20 Most Recent Sampo DVE-661 DVD Player Questions & Answers
manual
0answers
0answers
Manual for samsung un46es6500f
have you tried to GOOGLE FOR IT? TRIED TO CONTACT SAMSUNG?
3/23/2012 1:44:12 PM • Sampo Televison... • Answered on Mar 23, 2012
2answers
Code error
do a reset by going into your TV settings. You can also look in your booklet that came with the computer contacting sampo directly.
2/11/2011 12:17:17 AM • Sampo Televison... • Answered on Feb 11, 2011
Tv wont turn on
You need troubleshooting to find the cause of the problem first. It can be simple or complicate problems.
Please read my guide.
Please see my basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series. Please post back what you find.
12/2/2010 3:50:58 AM • Sampo Televison... • Answered on Dec 02, 2010
Have a 42" Sampo plazma
Before we proceed, i would like to share few details. The life of plasma totally depends on the usage. For a normal user it is anywhere between 10 - 14 years. There are few people who have actually used it for even more years depending upon usage and care. However, as i have no idea whether you have sparingly used it or the condition, so i would take an average life span.So, as a normal user you are left with less than 4 years before you would see other parts worn out. These are made in such a way that they mostly require replacement than repair, so cost is always a factor before getting them repaired. There is a thumb rule - when the cost of the repair is more than half the amount of the product, buy a new one.If are experience in electronics, could read schematics and would be able keep precautions, then it's different - you could save labor cost. Unless it is better to replace it.
I am sure you must have checked all the connections to make sure there is no lose connection. As unplugging didn't help you, there could be few causes ranging from digital board, sustain boards and few more. The more probable cause is driver board failing. If you call a tech, it would be an expensive deal taking into consideration the cost of the new plasma TV's and age of the TV.
Note - As i cannot diagnose the TV, this information is purely based on what i saw on most occasions on the basis of the description you gave.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
9/23/2010 4:42:28 AM • Sampo Televison... • Answered on Sep 23, 2010
I HAVE A YELLOW POWER
You are saying that the TV has no display and no sound, right?
Is there any blinking red or green light?
Thank you!
3/5/2010 9:11:21 PM • Sampo Televison... • Answered on Mar 05, 2010
I lost the remote and I cant find a universal
You can order origional remote from the factor for $10.
I also recommend checking ebay.Sampo Rl-611 Dvd Remote Control $19.95 - eBay
6/23/2009 4:42:33 PM • Sampo Televison... • Answered on Jun 23, 2009
3answers
4answers
I have a 42" Sampo-PME42S6
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works.. this not work check the cable try yo use another pair of cables ,even this did solve your problem then you need contact the company if under warranty ,if its out of warranty then you need get service from local TV repair center....
Good luck..
9/22/2008 4:15:00 PM • Sampo Televison... • Answered on Sep 22, 2008
Sampo DVE-611 apparently powers up
After several power ups, the front panel buttons eventually "woke up". Replaced remote, and everything's working fine. Not sure why the front panel was temporarily unresponsive.
8/11/2008 3:47:03 PM • Sampo Televison... • Answered on Aug 11, 2008
2answers
I replaced the three circuit boards in the back of my TV and I still have a black screen but lights up. Not sure what to do next. Any suggestions?
If replacing the circuit boards didn't solve the issue, here are a few suggestions that might help you fix the black screen issue on your TV:
Check the cables: Make sure all the cables connecting your TV to the wall and to other devices are securely plugged in and not damaged.
Reset the TV: Try resetting your TV to its original factory settings. This may resolve the issue if it was caused by a software problem.
Check the power source: Make sure the TV is receiving adequate power and that the power source is functioning correctly.
Try a different input: Try connecting a different device to the TV, such as a DVD player or a different cable or satellite box, to see if the problem is with the TV or with the source.
Contact a professional: If you have tried these steps and the issue persists, it may be a hardware problem. In this case, it's best to contact a professional for further assistance.
If you still have the warranty for the TV, it may be best to utilize it for repairs.
2/9/2023 12:39:24 AM • Televison &... • Answered 10 hours ago
LED TV has sound and picture, not backlight
You're LED backlights need replacing, you can get parts from shopjimmy,.com.
2/9/2023 12:34:17 AM • Televison &... • Answered 10 hours ago
Sampo DVE-661 DVD Player Logo
0 questions posted
Top Sampo Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sampo Televison & Video
Most Popular Question
ive just given technika television
  • Televison & Video
