20 Most Recent SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television Questions & Answers
SVA TV will not turn on.
I've got old sva tv I was watching tv n went off then didnt com on any suggestions plz
1/5/2018 5:30:34 PM • SVA-USA... • Answered on Jan 05, 2018
0answers
0answers
Conversion
Be the first to answer 4/17/2017 9:24:03 AM • SVA-USA... • Posted on Apr 17, 2017Be the first to answer
7answers
SVA PLASMA TV
I got this same tv from a guy in my area he would press the poewer botton on the tv and the standby light comes on and then turns off, so he gave me the tv for free i took the back panel off, and everytime i press the power botton the green light came on where the screen board is and went back off after i let the botton go i took the power board out took it to a repair shop to see if there was anything a wrong with it everything was good so i replaced the two fuses on the board and the one on the screen board, i had a feeling about the power switch so i jumped the wires on the switch purple to purple and green to green, I put it back together pluged it in the standby light came and stays on now, so i went out and got a universal remote for the sva at walmart for $15 programed it and pressto the tv works perfect so three fuses $3.60 two small pieces of wire and ele tape $0 my time 35 mins = one working plasma for $3.60 so when you have this problem like everyone else check the power botton switch, there cheap and check the fuses theres only three and if that dont work idk what to tell ya. and you do need a remote or tv wont work.
12/23/2015 7:06:44 AM • SVA-USA... • Answered on Dec 23, 2015
Why are there red lines in the middle of the screen?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
6/19/2015 3:42:45 AM • SVA-USA... • Answered on Jun 19, 2015
I HAVE A HD4208T3-PDP WITH NO REMOTE
http://www.ebay.com/itm/Replacement-Remote-for-SVA-PDP4208-HD4208TII-HD4208UII-HD4208TIII-/111089776871
3/23/2015 7:56:02 PM • SVA-USA... • Answered on Mar 23, 2015
Need power suply
just under $400 @ www.SVA-USA.Com
12/21/2014 10:04:57 AM • SVA-USA... • Answered on Dec 21, 2014
0answers
VR3718W set shuts off and comes back on by its self. does this several times
Two most likely areas are power supply (filter caps?) or the main board which controls almost everything---a bit like saying my car stalls---things have to be checked out.
8/30/2012 2:12:41 PM • SVA-USA... • Answered on Aug 30, 2012
0answers
3answers
I cant get the tv on...a red light comes on but it
The TV may simply be stuck in standby, the remote control will be required to get it started if there are no front panel controls. If there are front panel controls then the panel lock may be on. The remote is needed.
4/30/2012 11:13:55 PM • SVA-USA... • Answered on Apr 30, 2012
0answers
Who makes sva tv
Be the first to answer 4/10/2012 4:02:51 AM • SVA-USA... • Posted on Apr 10, 2012Be the first to answer
MY HD4208TIII=PDP IS STUCK ON STANDBY MODE. hOW DO I GET IT TO TURN ON?
HelloPlug it out from AC mains, and let it be in that state overnight, and then check. OK.
11/10/2011 7:13:45 PM • SVA-USA... • Answered on Nov 10, 2011
When plugged in, TV goes on and then goes off
This has nothing to do with the power cord, the fault is internal.
This is what happens: a part inside your tv has failed; when the tv is started the first thing that gets powered is the power source; when it reaches working order it starts to deliver the power to the other components, including the failed one; that failed one now acts as a short so the current thru it gets much larger than it should; this huge increase in current is detected by the safety system of the power source which gets triggered in emergency mode and shuts down the power source by force.
Normally the tv's processor would be powered long enough to detect itself the damaged part and generate a fault code - the status light should blink. If this doesn't happens it means that the fault is massive and affects directly the power source. Because of that the tv must be opened and tested, starting with the power source. The first step is something that you could do yourself, just follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
If, after that, you are still in the same situation, it's clear that another components were also damaged. From now on only an experienced repairman can do the diagnose, you will have to call one.
5/29/2011 4:00:13 PM • SVA-USA... • Answered on May 29, 2011
I weeould like this manuel
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
4/21/2011 9:15:25 PM • SVA-USA... • Answered on Apr 21, 2011
SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television Logo
99 questions posted
Top SVA-USA Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • SVA-USA Televison & Video
Most Popular Question
red lines in middle screen
  • Televison & Video
