20 Most Recent SVA-USA DP262 DVD Player Questions & Answers
I have a SVA DP262 DVD Player, lost remote. I have
See the user manual found here
RCA RCR312WR Universal
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/RCR312W_DOC_OM.pdf
9/19/2010 11:30:01 PM • SVA-USA DP262... • Answered on Sep 19, 2010
I cannot get th sound of the actors speaking .
Look for your owners manual on line.
8/23/2009 4:13:48 PM • SVA-USA DP262... • Answered on Aug 23, 2009
I have a dp262 dvd player and there was a power
You need to turn the progressive scan off. I presume your have the player connected using a yellow, red, and white cable. Progressive scan requires a different connection or else the screen will look like what you've described. There should be a button on your remote that says "pscan" or "p/s". If you don't see these or a button that says progressive scan, check for a button on the back of the player, and also check the setup menu of the player. You'll find it in one of those places.Let me know how it goes.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
7/11/2009 10:26:39 PM • SVA-USA DP262... • Answered on Jul 11, 2009
How to program ditagal channels
Switch to Air, or ASTC in Menu, re-scan. If it's cable, switch to cable, re-scan.
12/4/2020 7:38:20 AM • SVA-USA... • Answered on Dec 04, 2020
0answers
Tv error message
Be the first to answer 1/1/2014 3:48:54 AM • SVA-USA... • Posted on Jan 01, 2014Be the first to answer
Black square in the middle of my picture
Closed caption function is On. Turn it OFF.
4/13/2013 6:25:59 PM • SVA-USA... • Answered on Apr 13, 2013
I have a dark part on tha screen
If it is a burn our then the panel is kaput, otherwise, it must be the inverter.
1/16/2013 4:28:55 AM • SVA-USA... • Answered on Jan 16, 2013
We understand that your problem
some universal remotes are used only tv play.they did not open menu .so you bought original remote and solve your problem. thank you.
10/11/2010 8:06:53 PM • SVA-USA... • Answered on Oct 11, 2010
I have a small sva
With remote access the user menu and then Turn off the ' Closed Caption ' feature.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
6/16/2010 5:31:49 PM • SVA-USA... • Answered on Jun 16, 2010
2answers
Tcl 55s425 I get the back light but no display and some vertical lines
If you're getting backlight but no display and some vertical lines on your TCL 55s425 TV, it's possible that there is an issue with the T-Con board or its fuse. Since you've already inspected the ribbon cables and didn't find any issues there, checking the fuses would be the next step. If you see a fuse on the T-Con board, check it for continuity using a multimeter. If the fuse is blown, you'll need to replace it with a new one. If there is another smaller fuse on the board, you should also check that for continuity. If it's blown, replacing it may resolve the issue. If replacing the fuses doesn't resolve the issue, it's possible that there may be a problem with the T-Con board itself. In that case, it may need to be replaced or repaired. If you're not comfortable working with electronics or troubleshooting the TV, it's recommended to seek the help of a professional technician or contact TCL customer support for further assistance.
3/24/2023 1:01:56 PM • Televison &... • Answered 3 hours ago
I have a thin purple vertical line running down my screen from my webcam, How do I fix this?
A thin purple vertical line running down your screen from your webcam could be caused by a few different issues. Here are a few steps you can take to try and fix the problem:
  1. Check the webcam connection: Ensure that your webcam is properly connected to your computer. If it's a USB webcam, try unplugging it and plugging it back in.
  2. Update the webcam driver: Go to your computer manufacturer's website or the webcam manufacturer's website and download the latest driver for your webcam. Install the driver and restart your computer.
  3. Test the webcam on another computer: Try using the webcam on another computer to see if the issue persists. If it doesn't, the problem could be with your computer's graphics card or video driver.
  4. Check for software conflicts: Certain programs or software can conflict with the webcam and cause display issues. Try closing other programs while using your webcam to see if that resolves the problem.
  5. Contact the manufacturer: If none of the above steps work, contact the manufacturer of your webcam for additional troubleshooting or repair options.
If the issue persists, it could indicate a hardware problem with the webcam. In that case, you may need to replace the webcam or contact a professional repair service for assistance.
3/24/2023 9:03:08 AM • Televison &... • Answered 7 hours ago
Walker 43" tv. I have problems I go in Google. I got it secondhand and people didn't say that not work. Can you please help me what I have to do? All the time give me error. Please & thank you.
Unfortunately, you go scammed George. They got rid of it because of the faults. Take it in for repair, or at least find the manual online and read it first. The model number will be on the label next to the plug lead. Google make model manual https://www.google.com/search?q=Walker+43%22+television+manual ..
3/23/2023 6:06:57 PM • Televison &... • Answered 22 hours ago
What are the specs for Devant tv model 42CL900.
This is a Pinoy television. We are in North America. Check this link, as it should work better where you are. There are mentions of it and a link to the maker. https://www.google.com/search?q=devant+42cl900+Specifications ..
3/22/2023 9:31:26 PM • Televison &... • Answered Yesterday
How to level up my Bruhm 32 LED to 1080p HD?
Levelling up is easy, you can just put a book under one side. Converting to 1080p or 4K UHD is not so easy.
Bruhm 32 Inch TV BTF-32SC HD LED Digital Satellite TV
3/22/2023 5:40:14 PM • Televison &... • Answered Yesterday
2answers
Can you cast or mirror with this TV from Android device
Yes you can EXCEPT You give zero clue of the devices. all questions need 'make model (what it is)' and in you case you need TWO of those. Mirror your Android phone or tablet screen to the TV
  1. From your Android phone or tablet, open the Google Home app.
  2. Tap the left hand navigation to open the menu.
  3. Tap Cast screen / audio and select your TV.
Chromecast built-in - Learn - TV - Google
3/22/2023 6:06:15 AM • Televison &... • Answered 2 days ago
2answers
Hi. Where can I purchase a replacement battery for my portable DVD player? Model BAT-09?
It can bought from most of the electronic spare part selling shops.
3/21/2023 3:36:06 PM • Televison &... • Answered 3 days ago
SVA-USA DP262 DVD Player Logo
Popular Tags
4 questions posted
Top SVA-USA Televison & Video Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • SVA-USA Televison & Video
Most Popular Question
dp262 dvd player power
  • Televison & Video
