20 Most Recent Bissell Pet Hair Eraser Bagless Vacuum Questions & Answers
Beater bar only spins when vacuum is locked & upright.
Your belt is probably stretched and can't turn the brush when it's on the floor. Replace the belt at least twice per year.
3/8/2016 2:31:48 AM • Bissell Pet Hair... • Answered on Mar 08, 2016
tip
Change the belt
You need a phillips screwdriver with a good point because the screws are small. Dirt is goning to fall out,so be ready.---O.K.-- I usually sit on a folding chair outside with the vac upside-down on my lap & the handle between my legs.The screws you must remove are located in recessed holes around the brushes & back towards the wheels.These hold on the base plate.Take this off & the drive shaft should be visible.The beater bar (brushes) should slide straight out towards you. (You may want to look for clogs & generally clean this area now.) Loop the new belt over the end of the beater bar nearest the drive shaft & line it up with the gap in the brissles,then slide the beater bar back in place.Now's the hard part--Hold the beater bar in & pull the belt straight back over the drive shaft--Make sure it's on all the way & lined up straight with no kinks or twists. Replace the baseplate (Don't over tighten the screws or they will strip out & not hold) &you're done.
How to change the belt
Follow link below to www.bissell.com for belt change instructions,
http://www.bissell.com/how-to-videos/replace-brush-belt-vacuums/
11/23/2010 4:54:42 PM • Bissell Pet Hair... • Answered on Nov 23, 2010
2answers
More suction on my Bissell perfect sweep turbo. Doesn't suck very well
Check for any clogs in the hose and belt areas
11/24/2022 10:58:47 AM • Bissell Vacuums • Answered on Nov 24, 2022
How much are the Bissell 9200 ProHeat 2X Carpet Cleaner worth? New & used?
Question edited for clarity. You can't buy that model new as it is discontinued. For the secondhand market check eBay, or Facebook Marketplace. There does appear to be some old stock available, plus the newer model for $308. eBay has Pre-owned: Lowest price $160.99 + $100.20 Shipping https://www.google.com/search?q=Bissell+9200+price ..
11/3/2022 4:19:01 PM • Bissell Vacuums • Answered on Nov 03, 2022
2answers
I have a 7901-R Bissell dirtlifter that will not spray out water on to the floor could you help
There are an abundance of new cartridges on the market. It seems like every time we turn around, the market is flooded... Check this out: https://hodgdonretailstore.com/
10/31/2022 9:03:17 PM • Bissell Vacuums • Answered on Oct 31, 2022
2answers
Bissell Proheat X2 not spraying
https://www.youtube.com/watch?v=afFuV2j3r6w
9/26/2022 6:44:08 AM • Bissell Vacuums • Answered on Sep 26, 2022
6answers
The belt on my bissell powerforce compact keeps falling off the spindle. So its not moving the brush it stays on for a minute then falls off.
Either your belt has stretched beyond its specs or you have larger problems. Are you talking about a new belt? If not, try a new belt. If so, check to make sure the beater bar will spin freely without a belt attached. If it spins without a belt attached, make sure the bearing blocks at both ends are in good shape.
8/17/2022 2:50:00 PM • Bissell Vacuums • Answered on Aug 17, 2022
Bissell Crosswave Pet Pro
It is likely to be similar to the Clean View and Pro Heat. Or take into a Bissell Service Centre. https://www.google.com/search?q=Bissell+Cross+Wave+Pet+Pro+replace+motor ..
6/23/2022 12:21:18 PM • Bissell Vacuums • Answered on Jun 23, 2022
I, under stress put boiling in my BISSELL 2X revolutionary water tank! Now no water is being released. Could I have warped the tank and could I mould it back in?
You would see if you warped the tank, the issue is most likely related to melting some of the thin pump parts or tubing in the unit. Bissell does not sell those parts to the public. Find a repair center or send it in unless you want to buy a new one. PS in the future don't put high temp water in the tank, put it on the spot you are trying to clean and then vacuum it up.
2/8/2022 5:24:39 PM • Bissell Vacuums • Answered on Feb 08, 2022
Bissell vacuum belt partially melted
depends on model thy seem to start around $50.00. I would total parts cost vs new unit. if 50% or more replace.
2/6/2022 12:44:21 AM • Bissell Vacuums • Answered on Feb 06, 2022
Are Bissell electric motors replaceable with other electric motors?
Not normally, sometimes models have minor differences within the same range. Google make model replacement motor
1/19/2022 1:24:47 AM • Bissell Vacuums • Answered on Jan 19, 2022
2answers
Bissell Pet Hair Eraser Bagless Vacuum Logo
7 questions posted
Top Bissell Vacuums Experts
Marvin
Marvin
David Shaub
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Bissell Vacuums
  • Bissell Vacuums
Most Popular Question
beater bar only spins when vacuum locked
  • Vacuums
