20 Most Recent
Trendnet TDMC400 USB and Ethernet 10100BaseT ADSL Fast Modem Router Questions & Answers
Why my modem taking restart evey day to use net
For the above mentioned issue the best solution is to reset and reconfigure your router. Before you reset your router lease make sure that you have the user name and password given to you by the Internet service provider and the disk provided with the router to re-install it.
Step 1: At the back of the router you have a small hole called reset, press and hold it for 10 seconds.
Step 2: Disconnect the power from the router and after 30 seconds and power it back on.
Step 3: Now run the disk provided with the router and check if there is a firmware/software update to it.
Once this is complete you should not be facing this issue again.
Hope this helps. Please feel free to contact us for further assistance and clarifications.
Screen blacks out on KVM
I have had this happen to me a few times. Usually it is the video card/driver. By KVM I assume you mean a KVM switch that goes to both computers, so you can switch between them? I have had trouble with them, too, so try putting the VGA straight to the monitor and see.
12/21/2017 1:25:51 PM •
Trendnet...
Answered
on Dec 21, 2017
Wi fi pasword
If you want to reset your wifi so you need to press wifi reset button click on it and hold about 20 seconds.
1/29/2015 7:40:06 AM •
Trendnet...
Answered
on Jan 29, 2015
How do I set a static route lan side on a tew-733gr
You need to download the user guide from here
TRENDnet Support
Basically
1. Make the computer or network device (for which you are establishing a DMZ link) has a static IP address (or you can use the DHCP reservation feature to ensure the device has a fixed IP address) (see "Set up DHCP reservation" on page 29).
A. Signing up for a Dynamic DNS service (outlined in the DDNS section) will provide identification of the router's network from the Internet.
2. Log into your router management page (see "Access your router management page" on page 22).
3. Click on Access, and click on Firewall & DMZ.
4. Next to DMZ Enable, click Enabled.
5. Next to DMZ Host IP, enter the IP address you assigned to the computer or network device to expose to the Internet.
6. To save changes, click Save Settings.
1/23/2015 10:50:47 AM •
Trendnet...
Answered
on Jan 23, 2015
Http 192.168.01
Need a dot between 0 and 1 then enter admin admin in both boxes if not that then admin password .google the default password for you router if you still have problems.they are listed.
12/5/2014 10:50:38 AM •
Trendnet...
Answered
on Dec 05, 2014
