20 Most Recent Acer Aspire Notebook Questions & Answers
In my fingerprint device there but in the application when i go to enroll the my fingerprint data it shows as unable to detect the fingerprint device. pls help me..........
Take it back to where you bought it or contact the manufacturer. I bought a laptop for my boys that was supposed to be new but it was used. The fingerprint function was devoted to the PREVIOUS owner's finger print.
6/21/2018 4:20:35 PM • Acer Aspire... • Answered on Jun 21, 2018
I;m using Acer Aspire 5738 laptop. recently
Driver not matching... Check for the right driver and unload from Acer site using model number
10/15/2017 6:21:01 PM • Acer Aspire... • Answered on Oct 15, 2017
How to install fingerprint software
Acer has done a fingerprint install YouTube video
3/2/2015 8:57:23 PM • Acer Aspire... • Answered on Mar 02, 2015
How do I open PDF documents have tried several things Used to open but not now
find any pdf document on your computer. Right click on the file, select PROPERTIES. The properties box that opens will tell you what program opens the file and allow you to change it if the wrong program (or nothing at all) is indicated. I suggest using adobe reader.
2/18/2015 12:04:45 AM • Acer Aspire... • Answered on Feb 18, 2015
Acer aspire manual pdf
Try F3 key.
8/20/2014 6:42:17 AM • Acer Aspire... • Answered on Aug 20, 2014
Acer aspire boot problem
reinstall windows operating system. its a corrupted MBR which stands for mater boot record
10/25/2013 6:20:14 PM • Acer Aspire... • Answered on Oct 25, 2013
Google 3g problem
gi o in contact with ur internet provider...they should be able to help u with ur problem...
10/18/2013 1:49:48 PM • Acer Aspire... • Answered on Oct 18, 2013
Nothing happens when I put a instructional printer
you must uninstall the software , and install again use the CD for setup, and try again. See if the driver in in system properties in control panel, and then tab hardware look device manager the driver printer is installed? If not download from the supplier printer and installed.Run the antivirus+antimalware+ update the window+update your browser: firexfox, i.e or safari.etcGod bless you
7/30/2013 3:46:55 PM • Acer Aspire... • Answered on Jul 30, 2013
0answers
Bios 5738
Be the first to answer 7/18/2013 1:11:55 PM • Acer Aspire... • Posted on Jul 18, 2013Be the first to answer
Battery
This is the procedure for solving consider replacing your battery problem. Start by running the command prompt with administrator privileges. This will give the full control over the command prompt. There are those commands that can only be executed when you are using the command prompt with administrator privileges. Change the destination path showing on the command prompt to be set to C:\ then type the command POWER -ENERGY( to change destination path to C:\, type CD\ ). This command will make the computer scan the battery status and after 60 seconds, a report will be generated and saved in C:\. Simply open the energy report and scroll to check the battery information. Look for the design capacity and the last full charge, note the difference in this figures. For my laptop, these were the details Battery Information Battery ID: Hewlett-PackardPrimary Manufacturer: Hewlett-Packard Chemistry: LION Design Capacity: 88800 Last Full Charge: 36467To remove the message consider replacing battery fully charge your laptop battery then unplug the charger to use the laptop on battery power. Use it until the laptop to automatically shut down. Still with the charger unplugged, power on the laptop again. Do this until the battery is totally empty. Now plug in your charger and charge the battery fully. Then perform the commands steps again by running the POWER -ENERGY command. Make sure you note the differences in the last full charge details. Continuously perform these steps until the figures in the last full charge are more than 40% of the design capacity.
