20 Most Recent
Dell VOSTRO 1015 T6570 21G 2GB 160GB DVDRW W7Hewlett Packard 1YR NBD (4685946) PC Desktop Questions & Answers
After update bios ,Last i had switched off my
Let's hope that the bios upgrade wasn't corrupt. Remove the battery and unplug power source from wall. Wait about 1 to 2 minutes, then reinsert battery, and plug adapter back in, and see if it will power up. If not, let me know,I might have another suggestion.
Problem
DON'T INSTALL A BIOS-UPDATE.WITH OUT A 100% CERTAINTY.
Hi guys. I'm new here. Hope i get some help,
It sounds like the bluetooth device is turned off.
Go to device manager and look to see that the bluetooth is listed and enabled.
I hope this helps.
Good luck and have a pleasent day.
Forgot my dell 1015 bios
In case of forgot BIOS password , you can clear the password very easily .
First unplug the power cables to avoid the power
Open the cabinet of your system and look for the BIOS battery on the mother board .
It look like this
Take it out and wait for 2 minutes and then again put the battery in its place
Now plug all the cables and start your PC The BIOS will not ask for password.
Hope the information will be helpful to you.
Thanks.
Recently i have buyed dell
Try reinstalling the WEBcam driver.
You can download the drivers from Dell WEB site, thesupport download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows XP or Vista version of the drivers for your Windows operatingsystem. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Broadcom 802,11g network adapter
- Please go to this link and download apropriate net work card drivers
http://supportapj.dell.com/support/downloads/driverslist.aspx?os=WLH&catid=5&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=VOS_N_1015&hidos=WLH&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
How to switch on the web cam in dell 1015 it is an
If you have software that uses the webcam, most likely it will turn on by itself. If this doesn't happen when you know it should, you can try to download the drivers and install those. If that doesn't work, you might have faulty hardware.
I got a problem for downloading wedcam driver for
Hi.
Click Here to download the drivers that you need for your Dell VOSTRO 1015. This is for
Windows 7 32-bit Operating system, if you have a different version of Operating system then just change the operating system selection on top area on the dell support website that I provided you. Just download those drivers and install it on your
computer. Hope this Helps
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Code 10 is not starting
This error is basically saying that Windows, for one reason or another, cannot communicate properly with one of your programs. This communication problem is usually caused by out-of-date, missing or corrupt device drivers. ... Select Start > All Programs > Windows Update.
This copy of windows is not genuine
i used to get that also, I wrote down windows numbers from windows sticker on the side of machine, (needed magnifying glass) and went online to windows verify, after they scan it, it came out good
HOWCAN FIND MACADRESS WIFI LAPTOP VOSTRO1500?
Open a command prompt ( Windows key + R to open Run box, then cmd), and type
ipconfig /all
and look for the wifi adapter. The entry labelled "Physical Address" is the MAC address. It will look something like 84-3A-4B-C8-E9-B7
(Your router might want it entered in the format 84:3A:4B:C8:E9:B7)
Cpu overheating
The cooling fins on the processor chip are plugged with dust. The fan may not be turning fast enough. If that's the case you'll need to replace the cooling fan
Wifi hotspot
WiFi will in the laptop will connect to a wireless router or a hot spot. The laptop itself has no hot spot built in.
