20 Most Recent BOSS AUDIO SYSTEMS BV7320 Car Video Player Questions & Answers
if you trying to view the dvd while driving you have to bypass the secruity feature. all you have to do is connect the wire that goes to the Emergency Break to the Ground Wire On The DVD player. I Have This Player And Have Done This.
BOSS AUDIO... • Answered on Nov 28, 2013
you just need to ground the park brake wire
BOSS AUDIO... • Answered on Jan 29, 2013
your auxilury sounds like it is set to mono or s/w check your settings!!!!
BOSS AUDIO... • Answered on Oct 03, 2012
Connect the green parking brake wire to chassis ground or put the two wires on a toggle switch.
BOSS AUDIO... • Answered on Aug 17, 2012
their should be a safty wire run to the emergency brake that allows video only when the brake is set to bypass it you would need a relay wich you can get at autoparts store check out youtube for video on how to wire the relay
BOSS AUDIO... • Answered on Jan 30, 2012
Hi ryan_krue819,
There is a problem with the break wire. You will need to hook up the break wire in the harness. It is a protection wire so that it knows the emergency break is on. It is supposed to stop you from watching movies while driving. There is a wire in the back of the unit that needs to be hooked up to the parking brake. The break wire needs to be grounded.
Please follow these steps.
1. Locate the Brake wire.
2. Connect the Brake wire to a negative point. You may try to connect it to the body of vehicle.
3. Test by playing a DVD.
Hope it helps.
Thank you for using FixYa.
BOSS AUDIO... • Answered on Sep 15, 2011
Since you did not mention the year of the vehicle, I cannot be sure of the power/ground connection. However, if you are sure of the connections, let us proceed. Check the constant 12 volt for power. Check the accessory power connection for 12 volts when the key is on. Check the ground connection for a good chassis ground. If you do not have power at these connections, check your fuses at the vehicle fuse box and at the stereo head unit itself (if one exists). If all power and ground connection are good and all fuses are good and, your unit still does not power on, check and make sure that the pins in the stereo harness are properly seated.
If all of these things check out as good then the issue is with the head unit.
BOSS AUDIO... • Answered on May 27, 2011
Check this wiring for 2005 Ford Focus Car Stereo Wiring Schematic:
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
Hope help with this; keep us updated.
BOSS AUDIO... • Answered on Feb 07, 2011
BOSS AUDIO SYSTEMS BV7320 Car Video Player Logo
Popular Tags
27 questions posted
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ray gallant
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • BOSS AUDIO SYSTEMS Car Audio & Video
Most Popular Question
when insert dvd
  • Car Audio & Video
