor's bearings.
Replace the fan's label sticker.
Use a can of compressed air to spray the dust and debris from inside the fan blades.
Place the fan back into the motherboard on top of the processor chip.
Replace the retention screws and reconnect the fan's power cable to the motherboard.
Replace the side access panel and its two retention thumb screws.
Place the computer tower vertically, and then reconnect all cables and devices to the computer.
eMachines EL... | Answered on Nov 18, 2013
You will most likely have to remove the HDD from the chassis to access the RAM. Most eMachines utilize either tabs or screws to remove the drive. If you can post some pics of the inside of the chassis I can assist further.
eMachines EL... | Answered on Oct 29, 2013
you must check your browser which cud be outdated....download the latest chrome or mozilla browser and you are good to go
eMachines EL... | Answered on Oct 23, 2013
eMachines EL133105 Desktop Computer with Windows 7 Home Premium (64bit) | Athlon 2680E (18GHz) |  (PTNB902002) Logo
29 questions posted
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
EL eMachines
  • EL eMachines
Most Popular Question
troubleshooter will not start anything
  • Computers & Internet
