20 Most Recent VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Questions & Answers
2answers
** TAMPER ** VERIFONE VX670
VeriFone provides a clear tamper application to its service centres. you would have to locate a service centre closest to you to have that error cleared.
11/11/2019 6:11:28 PM • VeriFone VX570... • Answered on Nov 11, 2019
Our store's VeriFone Vx570 will
Have you triple-checked for a possible device on it that shouldn't belong? They are often disguised as if they are part of the reader. Malicious intruders are quick and smart on how they install them in front of multiple people. This is a possible reason why there's an issue. These disguised device attachments record credit card numbers and pin numbers. There are videos of how malicious intruders on how they install them (check out YouTube). I read a news article about someone installing such a device at the DMV. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/nicole_525c14680d45ee5d
11/15/2017 10:27:09 AM • VeriFone VX570... • Answered on Nov 15, 2017
0answers
MY HUSBAND BOUGHT A USED
First rule of thumb for resetting any computer peripheral is to look for a tiny hole somewhere on the back or bottom that is just large enough to poke the unfolded end of a paper-clip in. There may be an etching or label that says "reset" or it may say nothing. Push the end of an unfolded paperclip into that hole with the power off and hold it for 10 to 30 seconds to reset the device to factory. reset button on verifone-2tixnsi1a1hwbbvcdlqr4d03-4-0.jpg
9/28/2017 4:40:48 PM • VeriFone VX570... • Answered on Sep 28, 2017
Log into my account to change address
Do you know your user id and password? Google
6/27/2017 11:50:58 PM • VeriFone VX570... • Answered on Jun 27, 2017
4answers
TAMPER DEFAULT CERTIFICATE ON VERIFONE
Hi,you need to remove TAMPER through TAMPER recovery tool.
[email protected]
12/20/2016 12:33:48 PM • VeriFone VX570... • Answered on Dec 20, 2016
2answers
When one goes to purchase something, gives the assistant the credit card, but is handed back a credit card that is not yours, is out of date, but looks like yours a scam
credit cards have your name on it so if it has your name it is yours credit card companies keep advertising that you do not hand your card to anyone for this very reason there is now paywave and many operations don,t need any signature under a set amount ring your card company and report it as stolen if you suspect that it is not your card and a scam is in operation
7/27/2016 8:02:35 AM • VeriFone VX570... • Answered on Jul 27, 2016
Is not working it. Say tamper
you should send it to nearest authorized service center
1/25/2016 8:43:26 AM • VeriFone VX570... • Answered on Jan 25, 2016
2answers
My Verifone vx670 needs to release and reestablish
I also need to change the network settings on my Verifone VX 670 as i have recently installed a new wifi connection. Any help would be appreciated!
1/23/2016 9:12:42 PM • VeriFone VX570... • Answered on Jan 23, 2016
Verifone Vx570 given an error modem profile not set?
error modem profile not set appears when your Verifone VX 570 modem profile is not properly loaded or has been errased due to Tamper error or Bad RTC. Reloading back the modem profile will sometimes fix the error, but there is also a chance that your I/O module (form where you connect the power and telephone wire) is also bad, thats needs to be repaired or replaced. Call (775)358-2922 ask for Randy. Thanks.Backside of the I/O module of VX 5702_3_2012_10_48_12_pm.jpg
9/12/2015 7:22:28 AM • VeriFone VX570... • Answered on Sep 12, 2015
2answers
How to get verifone tamper recovery tool?
The software needed to remove "tamper" is a product that can be acquired from verifone. The problem is verifone has very strict requirements that has to be met before they will sell the software. Repair or this unit may be more than just software. If you need this unit repaired call Frank @775-338-6634. r
6/18/2015 12:18:51 PM • VeriFone VX570... • Answered on Jun 18, 2015
HYPERCOM OPTIMUM T4220
How do you add in the tip after you have closed out the credit card? She added one in after I am already passed the point in the system where you do it right away.
6/15/2015 10:27:13 PM • VeriFone VX570... • Answered on Jun 15, 2015
I applied for a credit card. did i get it?
that information is only available from the people you applied to try contacting them
5/19/2015 4:41:04 AM • VeriFone VX570... • Answered on May 19, 2015
How to remove a hypersafe lock on T4220
you can only remove this with the company that put it on your terminal. it is hardcoded and can be removed that way only
2/20/2015 11:16:24 PM • VeriFone VX570... • Answered on Feb 20, 2015
Verifone vx570 ink cartridge
there is no ink in this terminal it is thermal so it burns the image on the paper. make sure you buy thermal credit card paper. scratch the paper if a faint black line appears it is thermal this should be the side of the paper that is load to the bottom of the tray
2/20/2015 11:15:32 PM • VeriFone VX570... • Answered on Feb 20, 2015
Not respoinding to vmac
you need to check if the internet in your office that connects to the terminal is working. you may also need to reboot your system or do a partial download to connect to vmac. try unplugging for 1 min. then replug and see if this clears it. if it does not and you have transactions in your terminal you will need to call merchant services to assist you or you will lose those sales. try rebooting your internet modem and plugging it back in, unplug terminal power remove Ethernet cable reboot your modem plug in Ethernet, then power and see if that works
2/20/2015 11:10:14 PM • VeriFone VX570... • Answered on Feb 20, 2015
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
357 questions posted
Top VeriFone Computers & Internet Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • VeriFone Computers & Internet
Most Popular Question
remove tamper
  • Computers & Internet
