20 Most Recent Maytag Bravos MVWB400V Washer Questions & Answers
I'm sorry but, if you cannot see where it is leaking from, you can appreciate that it is virtually impossible for anybody on this forum to remotely guess exactly from where it is leaking without being there and looking ;-0(
I fear that you only real option is another service call UNLESS you can work out where the leak is and tell us.
Sorry again and good luck,
John C
Maytag Bravos... | Answered on Aug 30, 2015
Check outlet filter is clear and hose aren't kinked
Maytag Bravos... | Answered on May 09, 2014
Click this link: Manuals
Maytag Bravos... | Answered on Jan 21, 2013
I'd try laying in some double sided tape...not pressed in there but just make ya a loop down at the bottom and run it in the spin cycle a few seconds..
If the coins come out, maybe they can catch on the tape.
Maytag Bravos... | Answered on Jul 17, 2011
Apparently your hoses are switched, it means you rinse cycle is pumping in hot water instead of cold. Turn off the water to the washer, switch hoes connections to washer or the wall, not both. This should fix the problem..
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Maytag Bravos... | Answered on Jul 15, 2011
There is likely to be a problem with either the door/lid solenoid/lock or the 'door/lid closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Maytag Bravos... | Answered on Jul 03, 2011
Unbalanced Load
Maytag Bravos... | Answered on May 30, 2011
The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation ive seen this same problem in whirlpools calypso, cabrio, and kenmore's oasis you will need to support the machine on a diagonal and go in from under neath removing the motor to gain acces to the rps sensor if you have any further questions message me back and dont be surprised these codes usually hide other codes in the kenmore i mentioned i went from rps sensor to lid switch to erc to entire wiring harness cost me like 260 in parts for a machine that maybe costed 499 at that time not a great fan of the rps sensor in any unit they seem to fail within 3 years hope this helps and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Maytag Bravos... | Answered on Apr 08, 2011
Hi and welcome to FixYa, I am Kelly The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation. It is fixable but will result in the replacement of failed parts. (Sensor or electronic control board) The control board is not cheap. Hopefully you only have a failed sensor.
Thanks for choosing FixYa,
Kelly
Maytag Bravos... | Answered on Feb 16, 2011
Maytag Bravos MVWB400V Washer Logo
50 questions posted
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
code f51
  • Washing Machines
