20 Most Recent
Microsoft Outlook 2010 for PC (885370021134) Questions & Answers
How do I easily backup email files in Outlook 2010
Open Outlook, click on file in the top left hand side. Select Import and export. Now select export to a file and click next. Now select the file type you want save as (I mainly use a pst file and its the most common) and click next.
Now select which files you want to back up, for example Inbox, send items, contacts etc and click next. Now Click on browse and navigate to the external drive or save it to your desktop and copy the files to the external later on.
You can back up all of your emails this way just change the name of the file from backup to Inbox etc.
Regards.
12/20/2022 8:32:52 AM •
Microsoft...
Answered
on Dec 20, 2022
How do I Migrate email data from Outlook 2011 mac to windows outlook 2010 ?
Moving emails from outlook mac to outlook windows is a complicated process as both the platforms are totally independent of each other and does not support each others file formats. Outlook mac supports only olm database files whereas windows outlook only supports pst. Though there are pleanty of methods available like IMAP file transfer etc but the direct and most fruitful method is to simply convert olm file to pst format so that it can be imported in windows outlook. You may employ OLM to PST Converter Pro for conversion process and then import pst into windows outlook to move emails.
8/27/2022 3:13:09 AM •
Microsoft...
Answered
on Aug 27, 2022
MS Outlook won't start
Either delete the *.pst file and let Outlook re-build it. Or try running the "office repair" on outlook. Also a complete un-install, run a files cleanup from systems tools followed by re-installing Outlook might help.
There might be some *.pst repair tools out there but they probably cost money.
6/4/2022 11:44:10 AM •
Microsoft...
Answered
on Jun 04, 2022
Outlook 2010 wont always open
Hi Tami,You can fix your Outlook problem with the help of Scanpst.exe .With The help of Scanpst.exe you can repair your pst file just run the program and if everything is ok you can recover your PST File and after taht you can open your Outlook without any problem.As The .pst file corrution is the problem of your not opening Outlook so after the pst repair ther is no isues .If you did not repair your .pst file with help of Scanpst.exc program don't worry there so many third party data recovery for Outlook PST you can also try this type of software one of them which is personally used by me is Kernel for PST Repair you can try this software from here
http://www.pstrecoverytool.net/
3/23/2020 5:00:47 AM •
Microsoft...
Answered
on Mar 23, 2020
How to sync outlook contact categories to iphone
There are several ways to sync outlook contact to iPhone. Just follow below steps to complete this task.
Here we use iTunes to transfer Outlook contacts to iPhone. Please take note that iCloud must be disabled for this method to work.
Step 1. Lauch iTunes on your computer, and connect your device to your computer using the USB cable.
Step 2. Select the icon for your device located at the upper-left corner of the screen.
Step 3. Select the "Info" selection in the left pane.
Step 4. Check the contacts that you wish to transfer. To transfer contacts between Outlook and iPhone, choose "Outlook" afer you check "Sync Contact with", and then click on "Apply" button at the bottom.
For more methods, check:
How to Transfer Contacts Between Outlook and iPhone
8/29/2019 4:01:49 AM •
Microsoft...
Answered
on Aug 29, 2019
Set up Microsoft out look
technical errors are also quite obvious like every other man-made thing. Upon coming across with any such issue, the best recommendation can be to connect with the
Microsoft outlook support phone number. They can thoroughly solve all these issues. Prime reasons making Microsoft Outlook so much popular around the globe are:
10/22/2018 7:12:14 AM •
Microsoft...
Answered
on Oct 22, 2018
Bcc emails on Outlook 2010
Sounds like your Email has a set up issue. Check the Receive email setups under options. Make sure that you are able to receive BCC emails.
2/28/2012 1:56:42 AM •
Microsoft...
Answered
on Feb 28, 2012
1. Start Outlook. 2. On the Ribbon, click
If you cannot fit your PST file backup on a single drive please try choosing "Compressible Encryption" as the format to save as. This will reduce the amount of space needed to back up your PST file.
If it still won't fit then try backing up to a network drive.
Please let me know if this helps and rate my answer.
Many thanks,
Chris
3/2/2011 8:22:31 PM •
Microsoft...
Answered
on Mar 02, 2011
