20 Most Recent Sanyo R227 WiFi FM Radio Questions & Answers
I had the same problem. A defective capacitor is trying to charge near the audio chip .
My solution : I have remove the audio chip (the one with big heat sink) and I use the aux out output to my amplifier.
When plugging it takes some time to finally work : but once plug and working it stays on and work ok.
Sanyo R227 WiFi... | Answered on Mar 15, 2020
Flashing is caused by bad capacitors Caps on power supply board all go bad sooner or later, so replace them all ($5). Look for bulging tops especially, and the green ones are the worst. Power spike could have caused poor quality caps to fail. Don't want to fix it, sell it to me.
Could be bad capacitors or fuse. Fuse is inside under a plastic cover as I recall. Caps on power supply board all go bad sooner or later, so replace them all ($5). Look for bulging tops especially, and the green ones are the worst. Power spike could have caused poor quality caps to fail. Don't want to fix it, sell it to me.
If you can get a refurbished power supply board, buy it. They are as good as those new from factory. I bought a refurbished Sony Radio - Cassette - CD player 23 years ago and it's still good!
You'll never get this from them, as others have tried. Sanyo is now Panasonic (Matsushita). Also sold under the Medion name (in Europe I think).
Most likely bad capacitors on the power supply board. Replace them all (6 or 7). Same thing happened to mine. If you see green capacitors (KSC brand) they are definitely bad. Notorious for failing. Cost about $4 for me as I do it myself. Don't want to fix it yourself, sell it to me.
Yes there is. It is just inside the back cover on the right side looking from the back. It is located at the end of the brown wire from the power input jack. It has a plastic cover over it and is a
T2AL 250 volt (2 amp slow blow) with pig tails on it.
Sanyo R227 WiFi... | Answered on Dec 10, 2015
. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sanyo R227 WiFi... | Answered on Aug 17, 2014
Sanyo R227 WiFi FM Radio Logo
Popular Tags
34 questions posted
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Michel Laprise Sr
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Audio Players & Recorders
Most Popular Question
no power sanyo r227
  • Audio Players & Recorders
