20 Most Recent Samsonite Silhouette 11 SoftSide 22" Spinner Exp Upr Watch Questions & Answers
Added: I understand you have tried some steps to clear the combination lock. Check this web page to make sure you have tried all the possible options:
http://traveltips.usatoday.com/reset-samsonite-3digit-builtin-combination-lock-61343.html
(Copy and paste the web address above into your browser to get to the right page.)
Hello, Drjayapanick -
I checked the Samsonite web pages to try to find information for you.
Go to this web page (Contact Us information for Samsonite):
https://shop.samsonite.com/contact-us
On that page you can use the form to send an email regarding repairing the combination lock on your luggage.
Or, you may be able to find a business in Mumbai which sells Samsonite luggage, where you can take your bag to find out where you can have the lock repaired.
Samsonite... | Answered on Jan 08, 2018
Sure... here're the instructions - open the suitcase, then open the zipper in the modesty pouch (it is mounted on the backside of the suitcase, along its entire length), and then from in there, take out the plastic packet. In the plastic packet are labels, warranty information, AND voila - the instructions to set the combination lock... :-)
I would tell you here too:
1. Open the suitcase
2. Look at the inside back of the lock - you would see a red color tab, and two markings - A
Samsonite... | Answered on Sep 08, 2010
Your question ........................................
Watches | Answered 2 days ago
Why it won't unlatch
Watches | Answered 3 days ago
Welcome to Fixya. Can you provide the exact make and model so taht we can send you the manual.
Thanks
Watches | Answered on Nov 28, 2020
Of course, you can. The Opus Way crash course for CLAT will completely serve you the purpose. It takes a lot of strategic approach and right planning on part of the institution as they have to design the crash course in a way that the CLAT aspirant becomes successful, even if it is his first CLAT attempt. CLAT preparation at Opus will help you gain confidence for CLAT 2018. It is one of the best law entrance coaching institutes in India whose crash course for CLAT preparation has helped thousands of law aspirants across India. Some of the key features of the crash course of Opus for CLAT preparation are- 5 Advanced Workshops, 12 Mentor Books, 35 Full-Length Mocks, 10000 + topic wise questions, 6 days per week classroom teaching, year-wise CLAT papers and their solutions, as well as unlimited backups and helpline sessions.
If the screen goes dark, tap the screen to wake up the watch.
Swipe down from the top of the screen and tap the "Settings" icon. If you don't see the icon immediately, swipe left.
Tap the system date and time to select the time setting.
Watches | Answered on Nov 26, 2020
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Take your Amadeus watch to a jeweler and observe how to open it without damage, then note the replacement battery type for future reference.
Watches | Answered on Nov 19, 2020
There's a tiny slot you need to find that you can place a very small screwdriver to pry open the back plate. Then carefully lift off the plastic holder using the screwdriver to pry up in a couple of places. The battery is held in place with a "C" clamp which you can bend back with your fingers to pop out the old battery. Then reverse the procedure.
Watches | Answered on Nov 18, 2020
https://www.google.com/search?q=Bush+Nell+neo+XS+watch+repair&rlz=1C1CHBF_enUS757US757&oq=Bush+Nell+neo+XS+watch+repair&aqs=chrome..69i57j0i22i30i457.5183j0j4&sourceid=chrome&ie=UTF-8
Request from the manufacturer/distributor
Watches | Answered on Nov 14, 2020
fixya doesn't, but a jeweler might impart that information while replacing the battery.
Watches | Answered on Nov 11, 2020
Subaqua would be a possible source.
https://www.google.com/search?q=wr30m&oq=wr30m&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8 LEARNTO USE GOOGLE AND YOU MIGHT EVENTUALLY STOP ASKING US FOR HELP
Watches | Answered on Nov 08, 2020
if it is the Batman watch that has a secret screen that lights up when you pushed the bottom middle of the watch face this is what worked for me.I call that secret middle button the mode button.
push and hold that secret button on the watch face until the hour side of the time starts to blink. let go when you see the hour blink and then you can keep pressing to change the hour. to change the minute I let it go back into sleep mode then press and hold the secret button on the watch face and when it starts to blink let go for half a second and then press down and hold that button again and a minute numbers should start blinking. when they start blinking let go and then push once for each minute. it seems once you start one of these cycles letting go for half a second and then pressing and holding the mode button works. you'll have to experiment with how long to let go and then push.
Watches | Answered on Nov 07, 2020
You need the watch manual. The procedure varies across watches. You might be able to locate such via the manufacturer which should be on the back. If this is a Coast Guard watch, variations are sold at https://militarybest.com/coast-guard-watches.html
Whether or not they would or could help, I don't know.
I am rather presuming your query is unrelated to the following:
https://www.watchguard.com/help/docs/help-center/en-US/Content/en-US/Wi-Fi-Cloud/manage_wirelessmanager/configuration/system/timezone_location_tag.html
My Neff Digi watch only was the mode button on the top right and a light button on the top left. I tried various different methods for setting the time and can't figure it out please HELP!!
Watches | Answered on Nov 05, 2020
Samsonite Silhouette 11 SoftSide 22" Spinner Exp Upr Watch Logo
Popular Tags
6 questions posted
Top Samsonite Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Samsonite Watch Expert? Answer questions, earn points and help others
View Most Popular
Samsonite Watches
  • Samsonite Watches
Most Popular Question
please tell me
  • Watches
