Go through the installation guide to see the proper setup proceedure.
Then go through the user guide.
http://support.netgear.com/product/PTV3000#wrapper
Always read the manual, they contain helpful information that can save you a lot of headache.
Sounds like you have a firewall problem either with the Windows 7 built-in firewall or an anti-virus application firewall. Do you have an Anti Virus program installed?
click on start then right click on my computer, then click on manage, the a page will come up, on the left side of the page you will get the option of device manager on the left, once you will get the device manager, click on device manager, you will get the list of devices, in the list of devices, click on network adapters
once you click on network adapters there would be an option of wireless adapter, right click on wireless adapter and click on uninstall, once it is uninstalled, restart the computer, it will detect the drivers automatically
try to do this rest password on the router is u have to put in 0 26 times to reset the password typical problem of that kind of router try that and let me know leave a rating thanks.-natefixit
I'm not sure there is a problem. Intel WiDi is suppose to send what ever is displayed on your desktop to your TV. Is there a difference between what is shown on your TV and laptop's screen? It could also be that your laptop is set for extended display and the TV is set to the secondary display. Right-click on the desktop and select the Screen Resolution setting. If it is set to Extend then drag a window from your desktop to the right and it should show on your TV.
Jim, It depends how you connected the Netgear Push2TV adapter to your TV. The best way is to connect using an HDMI cable. Pay careful attention to which HDMI input you use in the Panasonic TV. Then using the remote control for your TV switch to that input. Usually there is a button label "Input" or "source". Make sure the Netgear Push2TV adapter is turned on and when you are switching among the various inputs you will see the Welcome screen on one that corresponds to the Netgear Push2TV adapter.
This sounds like an answer to someone's question? You need to click in the MY ANSWER box under the question. It doesn't work adding your ANSWER as a new QUESTION.
By connecting to your existing WiFi network and enhancing coverage, the NETGEAR range extender enhances your home WiFi network. The steps below will assist you in setting up your extender.We recommend using the Nighthawk app to set up your extension on our latest devices. See the following articles for more information:https://pnews.org/boost-your-speed-with-netgear-nighthawk-r7000/
QUICK TIP: When finding a location for your range extender, it is best to place it within the same room as the computer.
You can also use https://192.168.206.1 to access the range extender's web-based setup page.
Step 1:
Place the range extender in an area where the Wi-Fi signal of your router is strong, but near where you want to establish your extended network.
Step 2:
Plug in the power supply of the range extender and make sure that it is powered ON. Shortly, its light will begin to flash blue and orange.
Step 3:
Place your computer near the range extender. Also, make sure your computer is not wired to any other network devices.
Step 4:
Connect your computer to the range extender by opening the list of Wi-Fi networks and selecting Belkin.setup. Confirm that the list shows it's connected.
Step 5:
Open a web browser, enter https://belkin.range into the Address bar, and follow the on-screen instructions. Don't forget to type "http".
Once the setup for your range extender is complete, you may connect the computer to its Wi-Fi.
By Following these steps you can easily setup your Netgear wifi range AC1750 extender
Turn On Your Extender by plugging it into the power outlet, Wait till the extender is turned on and the power led light to stop blinking Once the device is fully booted up,
Now open your web browser, enter mywifiext.net in your web browser if you are Are going to setup your range extender using the window device.
Click on the New Extender Setup , Now Create a new account in case you do not have an account Already.
Accept the term and conditions, Click Continue
Now you will be asked whether you want to Configure your Netgear extender as a wifi extender or as an access point
Click as a Wifi Range extender
Now choose the network you wish to extend and click on the Next button
Enter the password of your current wifi and click next
Be Patience and wait for few seconds.
You had successfully setup your AC1750 Netgear range extender, in case if you are facing an issue with login into your Netgear extender read our extender login guide .