5/19/2013 5:08:23 AM • Acer Aspire... • Answered on May 19, 2013
I have an Acer Aspire 5738 with built in webcam(crystal eye) that has stopped working. I assume its a driver problem, my device manager shows one error Windows has stopped this device because it has r
Crystal Eye is a webcam application included with some Acer laptops. Laptops that have the Crystal Eye WebCam application installed also have a camera built in to the monitor. Crystal Eye can adjust the camera's brightness, contrast and color intensity, and capture photos. If you removed the Crystal Eye WebCam application from your Acer laptop on accident, you can download the software from the Acer website and reinstall the application to your PC. Click "Start." Click "Control Panel." Input "device" into the search box. Click "Device Manager." Expand "Imaging Devices." Double-click the Web camera to find the name of the manufacturer. Go to Acer Support. Select "Notebook" from the "Select Your Product" menu. Select the notebook's product line, then select its product model. Click "Confirm." Click the "Applications" tab. Select an operating system from the "Operating Systems" drop-down menu on the far right. Scroll to "Camera." Download "WebCam Application." Use the manufacturer information found in Device Manager to determine which vendor to download from. Save the file to the desktop. Double-click the file to run the setup for the Crystal Eye WebCam. Follow the on-screen instructions to complete the installation. Acer support http://support.acer.com/us/en/default.aspx Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
3/1/2013 7:13:30 PM • Acer Aspire... • Answered on Mar 01, 2013
Jerky / buffering game
What game? On-line? Shut down unnessary running tasks. If it's on-line you may not have any control of what is happening on-line. You can only shut down ALL unnessary broswer Add-ons. Open Internet Options, Manage Add-ons, Toolbars and Extentions, disable ALL toolbars, In Search Providers, Remove ALL unnessary search providers. Run a FULL Malware scan using freeware MALWAREBYTES at: http://www.filehippo.com/download_malwarebytes_anti_malware/. Use CCLEANER freeware at: http://www.filehippo.com/download_ccleaner/, to clean the junk from your machine. In the TOOLS section, STARTUP, disable ALL unnessary startup programs.
1/5/2013 6:08:33 PM • Acer Aspire... • Answered on Jan 05, 2013
Buffering game how to fix it
Need more info. What game? On-line?
1/5/2013 5:58:04 PM • Acer Aspire... • Answered on Jan 05, 2013
I hear hissing noise from my laptop (acer aspire 5738) while i watching video and songs
Sir if you're using VLC player or any player that goes beyond the limitation of volume of the computers then don't use it.Go for normal windows player or real player
12/14/2012 2:13:34 PM • Acer Aspire... • Answered on Dec 14, 2012
Can i watch 3D movies on my acer aspire 5738 notebook?
can i able to view 3D movies in acer aspire one D270????
11/11/2012 1:59:07 PM • Acer Aspire... • Answered on Nov 11, 2012
Acer aspire 5738 cd DVD drive not working
1.start>control panel>all control panel items>AutoPlay change settings for each desired media 2.update the drivers for the DVD drive. search in all programs for the program name, go online and download the most recent driver3. you may have mulitple programs that controll DVD/CDR reading ability. this will sometimes confuse/conflict the drive. try removing one using add /remove programs from the control panel.
10/5/2012 6:02:40 PM • Acer Aspire... • Answered on Oct 05, 2012
I have a 4GB USB Stick when i plug him in my acer aspire 5738g he isnt able to use him as readyboost when i plug the same stick into a other acer aspire he is able to be used as readybooster. why is i
You have to verify exactly what type of memory to use. Also, it is possible that it isn't seated properly. However, I'm unsure if you are referring to 2 of the same model computers you are trying the memory in. Make sure that the laptop can use more than 2GB RamYou must first verify the limitations of the mother board, or computer model before upgrading.
9/17/2012 6:53:48 PM • Acer Aspire... • Answered on Sep 17, 2012
How to solve heating and shutdown problem while playing games or ani media
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
7/20/2012 11:48:44 AM • Acer Aspire... • Answered on Jul 20, 2012
Acer laptop display is gone after blue screen came as physical memory dump
try changing the physical drive to IDE or to the other option... if that doesnt help check your memory..success
6/21/2012 9:32:40 AM • Acer Aspire... • Answered on Jun 21, 2012
Acer Aspire Notebook Logo
80 questions posted
Steve Sweetleaf
Steve Sweetleaf
shadow
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
4gb usb stick when plug in acer aspire
  • Computers & Internet
